GPS parsing problem
In what form do you want the data and what do you plan to do with it? As a simple parsing start, load the below code into the arduino, copy the sample string you posted, paste the string in the serial monitor (ctrl-v), then send it to the arduino.
//zoomkat 3-5-12 simple delimited ',' string parce
//from serial port input (via serial monitor)
//and print result out serial port
// CR/LF could also be a delimiter
String readString;
  Serial.println("serial delimit test 1.0"); // so I can keep track of what is loaded
  //expect a string like wer,qwe rty,123 456,hyre kjhg,
  //or like hello world,who are you?,bye!,
  if (Serial.available())  {
    char c = Serial.read();  //gets one byte from serial buffer
    if (c == ',') {
      //do stuff
      Serial.println(readString); //prints string to serial port out
      readString=""; //clears variable for new input
    else {
      readString += c; //makes the string readString
This PDF describes the format of the GPSACP sentence:
http://www.gatetel.com/PDF/GPSgprs/GPRS_Protocol_description.pdf
Pete
Hi all,
Sorry for the delay in getting back to this... after studying all your input I've been trying different solutions and have come up with one that seems quite elegant at first glance... Trouble is once incorporated into my complete code it doesn't work. Everything appears fine but in the "real world" situation the variables areeither not being populated, or the results are not being printed to the serial bus. For bothe the simulator and serial monitor run I manually enter the GPS response ($GPSACP: 234423.31,2728.3913S,15302.3418E,1.00,38.81,3,0,00,0.01,0.02,180313,07) into the serial monitor input and the correctly formatted output appears on the output.
The Parsing/printing code which works both on an arduino using the serial monitor, and in the simulator is here.
#include <avr/pgmspace.h>
  #define maxLength 80                                 // Set incoming string max length
  String readString;
  String Lat;
  String Lon;
  String COG;
  String Speed;
  int ComCount = 0;
  delay (5000);
  Serial.println("GPS Test");
  Serial.println ("AT$GPSACP");
void loop()  {
    if (c ==':')  {
      readString="";
    //delay(1000);
    if (c == ',') {
      ComCount++;
      if (ComCount == 1)  {
    //delay(1000);
      if (ComCount == 2)  {
        Lat = readString;
    //delay(1000);
      if (ComCount == 3)  {
        Lon = readString;
    //delay(1000);
      if (ComCount == 4)  {
    //delay(1000);
      if (ComCount == 5)  {
    //delay(1000);
      if (ComCount == 6)  {
        /*if (c += '1')  {
         Fix = 0;
         else Fix = 1;
    //delay(1000);
      if (ComCount == 7)  {
       COG = readString;
    //delay(1000);
      if (ComCount == 8)  {
    //delay(1000);
      if (ComCount == 9)  {
        Speed = readString;
    //delay(1000);
      if (ComCount == 10)  {
       Serial.println ("Lat " + Lat);
   Serial.println ("Lon " + Lon);
   Serial.println ("Speed " + Speed + " Knots");
   Serial.println ("COG " + COG);
        ComCount = 0;
    else {
The subroutines I'm actually calling are here... (first section calls the GPS subroutine then should print the data stored in the appropriate variables???)
if (inString.indexOf("Locate") >=0) {                        // look for a command in the string
      inString = "";                                         // Clear the string
      GPS();
      Serial.println ("AT+CMGS=0430340511");             //Send SMS to this number
      showString(PSTR("Current Location, Course, & Speed\r\n"));
      Serial.println("");
      Serial.println ("\x1A");                           //Delay to accomodate message send.
      delay(2000);                                       //Delay to accomodate message send.
void GPS()  {
  delay(2000);
    if (c ==':')  {
      readString="";
      ComCount = 0;
    if (c == ',') {
      ComCount++;
        Lat = readString;
        Lon = readString;
        COG = readString;
        Speed = readString;
        ComCount = 0;
    else {
The delays are simply for stability. The GPS/3G module responses are fairly quick but I want reliability over absolute speed.
It seems to me that from my testing with the first block of code I've included that perhaps the issue is with the response from the GPS not actually being available on the serial bus??? Other comands that come in via text message are recognised, and in fact the entire sequence is called in this manner. I can also confirm that watching the serial data output from both the arduino and the GPS/3G module the correct calls and responses are present.
Cheers
Greg.
