So I've tried converting the data in the following code both using casting and conversion methods.
i.e. int(variable) and (int) Variable
The offending code has been isolated to this portion, which i stripped down from the rest of the project:
double total = 0;
int y = 0;
for(int x = 0; x <= 7; x++)
while(y<=x)
** total += pow(2,x);**
y++;
Serial.print("Unconverted total (double Type): ");
Serial.println(total);
** int intTotalCast = (int)total;**
** int intTotalConversion = int(total);**
Serial.print("Converted using casting (int Type): ");
Serial.println(intTotalCast);
Serial.print("Converted using Converter (int Type): ");
Serial.println(intTotalConversion);
Serial.println("Loop Starts Over");
Here's the output:
Unconverted total (double Type): 1.00
Converted using casting (int Type): 1
Converted using Converter (int Type): 1 Loop Starts Over
Unconverted total (double Type): 3.00
Converted using casting (int Type): 3
Converted using Converter (int Type): 3 Loop Starts Over
Unconverted total (double Type): 7.00
Converted using casting (int Type): 6
Converted using Converter (int Type): 6 Loop Starts Over
Unconverted total (double Type): 15.00
Converted using casting (int Type): 14
Converted using Converter (int Type): 14 Loop Starts Over
Unconverted total (double Type): 31.00
Converted using casting (int Type): 30
Converted using Converter (int Type): 30 Loop Starts Over
Unconverted total (double Type): 63.00
Converted using casting (int Type): 62
Converted using Converter (int Type): 62 Loop Starts Over
Unconverted total (double Type): 127.00
Converted using casting (int Type): 126
Converted using Converter (int Type): 126 Loop Starts Over
Unconverted total (double Type): 255.00
Converted using casting (int Type): 254
Converted using Converter (int Type): 254
As you can see, the converted values start off correct, 1:1, 3:3, then it goes weird... 7:6, 15:14, 31:30, etc...
every single value after 3 is off by one, i don't get it!!!! Please help, I'm out of ideas.
BTW, what I'm trying to do basically... is count up in binary... to get this pattern:
00000001
00000011
00000111
00001111
00011111
00111111
01111111
11111111
Edit:
Cleaned it up, made it a little easier to read. Hopefully.
Because of the way doubles are stored, they can't be perfectly precise. So when you type 5 it might hear 5.00000012 or 4.9999984. So while 5.000000012 casted to an int (which is always rounded down) may be 5, 4.99999984 casted to an int is 4, which is obviously incorrect.
So instead of rounding down, you want to round to nearest. The easiest way to do this is to add 0.5 and then round down:
Thanks, that worked. Even with your explanation I don't understand how that could happen. I mean, i would think a data type of double would imply even more precision, rather then less. I would expect it to store 5.00000000000000000000. Also, I assumed it would simply truncate the value, so that everything to the right of the decimal point would be chopped off and discarded. It seems silly... but it worked! thanks again.
PeterMHull:
Nope. Fixed point types (int, long, byte) always have more precision than floating point (float, double) of the same length since they operate over a much smaller range of numbers. But even with ten thousand digits after the decimal point of precision, you can't store precisely 5 the way arduino does, just like you can't specify 1/3 precisely in decimal (it's ABOUT 0.3333333). And even if it's 0.00000000000000000001 below 5, it just chops off the stuff after the decimal point leaving you with four.
ok, but why does it return 5.00 when displaying it's double form? It rounds for println purposes?
Yes, the implementation of print(double) uses the same trick I showed you. From Print.cpp:
size_t Print::printFloat(double number, uint8_t digits)
size_t n = 0;
if (isnan(number)) return print("nan");
if (isinf(number)) return print("inf");
if (number > 4294967040.0) return print ("ovf"); // constant determined empirically
if (number <-4294967040.0) return print ("ovf"); // constant determined empirically
// Handle negative numbers
if (number < 0.0)
n += print('-');
number = -number;
// Round correctly so that print(1.999, 2) prints as "2.00"
double rounding = 0.5;
for (uint8_t i=0; i<digits; ++i)
rounding /= 10.0;
number += rounding;
// Extract the integer part of the number and print it
unsigned long int_part = (unsigned long)number;
double remainder = number - (double)int_part;
n += print(int_part);
// Print the decimal point, but only if there are digits beyond
if (digits > 0) {
n += print(".");
// Extract digits from the remainder one at a time
while (digits-- > 0)
remainder *= 10.0;
int toPrint = int(remainder);
n += print(toPrint);
remainder -= toPrint;
return n;
00000001
00000011
00000111
00001111
00011111
00111111
01111111
11111111
How about this:
void setup(){
int lines=8;
int number=1;
for (int s=lines-1;s>=0;s--){
for (int t=lines-1;t>=0;t--){
Serial.print(bitRead(number,t));
Serial.println();
number<<=1; // bitshift number one to the left
number+=1; // add 1 to the right most bit
void loop(){}
00000001
00000011
00000111
00001111
00011111
00111111
01111111
11111111
00000001
00000011
00000111
00001111
00011111
00111111
01111111
11111111
which of course is unary, not binary.
Can you explain what you mean by that? They look like binary numbers to me...
