Topic: If value is higher than for given time (Read 2115 times) previous topic - next topic
Robin2
The circuit just needs to detect if the table saw, router or sander is running to turn on the vac.
I think that is the first time you have explained what you are trying to do. It makes everything a great deal clearer. I will look at your code in the morning.
...R
Two or three hours spent thinking and reading documentation solves most programming problems.
Robin2
I have now had time to look at this. In the following version I have made a number of changes - including to the names of some variables. Apart from the  changed names I hope I have marked each change with a comment that begins // R2
I may have misunderstood your project and made a complete mess of the names, but they way I have done makes a lot more sense to me based on my present understanding.
When the logic became clearer it seemed to me necessary to update the variable noLoadTime after turning the vac circuit off. I suspect that that is the principal change needed to stop your flickering.
I have changed some references to millis() so they use currentMillis. That doesn't make any real difference. But there seems little point in creating currentMillis and then not using it. Reading the value from the variable will be marginally faster than calling the function.
Code: [Select]
#include <EmonLib.h>   // Get it here: github.com/openenergymonitor/EmonLib
* MISC SETUP                                                  *
#define DEBUG 1                      // Set to 1 for serial port output
const uint32_t SERIAL_BAUD = 9600;   // Set serial 0 speed
EnergyMonitor checkPower;            // Create an instance
const uint8_t vacCircuitRelay = 8;   // Relay circuit is connected to D8
const uint8_t SENSOR = A3; // ECS1030-L72 is connected to A3
// Define switch pins
const uint8_t pinS[] = {3, 4};                      // Array of used switch pins
uint8_t pinSCount = sizeof(pinS) / sizeof(pinS[0]); // Count used switch pins
// Define unused pins
const uint8_t pin[] = {2, 5, 6, 7, 9, 10, 11, 12, 13}; // Array of unused digital pins
const uint8_t pinA[] = {A0, A1, A2, A4, A5, A6, A7};   // Array of unused analog pins
uint8_t pinCount = sizeof(pin) / sizeof(pin[0]);       // Count unused digital pins
uint8_t pinACount = sizeof(pinA) / sizeof(pinA[0]);    // Count unused analog pins
unsigned long noLoadTime = 0;  // R2 MOVED
unsigned long loadRemoved = 0;
unsigned long turnOnDelay = 3000;
unsigned long turnOffDelay = 3000;
bool vacuumOn = false;
* SETUP                                                       *
    #ifdef DEBUG
     Serial.begin(SERIAL_BAUD); // Initialize serial communications
     while (!Serial) {;}        // Wait for serial port to connect
    #endif // END DEBUG
    for (uint8_t i = 0; i < pinCount; i++) {
     pinMode(pin[i], OUTPUT);    // Set unused digital pins as output
     digitalWrite(pin[i], LOW);  // Set unused digital pins state to low
    for (uint8_t i = 0; i < pinACount; i++) {
     pinMode(pinA[i], OUTPUT);    // Set unused analog pins as output
     digitalWrite(pinA[i], LOW);  // Set unused analog pins state to low
    for (uint8_t i = 0; i < pinSCount; i++) {
     pinMode(pinS[i], INPUT_PULLUP);  // Set switch pins as input and enable internal pull-up resistor
    pinMode(vacCircuitRelay, OUTPUT);     // Set Relay pin (D8) as output
    digitalWrite(vacCircuitRelay, LOW);   // Set Relay to off
