Topic: LCD + Analog Sound Sensor (Read 847 times) previous topic - next topic
claw106
May 19, 2017, 12:18 pm Last Edit: May 19, 2017, 04:12 pm by claw106
Hi, I wish to create something where when a sound is detected on the Sound Sensor, the LCD screen is printed with "loud"
LCD Info:
i2c 16x2, address is 0x20, works fine with normal text, etcetc.
LCD Link
Analog Sound Sensor link
This is my setup:
I am a complete nub when it comes to coding and this kind of stuff, I haven't experimented much with this and I'm still learning, so please forgive me. Any help would be appreciated.
PaulRB
Let's see your best attempt at the code so far. *Use code tags!*
claw106
Code: [Select]
#include <Wire.h>
#include <LCD.h>
#define I2C_ADDR    0x20 // <<----- Add your address here.  Find it from I2C Scanner
#define BACKLIGHT_PIN     3
#define En_pin  2
#define Rw_pin  1
#define Rs_pin  0
#define D4_pin  4
#define D5_pin  5
#define D6_pin  6
#define D7_pin  7
int n = 1;
LiquidCrystal_I2C  lcd(I2C_ADDR,En_pin,Rw_pin,Rs_pin,D4_pin,D5_pin,D6_pin,D7_pin);
int soundDetectedPin = 10; // Use Pin 10 as our Input
int soundDetectedVal = HIGH; // This is where we record our Sound Measurement
boolean bAlarm = false;
unsigned long lastSoundDetectTime; // Record the time that we measured a sound
int soundAlarmTime = 500; // Number of milli seconds to keep the sound alarm high
void setup ()
  lcd.begin (16,2); //  <<----- My LCD was 16x2
// Switch on the backlight
lcd.setBacklightPin(BACKLIGHT_PIN,POSITIVE);
lcd.setBacklight(HIGH);
lcd.home (); // go home
  pinMode (soundDetectedPin, INPUT) ; // input from the Sound Detection Module
void loop ()
  soundDetectedVal = digitalRead (soundDetectedPin) ; // read the sound alarm time
  if (soundDetectedVal == LOW) // If we hear a sound
    lastSoundDetectTime = millis(); // record the time of the sound alarm
    // The following is so you don't scroll on the output screen
    if (!bAlarm){
      Serial.println("LOUD, LOUD");
      lcd.print("LOUD");
      bAlarm = true;
    if( (millis()-lastSoundDetectTime) > soundAlarmTime  &&  bAlarm){
      Serial.println("quiet");
      bAlarm = false;
So far, the code works, I upload it and the serial monitor prints "LOUD" and the LCD prints "LOUD" but its constantly on loud. Is this because the ambient noise is too loud?
PaulRB
#3
May 19, 2017, 06:21 pm Last Edit: May 20, 2017, 11:00 am by PaulRB
Some sound sensors have an analog output and a digital output. You can adjust the sensitivity of the digital output by adjusting a pot on the sensor.
Your sensor has only an analog output. But you seem to have connected that to a digital input on the Arduino. So change that to one of the analog inputs and use analogRead() instead of digitalRead(). If you print the value to serial monitor, you will get so see the range of values you get with loud & quiet sounds. Then you can choose a value between those ranges and check the result of analogRead() against that value .
Grumpy_Mike
Quote
And if you turn on the serial plotter instead of the serial monitor you get to see a graph or waveform diagram of what is coming in.
claw106
Your sensor has only an analog output. But you seem to have connected that to a digital input on the Arduino. So change that to one of the analog inputs and use analogRead() instead of digitalRead(). If you print the value to serial monitor, you will get so see the range of values you get with loud & quiet sounds. Then you can choose a value between those ranges and check the result of digitalRead() against that value .
This worked perfectly, thank you very much.
I found this very interesting, thanks.
PaulRB
Post your corrected code. It may be useful to others.
