Hello,
With my DUE I am recieving encoder positions and writing the to an SD card via .csv. Each entry contains 2 ints and 2 floats with commas and no spaces.
Now, I wish to read the created file with the Arduino and just display them through the Serial communication. I am getting an error at:
if (!sdin.eof()) error("readFile")
It seems like the created file is not ending with an EOF which is triggering this error.
The code is large, so I will post the interface between writing and reading.
Writing
err = slaveEncoder - masterEncoder;
analogWrite(EnA, setPWM(err)); // Write PWM value as the encoder count of the Master (controller)
if (recordState == true){
int m;
m = millis();
if (m % LOG_INTERVAL == 0) {
// use buffer stream to format line
obufstream bout(buf, sizeof(buf));
bout << m << ',' << ID << ',' << masterEncoder << ',' << slaveEncoder << endl;
ID++;
#if ECHO_TO_SERIAL
cout << buf;
#endif // ECHO_TO_SERIAL
// log data and flush to SD
logfile << buf << flush;
// check for error
if (!logfile) error("!!WDF!!"); //Write Data Fail
// don't log two points in the same millis
if (m == millis()) delay(1);
if (Serial.available() > 0){
command = Serial.read();
if (command == 82){ //R - Record
cout << pstr("Recording...") << endl;
recordState = true;
return;
else if (command == 84){ //T - Traverse
cout << pstr("Stopped...") << endl;
logfile.close();
readFile();
recordState = false;
return;
else if (command == 83){ //S - Stop
logfile.close();
return;
else if (command == 88){ //X - Exit
logfile.close();
cout << pstr("Done!");
while (1);
else return;
Reading
void readFile() {
int read_millis;
int read_ID;
float read_ME, read_SE;
char comma1, comma2, comma3;
// open input file
ifstream sdin(fileName);
// check for open error
if (!sdin.is_open()) error("open");
// read until input fails
while (sdin >> read_millis >> comma1 >> read_ID >> comma2 >> read_ME >> comma3 >> read_SE) {
// error in line if not commas
if (comma1 != ',' || comma2 != ',' || comma3 != ',') error("comma");
// print in six character wide columns
cout << read_millis << setw(6) << read_ID << setw(6) << read_ME << setw(6) << read_SE << endl;
// Error in an input line if file is not at EOF.
if (!sdin.eof()) error("readFile");
If anyone can suggest a reason why I cannot read the file properly, I would really appreciate a tip
Daniel