    vacuumOn = false;  // R2 NEW
    checkPower.current(SENSOR, 20);  // Sensor input pin (A3) and calibration
* AUTOMATIC LOOP                                              *
void automatic() {
    double Irms = checkPower.calcIrms(1480);   // Calculate Irms only
    if (vacuumOn == false) { // R2 no comment needed
            // R2 check if no appliance is running
        if(Irms < 0.03) {
            noLoadTime = currentMillis;
            // R2 if appliance running for period
        if (currentMillis - noLoadTime >= turnOnDelay) {  // R2 use currentMillis
                                                        // If RMS is higher then 0.03A longer then 3 seconds
            digitalWrite(vacCircuitRelay, HIGH);                 // turn relay on
            vacuumOn = true;
    else  { // R2 if vacuum is ON
        if(Irms < 0.03) {
            loadRemoved = currentMillis;
            // R2 turn off vac after interval
        if ((currentMillis - loadRemoved) >= turnOffDelay) {  // R2 use currentMillis
            vacuumOn = false;
            noLoadTime =  currentMillis; // R2 NEW
    #ifdef DEBUG
        Serial.print(Irms*230.0);  // Apparent power
        Serial.print(" ");
        Serial.println(Irms);      // Irms
        Serial.println(currentMillis);
    #endif // END DEBUG
* MAIN LOOP                                                   *
    uint8_t switchState_1 = digitalRead(3);  // Read the switch value (pin D3)
    uint8_t switchState_2 = digitalRead(4);  // Read the switch value (pin D4)
    if(switchState_1 == LOW) {           // If pin 3 is low
        vacuumOn = true;      // R2 CHANGED
    else if (switchState_2 == LOW) {   // If pin 4 is low
        digitalWrite(vacCircuitRelay, LOW); // R2 NEW
        vacuumOn = false;
        automatic();                       // and run the automatic loop
    else {
        digitalWrite(vacCircuitRelay, LOW);          // Turn relay off
        vacuumOn = false;                 // and reset load detection state
    #ifdef DEBUG
        Serial.println(vacuumOn);      // Irms
    #endif // END DEBUG
...R
MrGlasspoole
Sorry still flickering. Brighter but still :(
Robin2
Are you using the EXACT code in Reply #31? If so please confirm that. If not then post the code you are actually using.
What steps have you taken to try to figure out the problem after studying the code in Reply #31 and my comments? I can't do everything from this distance.
...R
MrGlasspoole
#34
May 19, 2017, 11:55 pm Last Edit: May 20, 2017, 03:20 am by MrGlasspoole
I tried the exact code.
But i found the flicker part:
Code: [Select]
        // digitalWrite(vacCircuitRelay, LOW); // <<<<< if there then FLICKER
        vacuumOn = false;
Sure automatic turns on and this part turns off at the same time.
Will test the rest now...
EDIT
Ok i changed some things.
I removed the boolean's and did connect the relay output pin to another pin (input) so i have feedback.
Everything works expect one thing:
If the sensor detects load and i remove pin 4 from ground (switchState_2) the relay goes off as it should.
But if i reconnect pin 4 to ground (low) the relay turns on instantaneously. The 3 seconds delay is missing.
I tried resetting "noLoadTime" with
Code: [Select]
noLoadTime = 0;
in all the places i can thing of but nothing works.
Printing "noLoadTime" shows, the time is running from the point when automatic stopped.
