I want to add date & time to the SD card file. It was working OK before changing to RamDisk.
#include <SPI.h>
#include <SdFat.h>
#include <SdFatUtil.h>
#include <M23LCV1024.h>
#include <RamDisk.h>
#include <RTClib.h>
#include <Wire.h>
RTC_DS1307 RTC; // define the Real Time Clock object
void setupRAM(){
ram.begin(RAM_CS_PIN);
Serial.print(F("FreeRam: "));
Serial.println(FreeRam());
if (!sd.begin(SD_CS_PIN)) sd.errorHalt();
// Initialize RAM
if (!vol.format(&ram, 256, 4, 1)) {
Serial.println(F("format fail"));
return;
if (!vol.init(&ram)) {
Serial.println(F("init fail"));
return;
Wire.begin(); // add time stamp
if (!RTC.begin()) {
Serial.println("RTC failed");
while(1);
SdFile::dateTimeCallback(dateTime); // set date time callback function
sprintf(FILENAME, "run_%d.CSV", fileNum);
vol.remove(FILENAME); //format
if (!ramFile.open(FILENAME, O_CREAT | O_RDWR)) {
Serial.println(F("open fail"));
return;
Serial.println(F("Ready to write ramFile"));
Errors:
ADXL345_To_RAM.ino: In function 'void setupRAM()':
ADXL345_To_RAM:125: error: 'dateTime' was not declared in this scope
BTW, the speed increase is impressive.
