I've been trying to get my first program uploaded to a Duemilanove w/ ATmega328. I keep getting the following error though.
My best guess is the listed serial port is wrong. /dev/ttyS0 is the only one listed in tools-serial port. Most posts I've read list /dev/ttyUSB0 as the correct port but there isn't anything in /dev/ like that. The only thing with usb is usbmon0-5. The board is blinking in it's default program so I know it's getting power. Any ideas?
I'm running xubuntu 9.10 with the 2.6.31 kernel. I downloaded the sowtware through the ppa.
when a arduino is plugged in the device /dev/ttyUSB0 will be created by the operating system, and it will be removed when the arduino is unplugged.
Test:
Unplug your arduino
Open a console window and list the current devices with ls -all /dev/ttyUSB*
plug your arduino into your machine and list the devices again ls -all /dev/ttyUSB*
You should now see the device created for the Ardunio.
If not, please check the system log with
I noticed no change in /dev/. My dmesg output is below.
[48876.377581] usb 1-4: USB disconnect, address 11
[49049.352105] usb 3-2: new full speed USB device using uhci_hcd and address 4
[49049.472071] usb 3-2: device descriptor read/64, error -71
[49049.696135] usb 3-2: device descriptor read/64, error -71
[49049.912139] usb 3-2: new full speed USB device using uhci_hcd and address 5
[49050.032102] usb 3-2: device descriptor read/64, error -71
[49050.256108] usb 3-2: device descriptor read/64, error -71
[49050.472101] usb 3-2: new full speed USB device using uhci_hcd and address 6
[49050.884115] usb 3-2: device not accepting address 6, error -71
[49051.000112] usb 3-2: new full speed USB device using uhci_hcd and address 7
[49051.408129] usb 3-2: device not accepting address 7, error -71
[49051.408165] hub 3-0:1.0: unable to enumerate USB device on port 2
I think this is the relevant part. If not I really don't know because everything else seemed to be related to file systems.
bad news.
On the Linux-USB subsytem error 71 is a "Protocol error".
If the error does not go away when you use a different cable or use a different USB-Port/Hub it looks like your board (the USB2Serial adapater at least) is damaged.
