Rechargeable battery for 3 motors
How should I power 3 motors (2 steppers and 1 servo) ? I guess the Arduino's power wouldn't be enough, and I need portable sources of energy anyway (as it's a robot).
FYI, I'll be using the Adafruit motor shield to control the motors and I'm using an arduino mega. (So yes, I'll need a battery for the mega too !)
Know any (easily) rechargeable batteries that could handle the Mega and the motors ? (not necessarily a battery that does both)
Ckeck sites like hobbyking and hobbypartz for batterys and chargers.
Hobbyking is good place to buy servos, (rechargeable) lipo-batteries and chargers. Quality of products can be difficult to know. Mostly it's ok, but can be poor.
You have to know needed voltage and current, after that it's easy to find battery. Leave some headroom above the specs.
Thank you for the link !
I've found this battery that seem nice :
http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=16331
But I don't really know if it'll be enough for what I want.
First, I need a ~9v battery for the Arduino Mega (that one will do the trick with its 11.1v).
And then I need another battery for my motors. I will have 2 stepper motors ( Recommendations For You - DealeXtreme ) and one servo ( Recommendations For You - DealeXtreme ) ; they will be connected to the Adafruit motor shield.
I'm really new to electronics so I don't really know what kind of batteries are compatible and how much current / voltage I need !
Any help would be much welcome !
halflings:
Servos need 5 volts (6 V is possible too) and your stepper motors take 5 V too. Arduino works any voltage from 6 to 20, but 7-12 V is best choice.
You may change the higher voltage to 5 or 6 volt with part in next link, so called SBEC (UBEC makes (about) same thing).
By the way, fully charged 11.1v (Lipo-) battery voltage is some 12,6 V or even 12,7 volts.
You need to know both the peak current requirements of all your motors and the average current in normal use - the latter means you can estimate the battery capacity requirements for a given time of use.
Your battery will need to provide enough current (A) for the peaks and have enough capacity (Ah or mAh) to keep going for long enough.
If you have no exact figures how heavy load you will give to battery, you may just try some battery, like lipo you thought earlier (1000mAh 3S1P 25C). It can be ok, because your stepper motors are small and servo hardly needs much power.
Thank you guys for all these insights.
I think I'll just go for the LiPo I've posted earlier as I don't have any much infos about the motors and see how it works out !
Oh, just a last question:
How can I recharge this ( http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=16331 ) kind of batteries ?
halflings:
You need a lipo-charger. Like this:
Maybe you need (power cord) adapter for your country too. Or new cord. It is same type as in laptop comters, from "wall" to laptop power unit.
And how to use charger:
Always use "balance" charhing mode.
Next charger can make the job, but if you will buy bigger batterys, charging will take long time.
