I have recently resurrected my 3 x 3 x 3 LED cube to write some code based on Hassan Ali's code at -
http://www.abrushfx.com/Arduino/ledcube3.html
The posted code
//Code based on ABrushFX Cube code at
//http://www.abrushfx.com/Arduino/ledcube3.html
//Array for three LED levels
int ledRow[] ={ 11, 12, 13 };
// Array for nine LED's in each level
int ledCol[]= { 1, 2, 3, 4, 5, 6, 7, 8, 9 };
int timer= 500;
void setup() // Sets up all pins as Outputs
for( int i = 0; i < 3; i++)
pinMode( ledRow[i],OUTPUT);
for(int j = 0; j < 9; j++)
pinMode( ledCol[j],OUTPUT);
// Sets an LED HIGH based on Row and Column position
void onLED(int ledRow, int ledCol){
digitalWrite(ledRow, HIGH);
digitalWrite(ledCol, HIGH);
// Sets an LED LOW based on Row and Column position
void offLED(int ledRow, int ledCol)
digitalWrite(ledRow, LOW);
digitalWrite(ledCol, LOW);
void topRowPaneFigure8()
for(int y = 0; y < 3; y++) // light LED's 1 - 3 on/off on top level
onLED(ledRow[0],ledCol[y]); // 7 8 9
delay(timer); // 4 5 6
offLED(ledRow[0],ledCol[y]); // 1 2 3
for(int y = 5; y > 2; y--) // light LED's 6 - 4 on/off on top level
delay(timer);
for(int y = 6; y < 9; y++) // light LED's 7 - 9 on/off on top level
delay(timer);
delay(timer);
void centreRowPaneFigure8()
for(int y = 0; y < 3; y++) // light LED's 1 - 3 on/off on centre level
onLED(ledRow[1],ledCol[y]); // 7 8 9
offLED(ledRow[1],ledCol[y]); // 1 2 3
for(int y = 5; y > 2; y--) // light LED's 6 - 4 on/off on centre level
delay(timer);
for(int y = 6; y < 9; y++) // light LED's 7 - 9 on/off on centre level
delay(timer);
delay(timer);
void bottomRowPaneFigure8()
for(int y = 0; y < 3; y++) // light LED's 1 - 3 on/off on bottom level
onLED(ledRow[2],ledCol[y]); // 7 8 9
offLED(ledRow[2],ledCol[y]); // 1 2 3
for(int y = 5; y > 2; y--) // light LED's 6 - 4 on/off on bottom level
delay(timer);
for(int y = 6; y < 9; y++) // light LED's 7 - 9 on/off on bottom level
delay(timer);
delay(timer);
topRowPaneFigure8();
centreRowPaneFigure8();
bottomRowPaneFigure8();
includes three functions (one for each level of the cube) that light the LED's in a figure eight configuration as detailed in the short attached txt document. The code operates as required but in the interest of building on my limited code writing skills 8) I am wondering how to consolidate the three functions
topRowPaneFigure8
into one function. Where I am having trouble is the fact that the only difference between the three functions is the (ledRow[0] section in
delay(timer);
which is 0, 1 and 2 in the three functions corresponding to the three levels. I assume that the solution is to use a for loop, but as the " ledRow[ ] "appears unchanged four times in each function, I am somewhat perplexed. I hope that I have explained myself adequately and thanks for reading Pedro.
Cube doc.txt (399 Bytes)
