Just seen Leo's code over at http://arduino.cc/forum/index.php/topic,104247.0.html. Added in Flx lines for the altitude and we have -
#include <Wire.h>
#define ADDRESS 0x76 //0x77
uint32_t D1 = 0;
uint32_t D2 = 0;
int64_t dT = 0;
int32_t TEMP = 0;
int64_t OFF = 0;
int64_t SENS = 0;
int32_t P = 0;
uint16_t C[7];
float Temperature;
float Pressure;
const float sea_press = 1013.25;
// Disable internal pullups, 10Kohms are on the breakout
PORTC |= (1 << 4);
PORTC |= (1 << 5);
Wire.begin();
Serial.begin(9600); //9600 changed 'cos of timing?
delay(100);
initial(ADDRESS);
D1 = getVal(ADDRESS, 0x48); // Pressure raw
D2 = getVal(ADDRESS, 0x58);// Temperature raw
dT = D2 - ((uint32_t)C[5] << 8);
OFF = ((int64_t)C[2] << 16) + ((dT * C[4]) >> 7);
SENS = ((int32_t)C[1] << 15) + ((dT * C[3]) >> 8);
TEMP = (int64_t)dT * (int64_t)C[6] / 8388608 + 2000;
if(TEMP < 2000) // if temperature lower than 20 Celsius
int32_t T1 = 0;
int64_t OFF1 = 0;
int64_t SENS1 = 0;
T1 = pow(dT, 2) / 2147483648;
OFF1 = 5 * pow((TEMP - 2000), 2) / 2;
SENS1 = 5 * pow((TEMP - 2000), 2) / 4;
if(TEMP < -1500) // if temperature lower than -15 Celsius
OFF1 = OFF1 + 7 * pow((TEMP + 1500), 2);
SENS1 = SENS1 + 11 * pow((TEMP + 1500), 2) / 2;
TEMP -= T1;
OFF -= OFF1;
SENS -= SENS1;
Temperature = (float)TEMP / 100;
P = ((int64_t)D1 * SENS / 2097152 - OFF) / 32768;
Pressure = (float)P / 100;
Serial.print(" Actual TEMP= ");
Serial.print(Temperature);
Serial.print(" Actual PRESSURE= ");
Serial.print(Pressure);
Serial.println();
Serial.println();
Serial.print(" Actual ALTITUDE= ");
Serial.print(getAltitude(Pressure, Temperature));
Serial.println("m");
Serial.println();
Serial.print(" RAW Temp D2= ");
Serial.print(D2);
Serial.print(" RAW Pressure D1= ");
Serial.println(D1);
Serial.println();
// Serial.print(" dT= ");
// Serial.println(dT); can't print int64_t size values
Serial.println();
Serial.print(" C1 = ");
Serial.println(C[1]);
Serial.print(" C2 = ");
Serial.println(C[2]);
Serial.print(" C3 = ");
Serial.println(C[3]);
Serial.print(" C4 = ");
Serial.println(C[4]);
Serial.print(" C5 = ");
Serial.println(C[5]);
Serial.print(" C6 = ");
Serial.println(C[6]);
// Serial.print(" C7 = ");
// Serial.println(C[7]);
Serial.println();
float getAltitude(float Pressure, float Temperature) {
return ((pow((sea_press / Pressure), 1/5.257) - 1.0) * (Temperature + 273.15)) / 0.0065;
long getVal(int address, byte code)
unsigned long ret = 0;
Wire.beginTransmission(address);
Wire.write(code);
Wire.endTransmission();
delay(10);
// start read sequence
Wire.write((byte) 0x00);
Wire.requestFrom(address, (int)3);
if (Wire.available() >= 3)
ret = Wire.read() * (unsigned long)65536 + Wire.read() * (unsigned long)256 + Wire.read();
else {
ret = -1;
return ret;
void initial(uint8_t address)
Serial.println();
Serial.println("PROM COEFFICIENTS ivan");
Wire.write(0x1E); // reset
delay(10);
for (int i=0; i<6 ; i++) {
Wire.write(0xA2 + (i * 2));
Wire.requestFrom(address, (uint8_t) 6);
delay(1);
if(Wire.available())
C[i+1] = Wire.read() << 8 | Wire.read();
else {
Serial.println("Error reading PROM 1"); // error reading the PROM or communicating with the device
Serial.println(C[i+1]);
Serial.println();
I hastily ran the code and the results seem to be all correct now. Excellent.
Best
