Topic: Power dissipation IGBT sanity check (Read 180 times) previous topic - next topic
morrisonandboyd
Hi was hoping for a sanity check.
Looking at a FGY75N60SMD IGBT
Driving at 50 Khz, 50% duty, 75A, 311V DC
Was trying to figure heat dissipation in device.
I calculated 236 watts switching loss, and 54 watts of resistance dissipation (call it 300 watts)
Device is rated to 375 watts.
Switching loss is 4.71mJ (x 50,000 cycles/ second) = 236j/sec= 236watts
Resistance loss calculated from Saturation voltage characteristics (fig3 in Fairchild data sheet Rev C2)
R=(deltaV)/(Delta Amps) = 1.4V/146Amps) = 0.0096 ohms
P = I*I*R = 75A*75A*(0.0096) = 54
Have I missed anything besides the obvious need to quench this thing in the Mississippi river??
Thanks,
MB
TomGeorge
#1
Jun 13, 2018, 12:24 pm Last Edit: Jun 13, 2018, 12:36 pm by TomGeorge
Load = V * I = 311 * 75 = 23325 Watts (23.3kW)
At 50% duty = 23325/2 = 11662.5 Watts
Your IGBT losses = 236 + 54 = 290 Watts
Switching efficiency= 11662.5 / (290 + 11662.5) =0.975 == 97.5%
Sounds pretty good.
You will need a decent heatsink and forced cooling, some more equations to play with.
Tom... :)
Everything runs on smoke, let the smoke out, it stops running....
morrisonandboyd
Thanks Tom!,
Appreciate second set of eyeballs.
MB