#7 below might help alot.
http://arduino.cc/forum/index.php/topic,148850.0.html
Thanks for the tip... modified post as suggested.
Cheers
Greg
There is the TinyGPS library that handles parsing GPS data without using crutches (otherwise known as the String class). Why not use it?
Or, at least refer to it to see how parsing is done.
Thanks PaulS,
This was discussed at the beginning of the topic. TinyGPS doesn't recognise or handle GPSACP strings natively and I figured it was just as easy (and far more educational) to attack the problem head on.
Cheers
Greg.
But, at least the TinyGPS library provides a skeleton. Why not add the ability to parse GPSACP sentences to that library?
All those Strings coming and going are trashing the limited memory that you have.
Thanks PaulS,
So you think the issue could be related to memory?... OK, I'll relook at TinyGPS and see if I can figure out how to add a sentence type to it...
Cheers
Greg
O.K...., Still pretty new to all this...
Below is my modified version of Tiny GPS... Not sure if it's going to work as I've never really dealt with libraries before but I'm happy to give it a go! Any suggestions would be greatly appreciated...
Cheers
Greg.
  TinyGPS - a small GPS library for Arduino providing basic NMEA parsing
  Copyright (C) 2008-9 Mikal Hart
  All rights reserved.
  Satellite Count Mod - by Brett Hagman
  http://www.roguerobotics.com/
  This library is free software; you can redistribute it and/or
  modify it under the terms of the GNU Lesser General Public
  License as published by the Free Software Foundation; either
  version 2.1 of the License, or (at your option) any later version.
  This library is distributed in the hope that it will be useful,
  but WITHOUT ANY WARRANTY; without even the implied warranty of
  MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the GNU
  Lesser General Public License for more details.
  You should have received a copy of the GNU Lesser General Public
  License along with this library; if not, write to the Free Software
  Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA  02110-1301  USA
#include "WProgram.h"
#include "TinyGPS.h"
#define _GPRMC_TERM   "GPRMC"
#define _GPGGA_TERM   "GPGGA"
#define _GPGSV_TERM   "GPGSV"
#define _GPGSA_TERM   "GPGSA"
#define _GPSACP_TERM   "GPSACP"
TinyGPS::TinyGPS()
:  _time(GPS_INVALID_TIME)
,  _date(GPS_INVALID_DATE)
,  _latitude(GPS_INVALID_ANGLE)
,  _longitude(GPS_INVALID_ANGLE)
,  _altitude(GPS_INVALID_ALTITUDE)
,  _speed(GPS_INVALID_SPEED)
,  _course(GPS_INVALID_ANGLE)
,  _satsinview(0)
,  _satsused(0)
,  _fixtype(GPS_FIX_NO_FIX)
,  _last_time_fix(GPS_INVALID_FIX_TIME)
,  _last_position_fix(GPS_INVALID_FIX_TIME)
,  _parity(0)
,  _is_checksum_term(false)
,  _sentence_type(_GPS_SENTENCE_OTHER)
,  _term_number(0)
,  _term_offset(0)
#ifndef _GPS_NO_STATS
,  _encoded_characters(0)
,  _good_sentences(0)
,  _failed_checksum(0)
#endif
  _term[0] = '\0';
// public methods
bool TinyGPS::encode(char c)
  bool valid_sentence = false;
  ++_encoded_characters;
  switch(c)
  case ',': // term terminators
    _parity ^= c;
  case '\r':
  case '\n':
  case '*':
    if (_term_offset < sizeof(_term))
      _term[_term_offset] = 0;
      valid_sentence = term_complete();
    ++_term_number;
    _term_offset = 0;
    _is_checksum_term = c == '*';
    return valid_sentence;
  case '
: // sentence begin
    _term_number = _term_offset = 0;
    _parity = 0;
    _sentence_type = _GPS_SENTENCE_OTHER;
    _is_checksum_term = false;
// ordinary characters
  if (_term_offset < sizeof(_term) - 1)
    _term[_term_offset++] = c;
  if (!_is_checksum_term)
    _parity ^= c;
void TinyGPS::stats(unsigned long *chars, unsigned short *sentences, unsigned short *failed_cs)
  if (chars) *chars = _encoded_characters;
  if (sentences) *sentences = _good_sentences;
  if (failed_cs) *failed_cs = _failed_checksum;
#endif
// internal utilities
int TinyGPS::from_hex(char a)
  if (a >= 'A' && a <= 'F')
    return a - 'A' + 10;
  else if (a >= 'a' && a <= 'f')
    return a - 'a' + 10;
    return a - '0';
unsigned long TinyGPS::parse_decimal()
  char *p = _term;
  bool isneg = *p == '-';
  if (isneg) ++p;
  unsigned long ret = 100UL * gpsatol(p);
  while (gpsisdigit(*p)) ++p;
  if (*p == '.')
