David82:
What other cable can carry that kind of power and data while being able to be bought locally in different lengths? Cat5 is very convenient. An extension chord would be good too but it only has 3 wires. I need power, RX, TX, and video signal all on one cable.
You're mixing data and video in the same bundle as power cables? That's going to need screening then even assuming you get around the conductor rating issues. UTP is not a good starting point for that.
Believe it or not, I actually do this type of testing for a living, so let me assure you - CAT 5 cable will carry 7A of AC current for approximately 2.5 seconds before fusing. 30A will last approximately 65ms before fusing, and 60A will last approximately 13ms before fusing.
I will not state how much current can be 'safely' carried by CAT 5 cable for your own safety...
Forgot to answer the second part of the question...you asked why would 120V cause the CAT5 cable to fuse when 12DC does not:
DC current will use the entire cross-sectional area of the wire to conduct current. I do not know what the DC current rating of CAT5 cable is, but if you say you can carry 7A DC through it, I assume the cross-sectional area of 26 AWG wire is sufficient...
With respect to AC current - as frequency increases, conductors begin to exhibit "skin effect," which is that the current actually travels on the outer surface of the wire and not through the center of the wire. As frequency gets higher, the skin depth gets smaller, so you are effectively reducing the area that the current is flowing though, so at 120Hz, you really don't have the equivalent of 26AWG copper wiring any more - you have something less (I don't know how much less, unfortunately). At extremely high frequencies, the entire current path may be only on the surface of the wire itself. 30 Megabit Ethernet signals are very low voltage and very low current, so the amount of copper needed to transmit the data is very small, so why then is CAT5 cable 26 AWG??
The answer is simple - the telecommunications company that is sending service into your home has engineered their protection mechanisms to ensure that the most dangerous voltages your telecomm lines will ever see is 120V. They also know that if you should get 120V on your telecomm lines, the equipment that your telecomm lines are connected to will have secondary voltage-limiting and secondary current-limiting protection. In short, they know you have sidactors and fuses in your equipment. Fuses are designed to carry up to 20% above their rated spec for up to 15 minutes, so a 2A fuse will carry up to approximately 2.4A for a full 15 minutes before fusing. Anything more than that, and the fuse operates almost immediately. When that fuse operates, the current is interrupted and your telecomm lines don't fuse and catch your house on fire...so, that CAT5 cable has to be rated to carry up to approximately 2.5A for 15 minutes...
Pretend like you have a device that draws 12V 7A at most, receives TTL data, and sends back video data. It needs to operate at varying distances, say, 6-100ft. It needs to be connected with one cable. How would you do it? Do you cop out and run an extension chord for the power and a telephone/CAT5 line for the other data, or do you get smart and figure out a solution that meets the requirements?
The calcs above showed that with cat5 cable in order to stay within the cable's rated voltage and current you could carry the power but it would require using all the conductors. I wonder whether you could get away with using fewer conductors if you used solid core cat6 augmented cable? That has thicker conductors and would have a significantly higher DC current rating. Since you're carrying video and TTL data down the same cable I'm pretty sure that cross-talk would render AC completely out of the question so I assume you would transmit it using DC, and keep the DC voltage within the specs for the cable which probably means 50-60V maximum. Cross-talk issues may still kill you with UTP, though. You really don't want high currents running parallel to unshielded cables.
Again, this implies transforming and rectifying the power at the supplier, and doing DC-DC conversion down to 12V at the receiver side. It seems to me that the cost / complexity added by that would outweigh the convenience of being able to use standard network cable, but I don't know how interested you are in issues other than the cable itself.
You haven't mentioned where these cables would be used. Can we assume that they would be for permanent installation in a warm dry environment?
You might be able to get away with ethernet cable if you are willing to make enough compromises, but it doesn't strike me as the right cable for carrying this much power or that combination of signals. You really need a cable designed to carry the current and voltage you need, plus separate shielded cables for the video and TTL components.
Because customers would prefer to buy and string up one cable vs two side-by-side.
I figured this was for your own use. I shouldn't make such assumptions.
That's different, the customer is always right. In that case just present to and have your customer sign off on a waiver of all fault and liability for your work and run it all through your cat5 cable. Be sure you have your attorney draw up the document as some liabilities cannot be transferred or waived.
Lefty
Waivers aren't going to help you when somebody gets killed. If anything it will show you knew it was dangerous and did it anyway.
Lefty
Actually, this makes the problem much simpler. If you sell stuff to people that connects
to the power mains, and you didn't get UL agency approval, and it burns down their house,
then you both get sued and the govt puts you in jail. Totally illogical.
And we have documented here that David82 was repeatedly advised against such reckless behavior - that will certainly not play well in the inevitable lawsuit that David82 will be answering to, as he seems hellbent on moving forward with this blatantly hazardous endeavor.
It would be hilarious if David82's client was an Arduino hobbyist and read this thread, thinking "Hmmm, this looks just like that project at the office.... wait a minute, pretty sure it is the project at the office... does this guy know Jack Schitt about this stuff we're paying him to do?"
Some very odd claims here. A 7A power supply is the low voltage current. Not the high voltage current.
A 7 Amp low voltage power supply is going to be requiring well under 1 A on the mains supply side, so as far
as current capacity is concerned, that is the figure you should be comparing the capacity of the cable to.
You are more likely to have inadequate insulation capability, than current constraints.
You'd still be running a Cat5 cable close to, or exceeding, it's DC current rating. WIth a long length than thatwll introduce I2R losses in the cable. These losses are simply heating effects due to the resistance of the conductor. That means heat. Heat means de-rating current carrying capacity AND insulation resistance.
The fact it would also be an AC supply, which the cable is NOT designed for, rings a big fat NO.
It's very very simple really, he states it's for a customer, that means you have to use materials that are rated for the purposes you want to put them to. Using a Cat5 cable for a mains AC supply is NOT what it is designed or rated for.
AC and DC are two totally different things, with different characteristics of stress and leakage currents. A cable acts like a capacitor. When you test a cable at DC it will take a charging current initially and then settle to a steady (you hope low) leakage current. If you test at AC power frequency (50 or 60Hz) that capacitance is charged and discharged repeatedly in opposite polarity and you get appreciable larger AC leakage current. It's the same as in an electronic circuit, a capacitor blocks DC and, depending on the value and applied AC frequency, will have differing effect on AC from a hgh reactive impedance to virtually none.
I get involved in low (up to 1000V) and high (up to 33,000V) testing and there are many different insulation types and ways of testing each one, from DC to AC power frequency (50 or 60Hz) and AC Very Low Frequency (0.01 to 1Hz). Insulation of a particular cable is designed to withstand the type of voltage it is intended to carry.
If you use a cable for a purposes it's not intended for then you can't guarantee how it will hold up under those conditions.
David82, I think that you should STOP trying to do something that may cause injury or death, and may cause damage to property. You CAN'T try to run 120VAC current through Cat5 cables. If you don't believe me, connect two thin wires to a powerful battery (battery pack for R/C cars). Touch the wires together and watch the insulation melt.
Here's an even simpler way of looking at it.... if the OP has to ask about mains wiring on a forum, he's not qualified to sign off on the work... Period.
JimboZA:
