Why won't this print the whole number to the webpage?
Hi all,
I am having a bit of a dilemma here.... This sketch I have attached is meant to print the battery voltage measured on analog0 to a webpage. The issue is it will not add any of the decimal places, I am using the "float command" but still not working. When the code is set to dump the voltage to serial it prints it perfectly to 2 decimal places. Why isn't this working? How should I go about fixing it?
#include "etherShield.h"
#include "ETHER_28J60.h"
// Define MAC address and IP address - both should be unique in your network
static uint8_t mac[6] = {
  0x54, 0x55, 0x58, 0x10, 0x00, 0x24};
static uint8_t ip[4] = {
  192, 168, 0, 12};
static uint16_t port = 80; // Use port 80 - the standard for HTTP
int loadrelay = 7;
int solarrelay = 6;
int volt_val;
int voltage;
int light_val;
ETHER_28J60 ethernet;
  pinMode(loadrelay, OUTPUT);
  pinMode(solarrelay, OUTPUT);
  digitalWrite(solarrelay, HIGH);
  digitalWrite(loadrelay, HIGH);
  ethernet.setup(mac, ip, port);
}void loop()
    digitalWrite(solarrelay, HIGH); // turn solar regulator on
    volt_val = analogRead(0);
    float voltage = volt_val * (20.0 / 1023.0);
    Serial.println(voltage); //for calibrating voltage divider
    light_val = analogRead(1);
    //Serial.println(light_val); //for calibrating light sensor
    //low battery cutoff
    if(voltage  <12.5){
      digitalWrite(loadrelay, LOW);
      delay(1000*10);
    else{
      if(light_val >140){
        delay(10*1000);
      else{
    if (ethernet.serviceRequest())
      ethernet.print("<meta http-equiv='refresh' content='1'>");
      ethernet.print("<font face='verdana'>");
      ethernet.print("<center><H1>Remote Battery Management</H1></center>");
      ethernet.print("<p><b>Battery Bank Voltage</b></p>");
      ethernet.print(voltage); //this is the value which will not display the entire number.
      ethernet.print("<p> Wireless transmitter and IP camera are turned off if battery is low. </p>");
      ethernet.print("</font>");
      ethernet.respond();
lochienichols:
Hi all,
the problem is the ETHER_28J60.h ethernet library only has these two print methods:
	void print(char* text); 	// append the text to the response
	void print(int value);  	// append the number to the
So, it is converting the float to an int.
You need to create a character array, print your float into that buffer, then call ethernet.print(buffer). It will call the first of these two methods.
something like (untested):
      char buffer[10];
      sprintf(buffer, "%.2f", voltage);
      ethernet.print(buffer);
Thankyou, I will test this out now :slight_smile:
Okay so I have tried with your suggestion, now on the webpage I am left with a question mark where the voltage should be?! What's the next step?
serial.print(buffer); and see what it says.
you could try ethernet.print("4.92") to prove the concept as well.
Okay so,
serial.print(buffer); - this is printing question marks
Ethernet.print("4.92"); - that is printing to the webpage fine
Thankyou for the quick replies
so this line is the problem:
Ahhhh.
float format specifiers are not included in the Arduino libraries for sprintf.
The answer is to do it this way apparently:
So,
      char buffer[10];
      dtostrf(voltage, 6, 2, buffer);
