Many users need faster decimal print for logging data to SD cards. The big problem with Print is this line
return write(str);
A class derived from Print may have a fast write for strings but it is not uses since Print defines these members
size_t write(const char *str) {
if (str == NULL) return 0;
return write((const uint8_t *)str, strlen(str));
size_t Print::write(const uint8_t *buffer, size_t size)
size_t n = 0;
while (size--) {
n += write(*buffer++);
return n;
So printNumber uses the above write(const char *str) and the string is written character at a time.
I did a test with the new version of print. It is faster but not as much as one would expect.
I timed this loop
for (int i = 0; i < 20000; i++) {
file.println(i);
The result for the old print is:
Time 9.38 sec
File size 128.89 KB
Write 13.74 KB/sec
For the new print with Stimmer's optimization.
Time 6.00 sec
File size 128.89 KB
Write 21.50 KB/sec
For a simple printField() function with no optimized divide that uses SdFat's write(const char*)
Time 2.66 sec
File size 128.89 KB
Write 48.44 KB/sec
So the improvement in Print will not be fully realized as long as printNumber uses Print::write(const char*).
I believe there is a way to fix this in a class derived from Print since size_t Print::write(const char *str) is not pure virtual. Correct me if I am wrong.
I tried your sketch on a Uno with 1.0.5 and get a fast write with SD.h and the new Print. About the same as with the new SdFat. Looks like you don't even need the SdFat improvements at 50 KB/sec.
There is another speed optimization to make when you are using divmod10 to convert a long into base-10 digits: Only the first few digits of a 10-digit number need full 32-bit precision. Once the high byte is 0 you only need 24 bit precision (saves at least 10 cycles), then when the two highest bytes are 0 you only need a 16 bit divmod10 (saves over a microsecond). Once the three highest bytes are 0 the 8-bit divmod10 only takes a microsecond, and for the very last digit you don't need to do a division at all.
The downside is an increase in code size of about 200 bytes. I've attached a modified Print.cpp including all the assembler macros, my profiling indicates it's 0.5us-1.5us faster per digit on average (which adds up to 7us faster for 5-10 digit numbers). I have not fully tested for accuracy yet.
a well implemented trick - trading space for speed -
There are other tricks possible, not investigated though
Consider the fact that the largest uint32_t < 50000 * 10000 * 10000;
with a divmod10000() one could divide the uint32 in 4digit chunks which can be processed by divmod10_asm16
a divmod1000() might be broader usable
another trick would use a divmod100() to extract 2 digits at a time => fit in a byte. => divmod10_asm8() to split it
I have used the ideas here to improve the speed of logging data to SD cards. I wrote functions to print a numerical field to an SD card that are as much as five times faster than the standard Arduino print.
I am now able to log data from four analog pins on an Uno to an SD at 2000 Hz. This is 8000 ADC values per second. This is near the limit since each conversion takes about 110 microseconds.
I wrote a version of analogRead() that sleeps while the ADC conversion occurs. This saves about 90 microseconds of CPU time per conversion.
I have also modified SdFat so it no longer busy waits for flash programming in the SD to complete.
Here are test results for 16-bit unsigned fields and 32-bit float fields.
This test compares the standard print function
with printField. Each test prints 20,000 values.
Test of println(uint16_t)
Time 6.51 sec
File size 128.89 KB
Write 19.80 KB/sec
Test of printField(uint16_t, char)
Time 1.27 sec
File size 128.89 KB
Write 101.33 KB/sec
Test of println(double)
Time 17.17 sec
File size 160.00 KB
Write 9.32 KB/sec
Test of printField(double, char)
Time 3.56 sec
File size 160.00 KB
Write 44.94 KB/sec
Here are the test loops for the writes:
switch(test) {
case 0:
for (uint16_t i = 0; i < N_PRINT; i++) {
file.println(i);
break;
case 1:
file.printField(i, '\n');
break;
case 2:
file.println((double)0.0001*i, 4);
break;
case 3:
file.printField((double)0.0001*i, '\n', 4);
I have attached the implementation of printField().
robtillaart:
think divmod10() should become part of the core seeing these and the above numbers.
I'm planning to release it in the next version of Teensyduino.
Stimmer, is Arduino Print LGPL ok with you? Would you like your name to appear, other than "Stimmer" and link to this forum topic? You deserve credit.... just let me know what should be in the comments?
Ok then. I'll hold off publishing anything until Stimmer replies.
I'm currently working on a Mac-related USB problem, so it's not like there's any hurry. But it would be nice to publish this code to a wider audience, if that's allowed?
Yes that's OK. Consider what I wrote to be in the public domain so anyone can use it under any license. Just put something like "this section of code based on public domain code by Stimmer, see post at forum.arduino.cc/whatever-the-url-is ".
agree these should be standard libs of the core,
but the arduino team wont,
I'm definitely not sure of the latter.
The code is not core lib ready yet. For Arduino-team the portability of core libs is a very important issue. The divmod10() function should be decorated with #ifdefs to select the C (portable to DUE?) or the assembly (328 only?) implementation .
It ought to be pretty simple to surround this code with #ifdefAVR, or perhaps a check for the AVR architecture with multiply? In fact, the Print.cpp I posted has #ifdef checks to use either the original C code, Stimmer's optimization, or your version of the Hackers Delight algorithm. Yes, it requires some careful attention, but this part really isn't very difficult.
Whether the Arduino Team will accept this for the Print.cpp that ships for all Arduino boards is a good question. Historically, they've been pretty uninterested in speed optimizations.
I definitely do plan to publish this in the next version of Teensyduino, likely within the next 6 weeks. Of course, if Coding Badly is satisfied with the licensing? ... Thanks Stimmer! You definitely did the heavy lifting with an amazing optimization!