Code: [Select]
* MISC SETUP                                                  *
const uint8_t vacRelay = 8;        // Relay circuit is connected to D8
const uint8_t pin[] = {2, 5, 6, 9, 10, 11, 12, 13};  // Array of unused digital pins
* SETUP                                                       *
    #ifdef DEBUG
    #endif // END DEBUG
    pinMode(vacRelay, OUTPUT);   // Set Relay pin (D8) as output
    digitalWrite(vacRelay, LOW); // Set Relay to off
* AUTOMATIC LOOP                                              *
unsigned long loadTime = 0;
void automatic() {
  uint8_t feedBack = digitalRead(7);       // Read feedback (pin D7)
  if(feedBack == LOW) { // Relay is off < feedback
    if(Irms < 0.03) {
    if ((currentMillis - noLoadTime) >= turnOnDelay) { // If RMS is higher then 0.03A longer then 3 seconds
      digitalWrite(vacRelay, HIGH);                    // turn relay on
  } else { // Relay is on < feedback
    if(Irms > 0.03) {
      loadTime = currentMillis;
    if ((currentMillis - loadTime) >= turnOffDelay) { // If RMS is lower then 0.03A longer then 3 seconds
      digitalWrite(vacRelay, LOW);                    // turn relay on
  #ifdef DEBUG
    Serial.print(" ");
    Serial.println(noLoadTime);
  #endif // END DEBUG
* MAIN LOOP                                                   *
    #ifdef DEBUG
      Serial.println("Manual");
    #endif // END DEBUG
  } else if (switchState_2 == LOW) { // If pin 4 is low
    automatic();                     // run the automatic loop
    #ifdef DEBUG
      Serial.println("Automatic");
    #endif // END DEBUG
    digitalWrite(vacRelay, LOW); // Turn relay off
    #ifdef DEBUG
      Serial.println("Off");
    #endif // END DEBUG
Robin2
#35
May 20, 2017, 08:36 am Last Edit: May 20, 2017, 08:38 am by Robin2
Code: [Select]
        vacuumOn = false;
Your IF logic is very confused. I had not studied that because I assumed the problem was elsewhere. What sort of switches are connected to pis 3 and 4? This is another example where meaningful variable names (rather than switchState) would make the logic much clearer and might have avoided the problem in the first place.
I suspect if you sort that out the version of automatic() that I suggested will work.
I have no idea why you thought that removing the booleans would help. That sounds like the scatter-gun approach to debugging - Do something! Anything!
...R
MrGlasspoole
Its a on/off/on switch.
Sure that was the first thing i tested (removing that part in switchState_2) in your code - but it does not work.
The thing with booleans is that they don't really tell you the real state and that is something i don't understand in most stuff others are doing.
Why does nobody look for the state of a pin with another pin (feedback - if something is on/off)?
With the words from somebody else:
Quote
Reading the internal register will always return for you what the controller is trying to put on the pin, not the actual pin value. If you are doing this to validate that the pin is really high, this will not confirm it to you, because maybe there is a short circuit on the high pin from the external circuit, the best way is to create a feedback through another pin; configure another pin as input, and connect the output pin to the new input pin, and read its value.
But what i really don't get is why "noLoadTime = 0" does not work.
MrGlasspoole
GOT IT WORKING
No need for boolean or feedback and i don't know why it took me so long.
Now if i look at it it's not complicated.
Code: [Select]
* MISC SETUP                                                  *
* SETUP                                                       *
    #ifdef DEBUG
    #endif // END DEBUG
* AUTOMATIC LOOP                                              *
float Irms;
void automatic() {
  if(Irms < 0.03) {
  if(Irms > 0.03) {
    digitalWrite(vacRelay, LOW);                    // turn relay off
* MAIN LOOP                                                   *
  uint8_t switchPositionOn = digitalRead(3);   // Read the switch value (pin D3)
  uint8_t switchPositionAuto = digitalRead(4); // Read the switch value (pin D4)
  if(switchPositionOn == LOW) {   // If pin 3 is low
    #ifdef DEBUG
      Serial.println("Mode: On");
    #endif // END DEBUG
  } else if (switchPositionAuto == LOW) { // If pin 4 is low
    #ifdef DEBUG
      Serial.println("Mode: Automatic");
    #endif // END DEBUG
    noLoadTime = millis();       // and set noLoadTime
    #ifdef DEBUG
      Serial.println("Mode: Off");
    #endif // END DEBUG
  #ifdef DEBUG
    Serial.print(" ");
  #endif // END DEBUG
Robin2
Glad to hear it is working. Perhaps using meaningful variable names helped?
The comment here is incorrect
Code: [Select]
It should be // if pin3 is HIGH and pin 4 is LOW
It would be even better if it said // if ON switch is OFF (high) and AUTO switch is ON (low)
And that suggests to me that it would be more meaningful to use constantVacSwitch rather than switchPositionOn and autoVacSwitch instead of switchPositionAuto.
Using switchPositionOn and switchPositionAuto conveys the notion of a single multi-way switch - for example a rotary switch.
...R
