Oui je m'en doutais, ce n'etait pas tres clair
Voici un example. J'ai pris le code de demo
* HelloMenu
* by BREVIG http://alexanderbrevig.com
* This is the structure of the modelled menu
* Settings
* Pin
* Debug
* Options
* Delay (D)
* 100 ms
* 200 ms
* 300 ms
* 400 ms
#include <MenuBackend.h>
//this controls the menu backend and the event generation
MenuBackend menu = MenuBackend(menuUseEvent,menuChangeEvent);
//beneath is list of menu items needed to build the menu
MenuItem settings = MenuItem(menu, "Settings", 1);
MenuItem pin = MenuItem(menu, "Pin", 2);
MenuItem debug = MenuItem(menu, "Debug", 2);
MenuItem options = MenuItem(menu, "Options", 1);
MenuItem setDelay = MenuItem(menu, "Delay",'D', 2);
MenuItem d100 = MenuItem(menu, "100 ms", 3);
MenuItem d200 = MenuItem(menu, "200 ms", 3);
MenuItem d300 = MenuItem(menu, "300 ms", 3);
MenuItem d400 = MenuItem(menu, "400 ms", 3);
//this function builds the menu and connects the correct items together
void menuSetup()
Serial.println("Setting up menu...");
//add the file menu to the menu root
menu.getRoot().add(settings);
//setup the settings menu item
settings.addAfter(options);
options.addAfter(settings);
settings.addLeft(settings); //loop back if left on settings
settings.addRight(pin); //chain settings to pin on right
debug.addLeft(settings); //also go to settings left for debug
//we want looping both up and down
pin.addBefore(debug);
pin.addAfter(debug);
debug.addBefore(pin);
debug.addAfter(pin);
options.addLeft(options); //loop back if left on settings
options.addRight(setDelay); //chain options to delay on right
setDelay.addRight(d100);
d100.addBefore(d100); //loop to d400
d100.addAfter(d200);
d200.addAfter(d300);
d300.addAfter(d400);
d400.addAfter(d100); //loop back to d100
//we want left to always be bak to delay
d100.addLeft(setDelay);
d200.addLeft(setDelay);
d300.addLeft(setDelay);
d400.addLeft(setDelay);
This is an important function
Here all use events are handled
This is where you define a behaviour for a menu item
void menuUseEvent(MenuUseEvent used)
Serial.print("Menu use ");
Serial.println(used.item.getName());
if (used.item.isEqual(setDelay)) //comparison agains a known item
Serial.println("menuUseEvent found Delay (D)");
Here we get a notification whenever the user changes the menu
That is, when the menu is navigated
void menuChangeEvent(MenuChangeEvent changed)
Serial.print("Menu change ");
Serial.print(changed.from.getName());
Serial.print(" ");
Serial.println(changed.to.getName());
menuSetup();
Serial.println("Starting navigation:\r\nUp: w Down: s Left: a Right: d Use: e");
//fire Delay : menu.use('D');
//bail back to Options by moving up one logical level after a D : menu.moveRelativeLevels(-1);
Ensuite je me suis dis, ca va etre simple il me suffit de faire ceci:
void function displayOnOledScreen(MenuItem item){
//pseudo code
for(tous les items du meme niveau as currentItem){
si le current == item
print ">>" //pour montrer que c'est celui la selectionné
print le currentItem sur mon ecran oled
Et j'appelais cette fonction directement dans la fonction menuChangeEvent
Sauf que je me suis appercu qu'il n'est pas simple de recupéré les autres items d'un meme niveau a partir d'un item. Par conséquent ca complique tout et ca oblige a se faire une grosse structure de if ou case alors qu'on a déja toute la structure du menu detaillé dans l'objet "menu". Je trouves que ca duplique un peu le code.
À moins bien sur que je n'ai rien compris... Ce qui est possible aussi
