Probably a dumb question, sure hope so. Can a normal through-hole crystal which works great on a 5V project generally be used for a 3.3V project or is there a special requirement? I bought my crystals on the cheap and I don't have a datasheet.
If you are talking about an atmega328p then the maximum supported clock speed @ 3.3V is 13.33MHz. In practice, you may get away with using a 16MHz crystal. The crystal itself doesn't care whether you run the microcontroller from 5V or 3.3V.
dc42:
Thanks. I have some slower crystals - 12Mhz and 8Mhz so I guess I will use those to be safe. Speed is not super important, the sketch has delays in it already. The MPU I want to use is a 328P-AU (TQFP).
I just got around to building this and when I switched it from the internal oscillator to the 16Mhz crystal it bricked the 328P-AU. I forgot about the details on this message so I desoldered that chip and put another one in and left it on the internal oscillator. I guess I can solder the bricked chip onto one of the other boards and try it with a slower crystal. Bad luck I guess. DOH.
