I will now prepare a sketch with all possible moves:
F (Front), B (Back), U (Up), D (Down), L (Left), R (Right), plus the " ' " and " 2 " variantsFor debugging purpose, moves will be entered through Arduino's serial monitor
Here it is:
#define VERSION "Cube Mover V1.2 @kas2014\n"
// V1.2: refactored using Cube class
// V1.1: replaced Servo with VarSpeedServo library
// V1.0: initial release
#include <VarSpeedServo.h>
#include "cube.h"
// ---------- user adjustments -------------------
#define DOWN_CLOSE 91 //92
#define DOWN_OPEN 132
#define DOWN_CW 6
#define DOWN_MID 89
#define DOWN_CCW 172
#define BACK_CLOSE 84 //85
#define BACK_OPEN 129
#define BACK_CW 2
#define BACK_MID 87
#define BACK_CCW 171
#define LOW_SPEED 50 //50
#define HI_SPEED 100 //80
#define downPinchPin 9
#define downRotPin 10
#define backPinchPin 5
#define backRotPin 6
#define bipPin 11 // buzzer
#define myRX 2
#define myTX 3
#define STX 0x02 // serial data frame delimiters
#define ETX 0x03
Cube myCube(downPinchPin, downRotPin, backPinchPin, backRotPin);
char cmd[128]; // bytes received buffer
Serial.begin(57600);
Serial.println(VERSION);
pinMode(bipPin, OUTPUT);
myCube.begin(HI_SPEED); // set HIGH servo's speed
myCube.downSetLimits(DOWN_CLOSE, DOWN_OPEN, DOWN_CW,DOWN_MID, DOWN_CCW); // set limits for pinch and rotation servo's
myCube.backSetLimits(BACK_CLOSE, BACK_OPEN, BACK_CW, BACK_MID, BACK_CCW);
myCube.seize();
bip(20, 2); // bip
if(getSerialData()) parseData();
boolean getSerialData() {
if(Serial.available()) { // data received from smartphone
delay(2);
cmd[0] = Serial.read();
if(cmd[0] == STX) {
int i=1;
while(Serial.available()) {
delay(1);
cmd[i] = Serial.read();
// Serial.print(cmd[i]);
if(cmd[i]>'u' || i>124) { bip(20, 5); return false; } // Communication error XXX reinitialiser à zero <<<
if((cmd[i]==ETX)) return true; //
i++;
return false;
boolean getSerialMonitor() { // Serial Monitor fsetting: Newline
for(int i=0; i<124; i++) cmd[i] = 0;
int n = Serial.readBytesUntil('\n', cmd, 124);
// Serial.print(cmd[0]); Serial.print(" ");
cmd[n+1] = ETX;
return true;
return false;
void parseData() { // parseData(cmd)
int i = 0;
String progress = "";
while (cmd[i] != ETX) {
// Serial.print(cmd[i]); mySerial.print(" ");
switch(cmd[i]) {
// Move commands ------------------------------------------------------------
case 'R': // 'R' moves
switch(cmd[i+1]) {
case '2':
Serial.print("R2 ");
myCube.R2();
break;
case 39:
Serial.print("R' ");
myCube.Rp();
break;
default:
Serial.print("R ");
myCube.R();
break;
break;
case 'L': // 'L' moves
switch(cmd[i+1]) {
case '2':
Serial.print("L2 ");
myCube.L2();
break;
case 39:
Serial.print("L' ");
myCube.Lp();
break;
default:
Serial.print("L ");
myCube.L();
break;
break;
case 'U': // 'U' moves
switch(cmd[i+1]) {
case '2':
Serial.print("U2 ");
myCube.U2();
break;
case 39:
Serial.print("U' ");
myCube.Up();
break;
default:
Serial.print("U ");
myCube.U();
break;
break;
case 'D': ** snip (9000 caracters limitation) **
case 'F':
case 'B':
break;
// Scan commands -----------------------------------------------------------
case 'f': // Scan Front side
myCube.scanFront();
Serial.println("OKf");
break;
case 'r': // Scan Right side
myCube.scanRight();
Serial.println("OKr");
break;
case 'b': // Scan Back side
myCube.scanBack();
Serial.println("OKb");
break;
case 'l': // Scan Right side
myCube.scanLeft();
Serial.println("OKl");
break;
case 'u': // Scan Up side
myCube.scanUp();
Serial.println("OKu");
break;
case 'd': // Scan Down side
myCube.scanDown();
Serial.println("OKd");
break;
case 'g': // back to Front side
myCube.scanFront2();
Serial.println("OKg");
break;
// Other commands --------------------------------------------------------------
case 'T': // release gripper pressure
myCube.seize();
bip(40, 2);
Serial.print("seize");
break;
case 'S': // change move speed
switch(cmd[i+1]) {
case '2':
myCube.setSpeed(HI_SPEED);
Serial.print("High Speed");
break;
case '1':
myCube.setSpeed(LOW_SPEED);
Serial.print("Low Speed");
break;
break;
case 'V': // bips
switch(cmd[i+1]) {
case '4':
bip(80, 4);
Serial.print("bip (4)");
break;
case '2':
bip(80, 2);
Serial.print("bip (2)");
break;
default:
bip(80, 1);
Serial.print("bip ");
break;
break;
default:
break;
i++;
Serial.println();
bip(20, 2);
void bip(int duration, int n) { // Bip piezo: duration in ms, n repeats
for(int i=0; i<n; i++) {
digitalWrite(bipPin, HIGH);
delay(duration);
digitalWrite(bipPin, LOW);
delay(75);
I also created a library to separate the "logic" of the program from the low-level details
EDIT: see post #43 for complete code including cube.h
According to Singmaster notation,
myCube.L generates a move
myCube.L2 for move
myCube.Lp (L prime) for a <L'> move
For demonstration purpose, the cube was first mixed according to < D B2 R2 U' F' L F2 R D2 R B2 R' >
In this video, I entered < R B2 R' D2 R' F2 L' F U R2 B2 D' > (inverse moves) in the IDE Serial Monitor.
>> Video <<
The cube is restored, as expected
I will now create a simple Python script (2 buttons) that will:
- Launch Cube Explorer
- move the cube, face by face, for color recognition by Cube Explorer
- request and obtain the solution from Cube Explorer
- transfer this solution to Arduino
