my first arduino robot
i have a chasis, 2 hc sr 04 sensor and uno rev3 so i thought to start coding
i edited this code for obstacle avoidance
#define trigPin 13
#define echoPin 12
#define TIMEOUT 40000 // 40ms timeout (the HC-sr04 has 38 ms timeout)
Serial.begin (19200);
pinMode(trigPin, OUTPUT);
pinMode(echoPin, INPUT);
digitalWrite(trigPin, LOW); // Ensure triger is starting with low befre any pulse
delayMicroseconds(20); // Delay before first pulse
long duration, distance;
digitalWrite(trigPin, HIGH); // Start the High Pulse
delayMicroseconds(10); // Delay 10 micros
digitalWrite(trigPin, LOW); // End the Pulse
duration = pulseIn(echoPin, HIGH, TIMEOUT);
distance = (duration/2) / 29.1;
if (distance >= 400 || distance <= 0)
Serial.println("Out of range");
Serial.print(distance);
Serial.println(" cm");
delay(50);
into this
//my code
#define ta 13   //trig pin of A ultrasonic sensor
#define ea 12   //eco pin of A ultrasonic sensor
#define tb 11    //trig pin of Bultrasonic sensor
#define eb 10   //trig pin of B ultrasonic sensor
#define lp 9  // pin to l293 to control left motor
#define ln 8  //pin to l293 to control left motor
#define rp 7  //pin to l293 to control rightmotor
#define rn 6  //pin to l293 to control right motor
pinMode(lp, OUTPUT);
pinMode(ln, OUTPUT);
pinMode(rp, OUTPUT);
pinMode(rn, OUTPUT);
pinMode(ta, OUTPUT);
pinMode(ea, INPUT);
pinMode(tb, OUTPUT);
pinMode(eb, INPUT);
digitalWrite(ta, LOW);    // Ensure triger is starting with low before any pulse
digitalWrite(tb, LOW);
long dua, da,dub,db;    // dua duration of A sensor// da distance by A sensor// in the same way dub//db
digitalWrite(ta, HIGH); // Start the a  High Pulse
digitalWrite(ta, LOW);    // End the Pulse
dua = pulseIn(ea, HIGH, TIMEOUT);
da = (dua/2) / 29.1;
digitalWrite(tb, HIGH); // Start the b High Pulse
digitalWrite(tb, LOW); // End the Pulse
dub = pulseIn(eb, HIGH, TIMEOUT);
db = (dub/2) / 29.1;
if ((da >=10) && (db >=10))
digitalWrite(lp, HIGH);
digitalWrite(ln, LOW);  \\ turning right concidering obstacle in left sensor A with in 10 cm
digitalWrite(rp, HIGH);
digitalWrite(rn, LOW);
if ((da <=10) && (db >=10))
digitalWrite(rn, HIGH); //turning left concidering obstacle in left sensor A with in 10 cm
digitalWrite(rp, LOW);
if ((db <=10)&& (da >=10))
digitalWrite(ln, HIGH);
digitalWrite(lp, LOW);
if ((da <=10) && (db <=10))
digitalWrite(ln, LOW); // turning right concidering obstacle in both A and B sensor  with in 10 cm
delay(7000); // giving some delay thinking that robot will turn enough from the obstacle
digitalWrite(ln, LOW);// ten left turn to robot to travel stright always
delay(50);
instead of testing this with real robot i planned for a pre check using serial monitor to print direction of robot travelling(replaced the motor block by print statment)
code below
#define eb 10   //trig pin of B ultrasonic sensor/trig pin of A ultrasonic sensor
.#define TIMEOUT 40000 // 40ms timeout (the HC-sr04 has 38 ms timeout)
pinMode(ea, INPUT);
pinMode(eb, INPUT);
delayMicroseconds(20);// Delay before first pulse
long dua, da, dub, db;  // dua duration of A sensor// da distance by A sensor// in the same way dub//db
if ((da >=10)&& (db >=10 ))
Serial.println(" go straight");
if ((da <=10)&&(db >=10))
Serial.println(" right turn");
if ((db <=10)&&(da >=10))
Serial.println("left turn ");
delay(50000);
Serial.println(" left turn ");
delay(50);
then i tested the above code with only two sensor...... i left both sensor unintreuptted so o/p should be printing only "go stright" statment but the output is mixed with "right turn" and "left turn" statment i dont no why...
help me to fix this and i like to go for pwm speed control(for that i have only l293 not arduino motor sheild ) so direct me, having lots of idea about add on like bluethoot contol using android app and add navigation capability
put all your code in the "Code" tags (Edit your post, highlight the posted code and press the "#" button near the text formatting buttons). It might also help make it readable if you format the code with indentations.
DM.
ya i edited it thank u
vikirobot:
delay(50000);
delay(50);
It is better to take the average of atleast 5 values to make result more sophisticated.
this time print the values of da, db to check the most occuring value when there is no interruption on both sensor.8)
cheers
