Wire Manufacturer / Supplier
It was a bit hard to pick a forum to post this in so I picked this one. (Moderators, If its the wrong one please move me to the correct one.)
I am looking for companies that can supply custom made cables that look like these:
![](http://i.ebayimg.com/00/s/MTIwMFgxNjAw/$(KGrHqZ,!q4F!-S1LdRLBQYnJ6ktpg~~60_12.JPG)
I have designing an Arduino CNC Shield and it needs a bunch of these cables to connect end-stops. (Need to be 100cm long as well)
Not sure what you call these as the ones I have found are called jumper wires or Dupont connectors (2.54mm pitch).
Any help will be appreciated.
Protoneer:
What's special about them? Why can't you just buy them on ebay like everybody else?
fungus:
The longest I could find on ebay was 30cm and those would not be long enough to reach all the ends on a small cnc router.
I bought a Ramps 1.4 3d printers board the other day and that came with 100cm cables that worked really well.
Protoneer:
fungus:
http://www.ebay.com/itm/321020831563
fungus:
Well spotted... thanks for that. They also have some 4 pin 100cm cables that will be perfect for stepper motors.
