Thanks for the answer. When I plug the DC motor to 5v and GND, it works.
The circuit is given in P3 (dc motor without capasitor). When I make it, it does not spin
THe code is;
int motorPin = 9; // define the pin the motor is connected to
// (if you use pin 9,10,11 or 3you can also control speed)
pinMode(motorPin, OUTPUT);
void loop() // run over and over again
motorOnThenOff();
//motorOnThenOffWithSpeed();
//motorAcceleration();
void motorOnThenOff(){
int onTime = 2500; //the number of milliseconds for the motor to turn on for
int offTime = 1000; //the number of milliseconds for the motor to turn off for
digitalWrite(motorPin, HIGH); // turns the motor On
delay(onTime); // waits for onTime milliseconds
digitalWrite(motorPin, LOW); // turns the motor Off
delay(offTime); // waits for offTime milliseconds
void motorOnThenOffWithSpeed(){
int onSpeed = 200; // a number between 0 (stopped) and 255 (full speed)
int offSpeed = 50; // a number between 0 (stopped) and 255 (full speed)
analogWrite(motorPin, onSpeed); // turns the motor On
analogWrite(motorPin, offSpeed); // turns the motor Off
void motorAcceleration(){
int delayTime = 50; //milliseconds between each speed step
//Accelerates the motor
for(int i = 0; i < 256; i++){ //goes through each speed from 0 to 255
analogWrite(motorPin, i); //sets the new speed
delay(delayTime); // waits for delayTime milliseconds
//Decelerates the motor
for(int i = 255; i >= 0; i--){ //goes through each speed from 255 to 0
