Hello guys,
I have recently purchased an Arduino 2560 Mega from ebay and I am trying the Blink tutorial with different delay times but the LED always blinks by 1secON-1sec OFF. It doesn't respond to code changes.
I also noticed that Funduino is written on the board. i'm using the standard Adruino environment to program it. Should I do something else?
Please help!
Thanks!
Under FIle:Preferences, check the Verbose output boxes.
What output do you get when you upload?
Thanks, I am back!
What I get is the following:
avrdude: Version 5.11, compiled on Sep 2 2011 at 19:38:36
Copyright (c) 2007-2009 Joerg Wunsch
System wide configuration file is "C:\Program Files (x86)\Arduino\hardware/tools/avr/etc/avrdude.conf"
Using Port : \.\COM9
Using Programmer : arduino
Overriding Baud Rate : 115200
avrdude: Send: 0 [30] [20]
avrdude: Recv:
avrdude: stk500_getsync(): not in sync: resp=0x00
avrdude done. Thank you.
How should I proceed?
Thank you
Supernoob here! Doooh..
Chose the correct board and thats it.. Many many thanks CrossRoads!!!!
