I have done something similar quite recently and used NPN transistors instead.
Attach the base to whatever pin you would like to use, the emitter to the motor (with the other lead attached to ground), the collector to the 5v output on the arduino. Unfortunately, the motor can only turn one way, but it is a lot cheaper than say a motor shield.
