the reading from the voltage meter is 4.62
and yes it was a > 4.8
wiring as follows
~82k resistor + 10k trimpot (calibration) in series from A1 to +batt/supply
10k resistor from A1 to ground
100n capacitor from A1 to ground for stable readings
calibration a 9volt battery and a DMM, adjust trimpot to the same reading
i also tried the following
unsigned long total_1;
unsigned long total_2;
analogReference(INTERNAL); // use internal 1.1volt reference, change (INTERNAL) to (INTERNAL1V1) for a Mega
Serial.begin(115200); // ---set serial monitor to this value---
analogRead(1); // one unused reading to clear old sh#t
for (int x = 0; x < 1000; x++) { // 1000 readings
total_1 = total_1 + analogRead(1); // add each value
analogRead(2); // one unused reading to clear old sh#t
total_2 = total_2 + analogRead(2); // add each value
// print to serial monitor
Serial.print("Raw average = ");
Serial.print(total_1 * 0.001, 3); // 1000 readings /100, 2 decimal places
Serial.print(" | ");
Serial.print(total_2 * 0.001, 3); // 1000 readings /100, 2 decimal places
Serial.print(" Input A1 = ");
Serial.print(total_1 * 0.00001, 3); // convert milivolts to volts, display with 3 decimal places
Serial.print(" volt");
Serial.print(" Input A2 = ");
Serial.print(total_2 * 0.00001, 3); // convert milivolts to volts, display with 3 decimal places
Serial.println(" volt");
delay(1000); // optional readout delay
total_1 = 0; // reset values
total_2 = 0;
but the reading was as if there was nothing attached yes i do have a complete circuit and its been tested at both ends with a multimeter. this applies for all my available analog sockets
A0,A1, A3,A4 to the end
and the suggested code above just returns
5 Volt Supply = 4.80
no matter connected or disconnected from voltage.
i can't understand it .. it was working until i was told to put in the following wiring diagram
now with or without it im getting nothing. but the rest of the system is working
pinMode(8, OUTPUT);
digitalWrite(8, HIGH); // turn on the radio
pinMode(4, OUTPUT); // switch on the radio
digitalWrite(4, LOW); // ensure the radio is not sleeping
// read the input on analog pin 0:
int sensorValue = analogRead(A0);
// Convert the analog reading (which goes from 0 - 1023) to a voltage (0 - 5V):
float voltage = sensorValue * (3.5 / 750);
// print out the value you read:
Serial.print("3 3Volt Supply = ");
Serial.println(voltage);
// read the input on analog pin 5:
int sensorValueFive = analogRead(A5);
float voltageFive = sensorValueFive * (4.8 / 900);
Serial.print("5 Volt Supply = ");
Serial.println(voltageFive);
and this is working fine on both analog ports
but when i put it into a function in my code it stops working and just report 4.8 volts all the time
so its my code somewhere and there is 5 Tabs at about 1500 lines per tab
void VoltageCheck() {
main loop
// //is the time up for this task?
// if (millis() - lastMillis >= 1 * 30 * 1000UL)
// lastMillis = millis(); //get ready for the next iteration
// VoltageCheck();
VoltageCheck(); // temp line for debug main code commented above
delay(2000); // temp line for debug main code commented above
blueledBlink();
char command = Serial.read();
if (command == ('a')) {
emergency();
else {
// Wait for a touch
if (! ctp.touched()) {
return;
// Retrieve a point
TS_Point p = ctp.getPoint();
// flip it around to match the screen.
