Make no mistake, I'm NOT in favour of creating a multi-lingual compiler or something like that.
i just find it interesting that nobody complains about this, or Tries to change it. The "real world" doesn't care, the only protests to stuff like that are based on "principles" of people who have no real stake in the matter... and I'm glad to see programmers are a niche spared from those people ( probably because they haven't figured it out yet or simply don't understand... refer to the importance of a good logical mind as needed in this field)
Background, or I came upon this discussion: I'm Belgian, and as you know (Or SHOULD know ) we have three official languages and a prime minister who speaks only one of those well, French, the second, Flemish, badly and the third, German, not at all as far as I know. And this affronts many of the Flemish speakers here.
Most of whom will never ever need to talk to him in person, so it's actually only a matter of principle, thanks to translation services and the Administrative machine that is a government.
Which I find silly seen as globalisation (unstoppable, wether one likes that or not) causes languages to become more and more regional, in favour of a single worldwide language, which may well turn out to be English.
Sorry Chinese people... you may build most of the chips and whatnots that the world uses, but as this thread shows... it's English that drives it all....
The same is true in Aviation. English is the spoken language for airlines. Yes, there are people who are multi-lingual, but if you want to fly the big birds, you must speak English.
flyboy:
I heard Grace Hopper talk about the origins of COBOL. She said they first "turned it in" in several languages, but it was rejected for being "too ambitious" or something like that.
C only has about 35 keywords, several of which aren't words ("int"), and others of which are deprecated ("register")
It wouldn't take much to translate the whole thing.
indeed but France has filed a difference
so all comms between French ATC and French pilots is in French
buggers up the situational awareness
they will talk English to an English pilot
but you miss half of what's going on
now Germany is different
I flew from UK to Denmark, through German airspace
when I first dialled in the German ATC everyone was talking German
uh oh
made my first call in English
it all went dead quiet
you could almost hear people changing gear
then everyone (pilots as well) continued in pefect English!
A Pan Am 727 waiting for start clearance in Munich overheard the following:
Lufthansa (in German): "Ground, what is our start clearance time?"
Ground (in English): "If you want an answer you must speak in English."
Lufthansa (in English): "I am a German, flying a German airplane, in Germany. Why must I speak English?"
Unknown voice from another plane (in a British accent): "Because you lost the bloody war!"
But I'm from Belgium and I have read some "french and dutch code". My advice: "don't go there".
There have been languages that have translated to local languages or were/are available in localized versions. For instance excel converts your formula's to local language (settings). But also other more professional languages have tried it.
In general they become popular locally but hardly get "world sized" for the obvious reason of code reuse.
What could I do with code from a Chinese if it were in Chinese?
Don't forget that appart from the words there is also the formatting issue 1,000 and 1.000 in Belgium is 1.000 and 1,000 in USA. If you ever copied excel formula's from the internet and it didn't work, this was very likely to be the cause?
Would you like to copy and adapt
Jantje:
For instance excel converts your formula's to local language (settings). Best regards
Jantje
I hate.. HATE that.... makes working at another location a b***h... because excell also manages to NOT recognise the other languages... you can't use ROOT for example on a non-english PC, and I know that a root is "wortel" in Dutch, but I have no idea what it is in german or french... let alone the more complex functions
What do you call a person that can speak two languages?
Answer, bilingual.
What do you call a person that can speak three languages?
Answer, trilingual.
What do you call a person that can speak only one language?
Answer, American.
tomperdarwin:
Are there compilers that work in other languages ?
i mean, as far as I know, C language (and every other programming language I 've encountered) is basically English. And a rapid search with the help of our googly friends didn't tell me more.
All they have to do is a cut and paste from English to another language concerning the commands of any language.
Compilers are lexographic translators, the do not working in "English", it just so happens that some of the lexographic symbols 'resemble' English words.
Much of the language has its basis in mathematics.
Whilst you may say " for (int loop=0; loop<8; loop++)" ,it is no more English than "Typhoon" ???? or "Sampan" (??).
For it to be English then you should be looking at:
Can you please loop round the following:
whilst the count is less than 8.
Changing keywords/reserved words in a programming to match the native language is relatively simple, but imagine, for instance, COBOL in German, with the verb at the end!
AWOL:
I once worked with a guy who figured out how to modify the symbol table in the CDC COBOL compiler so that his most frequent typos would still work. This was just for fun, of course, because you don't send code to production with 'perfrom' instead of 'perform' scattered here and there. Hmmm, might have been under VMS -- we were using both, and that was back in the early 80s, so I don't remember the gory details.
I've wondered about that for a while, but in the end I think it doesn't make a huge difference, if you speak English natively or not. Even for English speakers, C initially looks pretty obscure, for example:
^ exclusive or
% modulus
++ add 1 to itself
-- subtract 1 from itself
& bitwise and
| bitwise or
&& logical and
|| logical or
~ negate (plus destructor)
{ } group stuff into a block
! not <something>
< > templates
#xx some obscure compiler directive
\xx some "escape" sequence
void huh?
int a number?
char a letter?
It's not as if a native English speaker can pick up C++ code and just know exactly what it means. And for non-English speakers, they just have to add a few more things to the list, like "if" and "while". And even English speakers have to learn stuff like "if (a = b)" won't work as you expect.
