but is it globally blocking (like delay)?
Yes and no.
Look at eeprom.h source code (additional comment on the second line is mine)
/** \ingroup avr_eeprom
Write a byte \a __value to EEPROM address \a __p.
static __inline__ void eeprom_write_byte (uint8_t *__p, uint8_t __value)
do {} while (!eeprom_is_ready ()); // <<<<<<<<<<< delay()-like blocking busy wait
#if defined(EEPM0) && defined(EEPM1)
EECR = 0; /* Set programming mode: erase and write. */
#elif defined(EEPM0) || defined(EEPM1)
# warning "Unknown EECR register, eeprom_write_byte() has become outdated."
#endif
#if E2END <= 0xFF
EEARL = (unsigned)__p;
#else
EEAR = (unsigned)__p;
#endif
EEDR = __value;
__asm__ __volatile__ (
"/* START EEPROM WRITE CRITICAL SECTION */\n\t"
"in r0, %[__sreg] \n\t"
"cli \n\t"
"sbi %[__eecr], %[__eemwe] \n\t"
"sbi %[__eecr], %[__eewe] \n\t"
"out %[__sreg], r0 \n\t"
"/* END EEPROM WRITE CRITICAL SECTION */"
: [__eecr] "i" (_SFR_IO_ADDR(EECR)),
[__sreg] "i" (_SFR_IO_ADDR(SREG)),
[__eemwe] "i" (EEMWE),
[__eewe] "i" (EEWE)
: "r0"
Here's how I think it works...
A single EEPROM.write() call blocks only if there's a previous EEPROM.write() operation which is still not complete.
The act of starting an eeprom write operation is not blocking.
In your example, if you take out the sqrt() call, you just spend all of the 3.4 ms waiting for the eeprom to become ready after the last write().
If you insert the sqrt() call after the EEPROM.write(), you spend part of those 3.4 ms computing the sqrt(), and the rest of them waiting for the eeprom to become ready. So the wall clock time of the for() cycle is roughly the same in both cases.
