I've got a bit of a weird problem building my library and I can't figure it out. I have a function that the external code calls, and this function returns zero. The external code has a while loop that checks this return value and breaks out of the loop when it's zero.
So you'd think the loop would never run, right? Well the Arduino locks up in the loop...
uint8_t get_value() {
return 0;
void external_function() {
while (get_value()) {
// do stuff
Given that the code locks up only when the while loop is present I put a debugging command in to find out what get_value() is returning, and it came out as 2048! That's why the loop runs forever. How you get 2048 from a "return 0;" is beyond me though...any suggestions??
Maybe something to do with a uint8_t being cast to some other type?
Unfortunately now I can't tell It works as a char, but it is also working now if I take out the uint8_t cast. Perhaps that memory location is all zero now so it will work until it changes again...?
Yeah, I am... 0x1 and 0x0 (true false) the same way HIGH and LOW are handled (0x1 and 0x0 respectively.) I could be mistaken but I thought this is how Arduino stores these bool types.
The bool datatype is stored in a single byte. It's most related to the uint8_t or byte datatypes. true is stored as 0x1 and false is stored as 0x0.
Because the Arduino can't do booleans (they are handled as ints) the while statement may as well be while(false){} right?
In C(++), any thing that can be coerced into a bool can be used for a conditional expression...
int i;
while ( i ) { // if i is not zero, the loop executes (i is quietly coerced to a bool by comparing it to zero)
char ch;
while ( ch ) { // if ch is not zero, the loop executes
float f;
while ( f ) { // if f is not zero, the loop executes (f has to be EXACTLY zero)
char* s;
while ( s ) { // if s is not NULL, the loop executes
So, Malvineous' original expression...
...can be rewritten like this with the same results...
