I'd like to do this skectch w/out delays. But don't know what to do...thanks for any help!
int timer = 300; // The higher the number, the slower the timing.
int ledPins[] = {5, 9, 13, 22}; // an array of pin numbers to which LEDs are attached
int pinCount = 4; // the number of pins (i.e. the length of the array)
int thisPin;
// the array elements are numbered from 0 to (pinCount - 1).
// use a for loop to initialize each pin as an output:
for (int thisPin = 0; thisPin < pinCount; thisPin++) {
pinMode(ledPins[thisPin], OUTPUT);
// loop from the lowest pin to the highest:
// turn the pin on:
digitalWrite(ledPins[thisPin], LOW);
delay(timer);
// turn the pin off:
digitalWrite(ledPins[thisPin], HIGH);
Have a look at the blink with out delay tutorial - http://arduino.cc/en/Tutorial/BlinkWithoutDelay -
I have but am having issues implimenting it...
Is it something like this ?!? ( Cant check it at the moment, but somewhere around these lines)
But note the fact you should try to understand it properly instead of just having someone to do it. RESEARCH, READ THE TUtORIALS, and always be explicit about things, specially your circuit with schematics or at least a good detailed explanation, otherwise we cant know and guess what is you want !!
// Variables will change:
int ledState = LOW; // ledState used to set the LED
long previousMillis = 0; // will store last time LED was updated
// the follow variables is a long because the time, measured in miliseconds,
// will quickly become a bigger number than can be stored in an int.
long interval = 1000;
int thisPin;
// check to see if it's time to blink the LED; that is, if the
// difference between the current time and last time you blinked
// the LED is bigger than the interval at which you want to
// blink the LED.
unsigned long currentMillis = millis();
if(currentMillis - previousMillis > interval) {
// save the last time you blinked the LED
previousMillis = currentMillis;
// if the LED is off turn it on and vice-versa:
if (ledState == LOW)
ledState = HIGH;
ledState = LOW;
// set the LED with the ledState of the variable:
digitalWrite(ledPins[thisPin], ledState);
Think your goal is to let the LEDS blink one by one for 300 msec, right?
something like this?
int timer = 300;
int pinCount = 4;
int currentPin = 0;
unsigned long lastLedTime = 0;
if (millis() - timer > lastLedTime)
lastLedTime += timer;
digitalWrite(ledPins[currentPin], LOW);
currentPin = (currentPin +1 ) % pinCount;
digitalWrite(ledPins[currentPin], HIGH);
// other code can be here
you right. i wrote that quick example on the move anyway.
Something wrong in your code but cant see what it is, tbh
I can, I missed the () after millis(), I fixed it in the code above.
please retry.
Corrected, though im not sure this is what you wanted. Still, its an example of how to implement it. Hope it helps to get the logic of it, so u can implement it to suit you.
int ledPins[] = {
2, 5, 9, 13 }; // an array of pin numbers to which LEDs are attached
// initialize serial communication at 9600 bits per second:
// make the pushbutton's pin an input:
// blink the LED.
ledState = HIGH;
ledState = LOW;
int thisPin;
Serial.println(ledState);
robtillaart:
please retry.
Yeah, thats it. Tired, as i need some rest .
Plus the fact he probably wanted as u did(one at a time)
actually he ended up with two examples to show you can implement it in different ways to suit your style.
as regarding the 300ms he could have changed it at the interval long integer.
I appreciate the help...however both codes end up with less than desired results...which is kinda why i am ripping my hair out.
One code blinks all 4 at once the other bdoesnt blink...only one light is on.
I kinda hate arduino now...
I tried both and they both work. Mine blinks them all at a time and his does a kind MICHAEL KNIGHT KIT's car effect.
Arduino is not a toy u can just play and do things without some effort put into it. You cant follow the maxim"If everything else fails, read the instructions" or expect to just copy every thing you think cool, without having some knowledge to know what and when to change this or that !!
Do some reading, start from the beggining if u have no idea of programming and electronics, and climb the stairs...STEP BY STEP !!
robtillaart's code for example is a good example of a nice, tidy code and you can see he is a good programmer.
Dont stress of get frustrated. NO PAIN, NO GAIN !! He didnt learn all that in one day...Noone does !!
I figured out my stupidity....the code was not "looping" because i never told it to...LOL...its somuch clearer now..
Thanks Everybody
Good.
Remember to watch some video tutorials, even if they are about projects you might not be interested in as they were done for a purpose and teaching something that is important essential knowledge to understand it better.
The multi_blink example may also help for future projects.
