Used the if statement in the following sketch. The led is not coming on. Not sure where the variable, pressed, should be declared.
[quote]
[color=#7E7E7E]/*[/color]
[color=#7E7E7E] [/color]
[color=#7E7E7E] Turns on and off a light emitting diode(LED) connected to digital [/color]
[color=#7E7E7E] pin 13, when pressing pushbuttons attached to pins 2 and 3. [/color]
[color=#7E7E7E] The circuit:[/color]
[color=#7E7E7E] * LED attached from pin 13 to ground [/color]
[color=#7E7E7E] * pushbuttons attached to pins 2 and 3 from ground[/color]
[color=#7E7E7E] Written 1/27/13[/color]
[color=#7E7E7E] */[/color]
[color=#7E7E7E]// constants won't change. They're used here to [/color]
[color=#7E7E7E]// set pin numbers:[/color]
const [color=#CC6600]int[/color] button1 = 2; [color=#7E7E7E]// the number of the 1st pushbutton pin[/color]
const [color=#CC6600]int[/color] button2 = 3; [color=#7E7E7E]// the 2nd[/color]
const [color=#CC6600]int[/color] ledPin = 13; [color=#7E7E7E]// the number of the LED pin[/color]
[color=#7E7E7E]// variables may change:[/color]
[color=#CC6600]int[/color] pressed = 0;
[color=#CC6600]void[/color] [color=#CC6600][b]setup[/b][/color]()
[color=#7E7E7E]// initialize the LED pin as an output:[/color]
[color=#CC6600]pinMode[/color](ledPin, [color=#006699]OUTPUT[/color]);
[color=#7E7E7E]// initialize the 1st pushbutton pin as an input:[/color]
[color=#CC6600]pinMode[/color](button1, [color=#006699]INPUT[/color]);
[color=#7E7E7E]//turn on internal pull-up resistor[/color]
[color=#CC6600]digitalWrite[/color] (button1,[color=#006699]HIGH[/color]);
[color=#7E7E7E]//initialize 2nd pushbutton[/color]
[color=#CC6600]pinMode[/color](button2, [color=#006699]INPUT[/color]);
[color=#7E7E7E]//turn on pull-up resistor[/color]
[color=#CC6600]digitalWrite[/color](button2,[color=#006699]HIGH[/color]);
[color=#CC6600]void[/color] [color=#CC6600][b]loop[/b][/color]()
[color=#CC6600]if[/color] (button1 == pressed)
[color=#CC6600]digitalWrite[/color] (ledPin,[color=#006699]HIGH[/color]);
[color=#CC6600]else[/color] [color=#CC6600]if[/color] (button2 == pressed)
[color=#CC6600]digitalWrite[/color] (ledPin,[color=#006699]LOW[/color]);
[/quote]
In order to post code on the Arduino forum you need to completely ignore the 'copy for forum' command and just copy the text using 'copy'. You're pasting it into the forum inside CODE tags which is the correct thing to do, you're just using the wrong method to copy the source out of the IDE.
(IMO the 'copy as HTML' and 'copy for forum' commands are abominations which should never have got into the IDE in the first place and should have been chopped out at the first opportunity.)
Thanks for the helpful hint re. copying code to Forum. Here is the code - cleaned up and still not working.
The circuit:
Written 1/27/13
// constants used to
// set pin numbers:
const int button1 = 2; // the number of the 1st pushbutton pin
const int button2 = 3; // the 2nd
const int ledPin = 13; // the number of the LED pin
int pressed = 0;
pinMode(ledPin, OUTPUT);
pinMode(button1, INPUT);
digitalWrite (button1,HIGH);
pinMode(button2, INPUT);
digitalWrite(button2,HIGH);
if (button1 == pressed)
digitalWrite (ledPin,HIGH);
else if (button2 == pressed)
digitalWrite (ledPin,LOW);
Thanks guys. We are getting closer! Now button1 turns on LED, but the led does not stay on. The goal was to make the led stay on after one momentary button push. And use the second button to turn it off.
The circuit:
Written 1/27/13
// set pin numbers:
int pressed = 0;
if (digitalRead (button1) == pressed)
else if (digitalRead (button2) == pressed)
Ah - one way is to use a flag to indicate the on/off state.
When one button is pushed the flag is allowed to change.
