Fairly simple code that probably can be modified to do what you want.
//zoomkat 3-5-12 simple delimited ',' string
//from serial port input (via serial monitor)
//and print result out serial port
String readString, data;
int CD, CM, CT, CS, BR;
Serial.println("serial delimit test 1.0"); // so I can keep track of what is loaded
//expect a string like CD01,CM01,CT01,CS03,BR255,
if (Serial.available()) {
char c = Serial.read(); //gets one byte from serial buffer
if (c == ',') {
Serial.println(readString); //prints string to serial port out
if(readString.indexOf("CD") >=0) {
data=readString.substring(2);
Serial.print("CD is: ");
Serial.println(data);
CD = data.toInt();
Serial.println(CD);
Serial.println();
if(readString.indexOf("CM") >=0) {
readString=readString.substring(2);
Serial.print("CM is: ");
CM = readString.toInt();
Serial.println(CM);
Serial.println();
if(readString.indexOf("CT") >=0) {
Serial.print("CT is: ");
CT = readString.toInt();
Serial.println(CT);
Serial.println();
if(readString.indexOf("CS") >=0) {
Serial.print("CS is: ");
CS = readString.toInt();
Serial.println(CS);
Serial.println();
if(readString.indexOf("BR") >=0) {
Serial.print("BR is: ");
BR = readString.toInt();
Serial.println(BR);
Serial.println();
//do some stuff
readString=""; //clears variable for new input
data="";
else {
readString += c; //makes the string readString