    if (gpsisdigit(p[1]))
      ret += 10 * (p[1] - '0');
      if (gpsisdigit(p[2]))
        ret += p[2] - '0';
  return isneg ? -ret : ret;
unsigned long TinyGPS::parse_degrees()
  char *p;
  unsigned long left = gpsatol(_term);
  unsigned long tenk_minutes = (left % 100UL) * 10000UL;
  for (p=_term; gpsisdigit(*p); ++p);
  if (p == '.')
    unsigned long mult = 1000;
    while (gpsisdigit(
++p))
      tenk_minutes += mult * (*p - '0');
      mult /= 10;
  return (left / 100) * 100000 + tenk_minutes / 6;
// Processes a just-completed term
// Returns true if new sentence has just passed checksum test and is validated
bool TinyGPS::term_complete()
  if (_is_checksum_term)
    byte checksum = 16 * from_hex(_term[0]) + from_hex(_term[1]);
    if (checksum == _parity)
      ++_good_sentences;
#endif
      _last_time_fix = _new_time_fix;
      _last_position_fix = _new_position_fix;
switch(_sentence_type)
        case _GPS_SENTENCE_GPRMC:
          _time      = _new_time;
          _date      = _new_date;
          _latitude  = _new_latitude;
          _longitude = _new_longitude;
          _speed    = _new_speed;
          _course    = _new_course;
          break;
        case _GPS_SENTENCE_GPGGA:
          _altitude  = _new_altitude;
          _time      = _new_time;
          break;
        case _GPS_SENTENCE_GPGSV:
          _satsinview = _new_satsinview;
          break;
        case _GPS_SENTENCE_GPGSA:
          _satsused = _new_satsused;
          _fixtype = _new_fixtype;
          break;
  case _GPS_SENTENCE_GPSACP:
          _time      = _new_time;
          _date      = _new_date;
          break;
      return true;
      ++_failed_checksum;
#endif
    return false;
// the first term determines the sentence type
  if (_term_number == 0)
    if (!gpsstrcmp(_term, _GPRMC_TERM))
      _sentence_type = _GPS_SENTENCE_GPRMC;
    else if (!gpsstrcmp(_term, _GPGGA_TERM))
      _sentence_type = _GPS_SENTENCE_GPGGA;
    else if (!gpsstrcmp(_term, _GPGSV_TERM))
      _sentence_type = _GPS_SENTENCE_GPGSV;
    else if (!gpsstrcmp(_term, _GPGSA_TERM))
      _sentence_type = _GPS_SENTENCE_GPGSA;
      _new_satsused = 0;
else if (!gpsstrcmp(_term, _GPSACP_TERM))
      _sentence_type = _GPS_SENTENCE_GPSACP;
    return false;
if (_sentence_type == _GPS_SENTENCE_GPGSV)
    if (_term_number == 3 && _term[0])
      // we've got our number of sats
      // NOTE: we will more than likely hit this a few times in a row, because
      // there are usually multiple GPGSV sentences to describe all of the sats
      _new_satsinview = (unsigned char) gpsatol(_term);
  else if (_sentence_type == _GPS_SENTENCE_GPGSA)
    if (_term_number == 2 && _term[0])  // Fix type
      _new_fixtype = (unsigned char) gpsatol(_term);
    else if (_term_number >= 3 && _term_number <= 14 && _term[0]) // Count our sats used
      _new_satsused++;
//    if (_term_number == 15)  // PDOP
//    if (_term_number == 16)  // HDOP
//    if (_term_number == 17)  // VDOP
  else if (_sentence_type != _GPS_SENTENCE_OTHER && _term[0])
    switch((_sentence_type == _GPS_SENTENCE_GPGGA ? 200 : 100) + _term_number)
      case 101: // Time in both sentences
      case 201:
        _new_time = parse_decimal();
        _new_time_fix = millis();
        break;
      case 103: // Latitude
      case 202:
        _new_latitude = parse_degrees();
        _new_position_fix = millis();
        break;
      case 104: // N/S
      case 203:
        if (_term[0] == 'S')
          _new_latitude = -_new_latitude;
        break;
      case 105: // Longitude
      case 204:
        _new_longitude = parse_degrees();
        break;
      case 106: // E/W
      case 205:
        if (_term[0] == 'W')
          _new_longitude = -_new_longitude;
        break;
      case 107: // Speed (GPRMC)
