Hi all, I've got a few questions.
- I'm going to update the EEPROM Library and submit a pull request on Github here: GitHub - arduino/Arduino: Arduino IDE 1.x.
This is the correct place right?
- I then need to update the documentation. I'm not sure where to do that though. Is this the right place? GitHub - arduino/reference-en: Editable source for the Arduino Reference <--I can't find the EEPROM library documentation here, for instance.
As for documentation updating goes, here's more questions:
if I fork, modify, and do a pull request on this documentation repository, what documentation does it affect?
ie:
a) Arduino Website Documentation? (Arduino - Home)
b) Local IDE documentation on future downloads? (accessed via IDE help menu)
c) anywhere else I should know?
d) How do I update pages like this? Libraries - Arduino Reference <--the "Contributed Libraries" list, for instance, is outdated and should probably just point here (Arduino Playground - LibraryList), where I've already been able to make lots of contributions and improvements.
For the EEPROM library, I plan on adding read/write access for other variable types, namely: unsigned int, unsigned long, and float. I will keep the current functions to maintain backwards compatibility. I will be using the AVR library here: avr-libc: <avr/eeprom.h>: EEPROM handling
-I notice that there are update and write functions, but it seems to my I should ONLY use update, and not write at all. Ex: I should use eeprom_update_byte instead of eeprom_write_byte, so that I don't waste eeprom erase and write cycles to write a value already there. Is there any reason I should not do this? -
Side Question: anyone know what the process is for getting a new library included as part of the Arduino core?
-If I think it should be there, should I just make the change and do a pull request, or is there a process?
Thanks!
~Gabriel
