CASIO calculator and Arduino; joining circuits of different Voltage
Hello!
I'm trying to hack a CASIO fx-85ES calculator:
I want to use the calculator as a keypad (arduino knows what button you pressed) and display (arduino "presses" a button), using an Arduino Pro Mini (5v).
buttons are pressed by connecting two contact points on the board:
for example: K07 + KI5 = "1" or K01 + KI2 = "4"
I only want to use the following keys: 0-9, +, -, x, :, =, and ")". total of 16 buttons
I plan to:
Connect points using transistors "press buttons". (is there a way the arduino can do this without transistors)
Use pins as input to read buttons pressed. (or more transistors?)
Note: I will only use calculator as INPUT OR OUTPUT never both at once.
Anything I forgot or suggestions? what do you think, could this work? :stuck_out_tongue:
Would I damage the arduino by feeding the contact points on the calculator to it as inputs?
**Do I have to join GND like when wiring a Servo???? ** (1.5v cicuit of the calculator and 6v circuit of the arduino)
It is not clear what you are asking.
You want to use the Arduino as a substitute for the keypad?
OK
And also to read the calculator's keypad (key strokes), when that is used?
I WANT:
An arduino Pro Mini 5v to:
-Know when a button on the calculator is pressed.
-Press buttons on the calculator(buy connecting two connection points)
HOW?:
Know when a button is pressed by reading a change in voltage between connection points.
Use transistors to connect two connection points, transistor's base (B) to arduino.
MY PROBLEMS:
Will feeding a cable from the connection points on the calculator to the arduino damage the arduino? or even work?
Can I join two connection points on the calculator using the arduino, not transistors? ( the two connection points have to be wired one to another, NOT to GND or Vcc)
http://www.nxp.com/documents/data_sheet/74HC_HCT125.pdf
not sure if this helps
What does this mean:
quad buffer/line driver with 3-state outputs controlled by
the output enable inputs
I tried goggling around but I don't see how it should help?
it means you can use this chip to have 2 different components that use different voltage talk to eachother, ie 3.3v to 5v. its a buffer between the 2.
Would I damage the Arduino by feeding input and outputs to and from it without any isolation? (transistor, optocoupler)
using the 125? i really dont think you can, a very good detailed explanation Gammon Forum : Electronics : Microprocessors : Connecting 512 Kbyte EEPROM (flash memory) to your processor using SPI
No, without using any kind of isolation.
