- * @file Cosa/IOStream.cpp
- * @version 1.0
- * @section License
- * Copyright (C) 2012-2015, Mikael Patel
- * This library is free software; you can redistribute it and/or
- * modify it under the terms of the GNU Lesser General Public
- * License as published by the Free Software Foundation; either
- * version 2.1 of the License, or (at your option) any later version.
- * This library is distributed in the hope that it will be useful,
- * but WITHOUT ANY WARRANTY; without even the implied warranty of
- * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU
- * Lesser General Public License for more details.
- * This file is part of the Arduino Che Cosa project.
- #include "Cosa/IOStream.hh"
- #include "Cosa/Power.hh"
- #include <ctype.h>
- const char IOStream::CR[] __PROGMEM = "\n";
- const char IOStream::LF[] __PROGMEM = "\r";
- const char IOStream::CRLF[] __PROGMEM = "\r\n";
- IOStream::IOStream(Device* dev) :
- m_dev(dev),
- m_base(dec),
- m_width(6),
- m_prec(4),
- m_eols((str_P) CRLF)
- IOStream::IOStream() :
- m_dev(NULL),
- m_base(dec),
- m_width(6),
- m_prec(4),
- void
- IOStream::print(int n, Base base)
- if (base != bcd) {
- char buf[BUF_MAX];
- if (base == dec) {
- print(itoa(n, buf, base));
- else {
- print_prefix(base);
- print(utoa(n, buf, base));
- else {
- print((char) ('0' + ((n >> 4) & 0xf)));
- print((char) ('0' + (n & 0xf)));
- void
- IOStream::print(long int n, Base base)
- if (UNLIKELY(base != dec)) print_prefix(base);
- print(ltoa(n, buf, base));
- void
- IOStream::print(unsigned int n, Base base)
- void
- IOStream::print(unsigned long int n, Base base)
- print(ultoa(n, buf, base));
- void
- IOStream::print(unsigned int n, uint8_t digits, Base base)
- utoa(n, buf, base);
- for (uint8_t length = strlen(buf); length < digits; length++)
- print('0');
- print(buf);
- void
- IOStream::print(unsigned long int n, uint8_t digits, Base base)
- ultoa(n, buf, base);
- print('0');
- print(buf);
- void
- IOStream::print(double value, int8_t width, uint8_t prec)
- dtostrf(value, width, prec, buf);
- print(buf);
- void
- IOStream::print(IOStream::Device* buffer)
- int c;
- while ((c = buffer->getchar()) != EOF)
- print((char) c);
- void
- IOStream::print_prefix(Base base)
- if (base == hex)
- print(PSTR("0x"));
- else if (base == bin)
- print(PSTR("0b"));
- else if (base == oct)
- print(PSTR("0"));
- void
- IOStream::print(uint32_t src, const void *ptr, size_t size, Base base, uint8_t max)
- Base b = (base != dec ? hex : dec);
- uint8_t w = (base == hex ? 2 : (base == bin ? 8 : 3));
- uint8_t* p = (uint8_t*) ptr;
- uint8_t n = 0;
- print(src, 6, b);
- print(PSTR(": "));
- while (size--) {
- print((unsigned int) *p++, w, base);
- src += 1;
- if (++n < max) {
- print(PSTR(" "));
- else {
- println();
- n = 0;
- if (size > 0) {
- print(src, 6, b);
- if (n != 0) println();
- void
- IOStream::vprintf(str_P format, va_list args)
- const char* s = (const char*) format;
- uint8_t is_signed;
- Base base;
- char c;
- while ((c = pgm_read_byte(s++)) != 0) {
- if (c == '%') {
- is_signed = 1;
- base = dec;
- next:
- c = pgm_read_byte(s++);
- if (c == 0) s--;
- switch (c) {
- case 'b':
- base = bin;
- goto next;
- case 'B':
- base = bcd;
- goto next;
- case 'o':
- base = oct;
- goto next;
- case 'h':
- case 'x':
- base = hex;
- goto next;
- case 'u':
- is_signed = 0;
- goto next;
- case 'c':
- print((char) va_arg(args, int));
- continue;
- case 'p':
- print(va_arg(args, void*));
- continue;
- case 's':
- print(va_arg(args, char*));
- continue;
- case 'S':
- print(va_arg(args, str_P));
- continue;
- case 'd':
- if (is_signed)
- print(va_arg(args, int), base);
- else
- print(va_arg(args, unsigned int), base);
- continue;
- case 'l':
- if (is_signed)
- print(va_arg(args, long int), base);
- else
- print(va_arg(args, unsigned long int), base);
- continue;
- print(c);
- char*
- IOStream::scan(char *s, size_t count)
- if (UNLIKELY(m_dev == NULL)) return (NULL);
- char* res = s;
- // Skip whitespace
- int c = m_dev->peekchar();
- while (c <= ' ' && c != '\n') {
- if (UNLIKELY(c == EOF)) return (NULL);
- c = m_dev->getchar();
- c = m_dev->peekchar();
- // Scan the token; identifier, number or special character
- count -= 1;
- *s++ = c;
- if (isalpha(c)) {
- while (count--) {
- if (!isalnum(c)) break;
- *s++ = c;
- else if (isdigit(c) || c == '-') {
- while (count--) {
- if (!isdigit(c)) break;
- *s++ = c;
- *s = 0;
- return (res);
- char*
- IOStream::readline(char* buf, size_t size, bool echo)
- const char DEL = 127;
- const char ESC = 27;
- int count = m_dev->available();
- if (UNLIKELY(count <= 0)) return (NULL);
- size_t len = strlen(buf);
- char* s = buf + len;
- char c = 0;
- while (count--) {
- if (c == ESC) continue;
- if (c == '\b' || c == DEL) {
- if (len > 0) {
- if (echo) print(PSTR("\b \b"));
- len -= 1;
- s -= 1;
- else {
- if (c == '\r') {
- if (echo) print(c);
- if (m_dev->eol() == CRLF_MODE) continue;
- c = '\n';
- if (len < size) {
- len += 1;
- *s++ = c;
- if (c == '\n') break;
- *s = 0;
- return (c == '\n' ? buf : NULL);
This file has been truncated. show original