Something like:
if (button1 is pressed and flag == high){
flag = low;
digitalWrite(ledPin, flag);
if (button2 is pressed and flag == low){
flag = high;
Still not there. Checked circuit and grounding and put a flag into the code. Now, button 2 turns LED on momentarily and nothing with button 1.
Turns on a light emitting diode(LED) connected to digital
pin 13, when pressing one pushbutton attached to pin 2,
and off again when pressing a second button, attached to pin 3.
The circuit:
Written 1/27/13
// set pin numbers:
int flag = HIGH;
if (digitalRead (button1) && flag == HIGH)
flag = LOW;
digitalWrite (ledPin,flag);
if (digitalRead (button2) && flag == LOW)
flag = HIGH;
if (Switch1) flag=HIGH;
if (switch2) flag=LOW;
digitalWrite(Led,flag);
this program however assume that you use an external pull down resistor to both switches and you have debounce both the switch to make it work reliably.
ash901226:
why do you need to have the argument like that?
why not just
Actually you don't need to debounce with that code and setup. Only pressing switch2 can reverse the action of switch1, and vice versa...
It looks like Loop is being called from elsewhere in the sketch, as I don't see an actual for/while/etc. loop in it. Since you declared Flag as a global variable, is it possible that the value of Flag on entering Loop is not what you are expecting?
One approach to fix this might be to eliminate Flag and use a digitalRead(Led) to retrieve the current state in the if statements - e.g.
if(!digitalRead(led) && digitalRead(button1)) { //Led is off, button 1 is pressed, turn on the led
digitalWrite(led,HIGH);
} else if (digitalRead(led) && digitalRead(button2) { //Led is on, button 2 is pressed, turn off the led
digitalWrite(led,LOW);
CrossRoads sorry i dont mean to be negative on your code... but i do mean why do you need to know the current state of the led... sine if you press switch1 it turn on switch2 it turn off...
So I'm really tired and can't quite think straight (bad news night) but thought I'd take the chance of replying in case it's useful (keeps mind off of other things) so sorry if this doesn't provide anything useful ...
const uint8_t pinLED = 13;
const uint8_t pinON_BUTTON = 2;
const uint8_t pinOFF_BUTTON = 3;
pinMode(pinLED, OUTPUT);
pinMode(pinON_BUTTON, INPUT);
pinMode(pinOFF_BUTTON, INPUT);
digitalWrite(pinLED, LOW);
// ... possibly incomplete ...
// ... an interesting thing is we can query an OUTPUT pin for its last written state ...
// ... so no need for separate flags ...
// ... second, LOW is considered 'false' and HIGH is not false and thus 'true' ...
// ... so when querying items 'LOW' is '0' and thus 'false' meaning any non 0 value is 'true' ...
// ... given that if a pressed button returns HIGH and a unpressed button is thus LOW ...
if ( digitalRead(pinON_BUTTON) && !digitalRead(pinOFF_BUTTON) && !digitalRead(pinLED) )
digitalWrite(pinLED, HIGH);
else if ( !digitalRead(pinON_BUTTON) && digitalRead(pinOFF_BUTTON) && digitalRead(pinLED) )
@ash901226 ,
No problem. Here's what I think I think was thinking:
If the state of the LED was tracked, one wouldn't need to spend pointless time going thru the steps of digital writes when the desired condition was already set.
Sorry about the long absence from this project (dental implant && medications == brain, OFF) but thanks for all the suggestions and debate.
The circuit and components - simple as it is - has been checked forwards and backwards. The two if statements work by themselves, turning the Led on or off. I.e. the innards of the Arduino are not at fault. Yet, can not get them to work together.
Went back to external pull-down resistors. Agree that debouncing should not be needed here (the two "push buttons" are in fact reed switches, reliably activated by a train to set or clear a red signal).
The post by lloyddean pretty much summarizes previous ideas, including reading the output pin as an argument in the on/off function. (is const uint8_t the same as const int; the former won't work in my version).
But OFF_BUTTON (= button2) does not work in this sketch. Not sure what serial.print could tell us here that can not be seen with the Led on pin 13.
Apologies are in order! One of my test buttons from the junkbox was a normally-on type (didn't even know they exist), keeping pin 3 high instead of low. =(
Going back to test all the code previously submitted.