p.x = map(p.x, 240, 0, 240, 0);
p.y = map(p.y, 320, 0, 0, 320);
int a = page;
switch (a) {
// --------------check to see if screen 1 is loaded-----------------
case 1: { // Screen 1 Active As when screen 1 loads it chages the value of page to 1
if ((p.x > 175 && p.x < 201) && (p.y > 280 && p.y < 320))
setuser();
else if ((p.x > 144 && p.x < 163) && (p.y > 280 && p.y < 320))
systest();
else if ((p.x > 104 && p.x < 116) && (p.y > 280 && p.y < 320))
Serial.print("touch");
else if ((p.x > 58 && p.x < 72) && (p.y > 280 && p.y < 320))
Serial.print("option1.3");
else if ((p.x > 5 && p.x < 39) && (p.y > 280 && p.y < 320))
testfail();
break;
// -----------------check to see if screen 2 is loaded------------------
case 2: { // Screen 1 Active As when screen 1 loads it chages the value of page to 1
volup();
voldown();
Serial.print("option1.2");
mainmenu();
break;
// -----------------check to see if screen 3 is loaded------------------
case 3: { // Screen 1 Active As when screen 1 loads it chages the value of page to 1
Serial.println("one");
setuser();
Serial.print("option1.4");
break;
// -----------------check to see if screen 4 is loaded------------------
case 4: { // Screen 1 Active As when screen 1 loads it chages the value of page to 1
setuser();
break;
// ---------------------End Screen check ------------------------------------
// Print out raw data from screen touch controller for debug use only
// Serial.print(" X "); Serial.print(p.x);
// Serial.print(" & Y "); Serial.print(p.y);
// Serial.print(" Page Value= "); Serial.print(page);
// Serial.println();
// delay(500);
right im down to just the board Mega 2560 testing the voltage from a power converter outputting 5V via the capacitor and resistors as diagram top post
i am using the code
analogReference(INTERNAL1V1); // use internal 1.1volt reference, change (INTERNAL) to (INTERNAL1V1) for a Mega
total_1 = total_1 + analogRead(0); // add each value
// Serial.print(total_2 * 0.001, 3); // 1000 readings /100, 2 decimal places
Serial.print(" Input A0 = ");
with no voltage on A0
i am getting
Raw average = 1004.327 | Input A0 = 10.043 volt
Raw average = 1003.484 | Input A0 = 10.035 volt
Raw average = 1003.967 | Input A0 = 10.040 volt
Raw average = 1002.310 | Input A0 = 10.023 volt
this is something i expect
but with a voltage attached
Raw average = 1023.000 | Input A0 = 10.230 volt
if i try to adjust the voltage the output does not change with any voltage i am getting the last readout constantly
"if i try to adjust the voltage the output does not change with any voltage i am getting the last readout constantly "
I suggest you take out "analogReference(INTERNAL1V1);", because you will get max reading until the voltage on the analog pin goes below 1v1. If you take out that script, it should show changes when your voltage on the analog pin goes below 4v7.
with your voltmeter, read the analog pin. Adjust your pot to 0.5 volts showing on the analog pin.
Now what result is your code showing, raw reading from analog pin (before any math)?
Make sure you are using the same analog pin for hardware, as software. I have seen in posts that you were using A1 for hardware, and I think you have used A0 in script.
CAUTION note: When using a voltage divider on an analog pin, it is good practice to make sure the resistor to ground is secure, before hooking up the one to the sample voltage. If the sample voltage is above 5 volts, it is critical to do this.
No,
OP wants to measure the 5volt rail, and you CAN'T measure that with 5volt Aref.
Sketch works 100%.
Wrote it myself, and tested it myself.
Running right now on the bench, showing 5.029volt on the LCD.
OP has modded the sketch, and has some mistakes in there, but it still should work.
He should check his voltage divider.
Last picture we saw was a voltage divider with a 820ohm resistor instead of a 82k resistor.
And the 10k resistor in series with the 100n cap.
The voltage divider indeed has to divide to 0.5volt.
"OP wants to measure the 5volt rail, and you CAN'T measure that with 5volt Aref."
I beg to differ. I have used a 5 volt reference (default) several times, to measure anywhere from 2 volts to 18 volts. I have to modify the voltage divider for the higher voltages (or add a zener diode).
If your voltage divider is 50 50, then the 5 volt from the rail will show up on the analog pin as half (2.5v). Readable if using 5v aref, but not readable if using 1.1 volt.
Yes, you can measure any OTHER voltage, but NOT it's own 5volt rail.
Assume you have a 1:1 voltage divider connected to Arduino's 5volt rail.
The regulator is exactly 5volt. Default Aref is also 5volt.
The divider output is 2.5volt, and the A/D converts it to 512 digital.
The code converts 512 to 5.0volt for the display.
If the regulator would drop to 4volt, then Aref would also be 4volt.
The A/D sees 2volts as half of the reference voltage, and converts it to digital 512.
The code converts 512 to 5volt.
Leo..
Any Arduino with an internal reference can measure its own Vcc. Just select the internal reference, then use a voltage divider to divide Vcc down to the internal reference range. Some use 1.1V, some 2.56V, some have both and you must specify which one.
I sometimes use the 1.1volt and sometimes the 2.56volt (Mega only).
Say you have to use an LM35 temp sensor.
An LM35 outputs 0-1volt between 0 and 100 degrees C.
Read that with 1.1Aref and you have a scale of ~0-100 with ~0.1 degree resolution.
The limit of the A/D is ~100C.
Use the 2.56Aref, and the limit is the IC's temp limit. But with 2.5x less resolution..
Replace it with a TMP36.
They already output 1volt at 50 degrees C.
Only the 2.56Aref can measure -50C to +200C
Leo..
yes removing the analogReference(INTERNAL1V1)
worked i am getting results that show ok. but the trimpot needs to be turned right down to 2v to show 4.7v
but now i have my readings. but by looking at the code i can't see a way of putting and if statement in as i don't have a value to hold it against
eg the voltage is outputted to the serial monitor
how can i use this as a value to say if the value goes over 4.98v or in that range show an error
below is the working code