        _new_speed = parse_decimal();
        break;
      case 108: // Course (GPRMC)
        _new_course = parse_decimal();
        break;
      case 109: // Date (GPRMC)
        _new_date = gpsatol(_term);
        break;
      case 209: // Altitude (GPGGA)
        _new_altitude = parse_decimal();
        break;
return false;
long TinyGPS::gpsatol(const char *str)
  long ret = 0;
  while (gpsisdigit(*str))
    ret = 10 * ret + *str++ - '0';
  return ret;
int TinyGPS::gpsstrcmp(const char *str1, const char *str2)
  while (*str1 && *str1 == *str2)
    ++str1, ++str2;
  return *str1;
You need to be aware that GPS doesn't work indoors, and most GPS devices will output NMEA strings with 10 or 15 commas
and no values between them.
You need to firstly capture the actual output text from the GPS device and echo it to your computer serial monitor to
see what it looks like, and make sure it is the same as what those GPSAPC strings you are expecting, look like.
Depends which kind of building you are in and which GPS you are using. My Adafruit Ultimate GPS and Garmin GPSMAP 76Csx both lock on to several satellites on the main floor of my house but if I go downstairs the Adafruit maintains lock but the Garmin drops out. The Adafruit usually locks when I'm out and about, in and out of stores, whereas the Garmin often drops out when I'm in a store. I presume the Adafruit has a more recent/better GPS unit.
Pete
michinyon,
Thanks for the input but this is a definately a programming issue. I am very familiar with GPS idiosynchracies and short comings. The string included in my post is the actual output from the GPS device being used. I have 2 terminal windows monitoring both the TX and RX lines of the Arduino and what I see is the command (recieved as a text message) appear on the RX line, the Arduino responds with the AT$GPSACP request to the GPS, The GPS then outputs the GPSACP sentence to the RX line of the arduino, and the arduino does not appear to "see" it.
CHeers
Greg.
zoomkat:
Serial.println("");
Serial.println("GPS Test Example Sketch");
Serial.println("");?
it may sound dumb but I cannot understand line 1 & 3, what will be printed on serial monitor if I write " Serial.println("");"
There is nothing in-between the ""
is it for newline or carriage return??? I suppose Serial.println(); function already has newline or carriage return inbuilt. Kindly correct me if my knowing is wrong.
Hi NightCrawler... yes, those 2 lines just print blank lines to make reading the data easier when it's amongst other text on screen...
Cheers
Greg.
Thanks for your response greg.
Hey guys... Any further assistance? I haven't been able to sort this one out yet...
Cheers
Greg
And we haven't been able to see your serial output.
ask and you shall recieve...
I'll break it down line by line so you can see the order more easily. I've "X'd" out my phone number but don't take that personally...
Arduino RX line:-
+CMT: "+61430xxxxxx","","13/03/21,17:24:28+40"     [sub]incoming message origin date and time[/sub]
Locate      [sub]incoming command[/sub]
$GPSACP: 072449.000,2728.3193S,15302.3512E,6.75,104.0,3,097.58,0.00,0.00,210313,03    [sub]GPS response to command[/sub]
OK
+CMGS: 221
OK
AT$GPSACP          [sub]Text request in response to "Locate" command[/sub]
AT+CMGS=0430xxxxxx        [sub]number to send text response to[/sub]
Current Location, Course, & Speed       [sub]actual text output sent to my phone[/sub]
Lat
Lon
COG
Speed  Knots
Hope this is clear and helpful.
hmmm... preview didn't work and that's not clear... take 2!
incoming text message (arduino serial RX)
Locate
Arduino output to GPS (arduino serial TX)
AT$GPSACP
GPS response to request (arduino RX line)
arduino output text and send command(arduino TX line)
AT+CMGS=0430xxxxxx
Lat
Lon
COG
Speed Knots
