Topic: Help needed: direct drive LED matrix (Read 2336 times) previous topic - next topic
zhuxi1984
I was playing with this example:
http://www.arduino.cc/playground/Main/DirectDriveLEDMatrix
In the first code, it is rolling text to the left.
I am wondering what do I need to change to make it be able to roll the text to the other directions, such as right/up/down.
Hope those programming masters in this forum can help me out.
Thanks,
Designrats
halley
Code: [Select]
void slidePattern(int pattern, int del) {
 for (int l = 0; l < 8; l++) {
   for (int i = 0; i < 7; i++) {
     for (int j = 0; j < 8; j++) {
       leds[j][i] = leds[j][i+1];
     leds[j][7] = patterns[pattern][j][0 + l];
   delay(del);
This function on that page is responsible for "sliding" the existing contents of the leds[][] array out of view, and replacing them with another pattern.  In particular, leds[j] = leds[j][i+1]; sets a given LED to the value on its right-- do this for all LEDs in the correct order, and you'll see the whole image shift leftward one spot.  Then the statement leds[j][7] = patterns[pattern][j][0 + l]; deals with an LED in the rightmost column, by filling it with the appropriate cell in the next column of the new pattern.
It's a very straight-forward routine.  You could write three other similar routines that slide the contents in other directions.
Andrew
#2
Apr 02, 2009, 11:28 am Last Edit: Apr 02, 2009, 11:30 am by Andrew Reason: 1
Back when I wrote this code people were asking about it so I produced a commented version. Hopefully this will help you figure out what to do (also you can see the original thread at http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1203747843/17#17).
Code: [Select]
 // Loop 8 times, once for each column of new character to scroll in
 for (int loop = 0; loop < 8; loop++) {
   // First shuffle existing columns 1 to 7 into cols 0 to 6
     // Do each row of each column
   // Now copy new column from pattern onto end column of display
     leds[j][7] = patterns[pattern][j][0 + loop];
   // Wait for a bit
   delay(del);
 } // end loop for each column of new pattern
} // end function
Andrew
halley
Designrats, if you've tried a bit of tinkering there, but came up with ugly results, then perhaps you might not have noticed a key phrase in my reply:   do this for all LEDs in the correct order.
If you're scrolling columns rightward, you will need to visit all the columns in the opposite order as the given loop, otherwise each copy will damage data you've just written.
Likewise, if you're sliding up or down, then the order you visit the columns isn't important, but the order you copy the rows is key.
ason_cool
I've tried to compile the code but could not succeed
is warning / usr/lib/gcc/avr/4.3.3/../../../avr/include/stdlib.h: 111: error: expected unqualified-id before 'int'
/ usr/lib/gcc/avr/4.3.3/../../../avr/include/stdlib.h: 111: error: expected `) 'before' int '
warning is
warning is
warning is
warning is
What is the purpose of warning?
how to handle it?
PaulS
Which code?
Did you install (correctly) the FrequencyTimer2 library?
ason_cool
I use arduino  0017 and install frequency lib2 ...
in accordance with the already given
so what's my fault?
PaulS
Quote
What code?
