Topic: School project (Read 353 times) previous topic - next topic
Stormpiggly
im currently working on a school project (ROV), and we are having some issues with it.
issue: The arduino wont give 5v out to the relay (it gives 3.5v)
im currently using Arduino 168 in the program "Proteus"
Source code:
 int motorf1 = 7;
 int btn1 = 4;
 { // put your setup code here, to run once:
 pinMode(motorf1, OUTPUT);
 pinMode(btn1, INPUT_PULLUP);
 { // put your main code here, to run repeatedly:
  if (digitalRead(btn1) == LOW){
   digitalWrite(motorf1, HIGH);
   digitalWrite(motorf1, LOW);
picture of the masterwork:
https://imgur.com/a/RamTy
Any advice or solution?  :smiley-confuse:
rogertee
Arduino outputs are logic outputs not power outputs that can drive things like LEDs. Best advise is use an optically coupled relay board they are made for Arduino. This requires you to feed the relay coil directly with 5 volts and the key is this power is fed in series with an opto coupler which isolates the Arduino outputs from relay coils and back emf problems. The Arduino output feeds a little LED inside the optoc black box and in the case of a 4n25 a phototransistor inside black box detects the LED light and turns on allowing power to the relay. On those type of relay interface boards there is usually a jumper that allows to to use the same 5volt supply as the Arduino is getting or remove jumper you supply a separate supply. To better understand this topic do a research on opto couplers as some are photo transistor, resistors, triacs, scrs,etc. A typical name for triac type is a solid state relay AC only.
6v6gt
Following that, if Proteus does not make a ready made relay module available to you, then use a transistor and a 1k base resistor to drive the relay. What incidentally was the specification of the relay (coil resistance etc.).
TomGeorge
#3
Jan 14, 2018, 09:33 am Last Edit: Jan 14, 2018, 09:35 am by TomGeorge
Welcome to the forum.
http://forum.arduino.cc/index.php/topic,148850.0.html then look down to item #7 about how to post your code.
It will be formatted in a scrolling window that makes it easier to read.
OPs circuit
Thanks.. Tom.. :)
Everything runs on smoke, let the smoke out, it stops running....
Stormpiggly
thanks for the help, Proteus only have ready made relays etc. But i have a small issue with the relays. They wont work on 5V. If i put the relays to go on 3v on proteus, everything works. But if i set them to 5v ( what i want them to go on) they wont work.
any solution/advice?
thanks for the help:)
Grumpy_Mike
Quote
That is just wrong, so I suspect you are not fully explaining what is happening. Also from your schematic, you can not connect a relay directly to an output pin. You also need a diode across the relay coil to protect the rest of the circuit.
Stormpiggly
ive made a new post " https://forum.arduino.cc/index.php?topic=524165.0 "
there with picture and code. ive made some changes from this schematic. but ill test with diode on the relay
thanks - Stormpiggly
Robin2
Don't double Post.
I have already suggested to the Moderator to delete the other one thinking you had double posted by accident.
...R
Two or three hours spent thinking and reading documentation solves most programming problems.
robtillaart
Moderator: duplicate removed
Rob Tillaart
Nederlandse sectie - http://arduino.cc/forum/index.php/board,77.0.html -
(Please do not PM for private consultancy)
Grumpy_Mike
#9
Jan 22, 2018, 11:34 am Last Edit: Jan 22, 2018, 11:34 am by Grumpy_Mike
Please post updates here, we don't allow duplicate posts on this forum.
