I would like to control a bank of six relays with my Arduino Uno. The relays are less than 5 meters from the microcontroller, so I'm hoping I can connect things with some medium length (less than 5 meters) wires. In order to preserve output pins on the Arduino and (slightly) reduce the number of longish wires, I'm considering locating a shift register next to the relays and driving the shift register from moderately far away.
I know how to calculate the voltage drop and if I'm not mistaken it will be negligible.
What I don't know is what effect (if any) the the distributed inductance/capacitance of the wires will have. I suppose this depends on the frequency of the digital signals sent to the shift register. The sample Arduino code for shift registers that I've seen sets the pins high and low without any intervening delay()'s. For 5 meter, unshielded wires (telephone cable, say), will I need to slow down communication with the shift register in order to compensate for slow transitions between 0 and 5 volts on the wires?
Have a look at the ShiftPWM library as there are some instructions there for how to add push-pull line driver to ensure you can drive long signal wires to shift registers adequately.
Thanks for the suggestion. I downloaded to source code for ShiftPWM (from http://www.elcojacobs.com/shiftpwm/ ), but I couldn't locate the discussion of push-pull line drivers. Am I looking in the wrong place?
kmwkmw:
I don't think you'll have much trouble over 5m. At the very worst you'll have to drop the clock rate down from MHz to kHz.
LarryD: I'm using the relays to switch 24 volts AC (thermostat inputs to a radiant floor heat valve controller). I assumed that for AC I needed to use mechanical relays rather than some sort of solid state alternative, but if I'm wrong about that please let me know -- I'll be pleasantly surprised. I'm relatively new to this stuff.
Well, there are Triacs... which have the added advantage of possibly detecting zero-crossings and not switching the load at the AC waveform high points. That doesn't change your control circuitry much, if any, though.
kmwkmw:
Thank you, everyone, for the helpful answers.
