Topic: ESP8266-01 WiFiEsp library is slow. (Read 757 times) previous topic - next topic
alessandroAmedei
Nov 10, 2017, 09:03 pm Last Edit: Nov 10, 2017, 09:10 pm by alessandroAmedei
I ve bought a ESP8266-01 module, and I'm using the WiFiEsp library.
I am comunicating with the WiFiEspServer on the 80 port.
Everything works, but when i load the page from it, the tcp packets arrive really slow.
I am using an arduino nano.
Any ideas to make the sending of the packets faster?
Thank you.
I got another problem. It takes a lot of time to disconnect the client at the command "client.stop();" (like 10 seconds) and it stucks the loop of arduino; i even set the closing of the connection in the html header.
Thank you again.
Alessandro Amedei from Florence.
Code: [Select]
#include "WiFiEsp.h"
#include <SoftwareSerial.h>
SoftwareSerial ESP(9, 10); //TX, RX
char ssid[] = "FASTWEB********";            // your network SSID (name)
char pass[] = "***********";        // your network password
WiFiEspServer server(80); //Start the server
int status = WL_IDLE_STATUS;
RingBuffer buf(8);
int rele=12; //!!
int switch_=3;
int microphone=2;
int led=4;
int state=false;
int debug=0; //!!!
void setup () {
   pinMode(microphone,INPUT_PULLUP);
   pinMode(switch_,INPUT_PULLUP);
   pinMode(rele,OUTPUT);
   pinMode(led,4);
   digitalWrite(rele,LOW);
   digitalWrite(led,LOW);
  ESP.begin(9600);
  setupWifi();
int i=0;
void loop () {
switchListener();
hear();
 clientManager();
void switchLight(){
  state=!digitalRead(rele);
  digitalWrite(rele,state);
  debug++; // !!!
void switchListener(){
if(!digitalRead(switch_)){  //!!!!
switchLight();
int pos=0;
unsigned long t=0;
unsigned long t2=0;
void hear(){
  if(!digitalRead(microphone) && pos==0){
   Serial.print("pos=1 ");
   Serial.println(millis());
   digitalWrite(led,HIGH);
   t= millis();
   pos=1;
   delay(10);
   t2=millis();
   if((!digitalRead(microphone)) && pos==1){
         Serial.print("pos=2_NOIN ");
   if(t2-t>400 && t2-t<1000){
    Serial.println("Switch");
   switchLight();
   t=0;
   pos=0;
   t2=0;
  if(t2-t>1000 && pos==1){
    t=0;
    pos=0;
    t2=0;
    Serial.println("reset2");
  void setupWifi(){
     WiFi.init(&ESP);    // initialize ESP module
  // check for the presence of the shield
  if (WiFi.status() == WL_NO_SHIELD) {
    Serial.println("WiFi shield not present");
    // don't continue
    while (true);
  // attempt to connect to WiFi network
  while (status != WL_CONNECTED) {
    Serial.print("Attempting to connect to WPA SSID: ");
    Serial.println(ssid);
    // Connect to WPA/WPA2 network
    status = WiFi.begin(ssid, pass);
  Serial.println("You're connected to the network");
  printWifiStatus();
  // start the web server on port 80
  server.begin();
    void printWifiStatus()
  // print the SSID of the network you're attached to
  Serial.print("SSID: ");
  Serial.println(WiFi.SSID());
  // print your WiFi shield's IP address
  IPAddress ip = WiFi.localIP();
  Serial.print("IP Address: ");
  Serial.println(ip);
  // print where to go in the browser
  Serial.print("To see this page in action, open a browser to http://");
  Serial.println(ip);
void clientManager()
  WiFiEspClient client = server.available();  // listen for incoming clients
  if (client) {                               // if you get a client,
    Serial.println("New client");             // print a message out the serial port
    buf.init();                               // initialize the circular buffer
    while (client.connected()) {              // loop while the client's connected
      if (client.available()) {               // if there's bytes to read from the client,
        char c = client.read();               // read a byte, then
        buf.push(c);
        Serial.print(c);// push it to the ring buffer
        // printing the stream to the serial monitor will slow down
        // the receiving of data from the ESP filling the serial buffer
        //Serial.write(c);
        // you got two newline characters in a row
        // that's the end of the HTTP request, so send a response
        if (buf.endsWith("\r\n\r\n")) {
          sendHttpResponse(client);
        // Check to see if the client request was "GET /H" or "GET /L":
        if (buf.endsWith("GET /H")) {
          Serial.println("Turn led ON");
          state=1;
          digitalWrite(rele, HIGH);
        else if (buf.endsWith("GET /L")) {
          Serial.println("Turn led OFF");
          state=0;
          digitalWrite(rele, LOW);
    // close the connection
    client.stop();
    Serial.println("Client disconnected");
void sendHttpResponse(WiFiEspClient client)
  // HTTP headers always start with a response code (e.g. HTTP/1.1 200 OK)
  // and a content-type so the client knows what's coming, then a blank line:
  client.println(F("HTTP/1.1 200 OK"));
  client.println(F("Content-type:text/html\r\n"
  "Connection: close\r\n"));
  client.println();
  client.println(F("<html><head><style>"));
  client.println(F(".button{"));
  client.println(F("background-color: green; border: none; color: white;"));
  client.println(F("padding: 15px 32px; text-align: center; text-decoration: none;"));
  client.println(F("display: inline-block; font-size: 16px;margin: 4px 2px; cursor: pointer;}"));
  client.println(F("</style></head>"));
  // the content of the HTTP response follows the header:
  client.println(F("<body><table align='center'>"));
  client.println(F("<tr align='center'><td> <h1 style='color:blue; font-style:bold; '>HOMOTION</h1> </td></tr>"));
  client.println(F("<tr align='center'><td> <p style='color:green'>Controllo Luce</p> </td></tr>"));
   if(state)
  client.println(F("<tr align='center'><td> <h2 style='color:green'>Luce ACCESA</h2> </td></tr>"));
     client.println(F("<tr align='center'><td> <h2 style='color:red'>Luce SPENTA</h2> </td></tr>"));
   client.println(F("<tr align='center'><td>"));
   client.println(F("<a href='/H'><button style='width:200px; height:100px; padding: 5px 10px' type='button'>Accendi</button></a>"));
   client.println(F("<a href='/L'><button style='width:200px; height:100px; padding: 5px 10px' type='button'>Spegni</button></a>"));
   client.println(F("</td></tr>"));
   String debug_string= String(debug);
   client.println("<tr align='center'><td><br><br><br> <p style='color:blue;'>Accensioni/Spegnimenti casuali: "+debug_string+" </p> </td></tr>");
    client.println(F("<tr align='center'><td><br><br><br> <p style='color:blue; styel:italic;'>Alessandro Amedei</p></td></tr>"));
   client.println(F("<br>"));
 // client.println("Click <a href=\"/H\">here</a>LightOn<br>");
 // client.println("Click <a href=\"/L\">here</a>LightOff<br>");
  client.println(F("</body></html>"));
  // The HTTP response ends with another blank line:
  client.println();
pert
I don't know about the WiFiEsp library specifically but with similar projects I've found that the use of F() really slows things down because the way the Print class handles it is to send one character at a time, so every character is in its own packet. You might also try to use the fewest number of client.println() statements as possible, since your current code causes many more packets to be send than is necessary.
alessandroAmedei
Thank you. Effectly i used too many client.print() (it's the ServerLed Example).
I decrased the number of them and i also increased the buffer size of Software Serial, it s now more faster! But sometimes it gets stuck the same and i can not understand why.
Thank you for the answer!
Alessandro Amedei.
