dht11 with comparators
Hi, i have this code working with dht11 + lcd but i need to introduce a comparators something like if humidity is lower than 40% then turn a led and with temperature the same thing like if higher than 23 C then turn another led
Code working with no comparators DHT11 + LCD
#define dht_dpin 14
#define LIGHT_SENSOR_PIN 1
#include <LiquidCrystal.h>
LiquidCrystal lcd(0, 1, 2, 3, 4, 5);
byte bGlobalErr;
byte dht_dat[4];
int light_intensity = 0;
unsigned int flip = 0;
void setup(){
pinMode(13, OUTPUT);
lcd.begin(16, 2);
lcd.print("Heeeeeello!");
InitDHT();
delay(300);
delay(700);
void loop(){
if ( flip & 1 )
digitalWrite(13, HIGH);
digitalWrite(13, LOW);
flip++;
light_intensity=analogRead(LIGHT_SENSOR_PIN);
ReadDHT();
switch (bGlobalErr) {
case 0:
lcd.setCursor(0, 0);
lcd.print("temp = ");
lcd.setCursor(7, 0);
lcd.print( dht_dat[2], DEC);
lcd.setCursor(0, 1);
if ((flip % 15) > 7 )
lcd.print("humidity = ");
lcd.setCursor(11, 1);
lcd.print( dht_dat[0], DEC);
lcd.print("Light = ");
lcd.setCursor(8, 1);
lcd.print( light_intensity, DEC);
break;
case 1:
break;
case 2:
break;
case 3:
break;
default:
break;
delay(800);
void InitDHT(){
pinMode(dht_dpin,OUTPUT);
digitalWrite(dht_dpin,HIGH);
void ReadDHT(){
bGlobalErr=0;
byte dht_in;
byte i;
digitalWrite(dht_dpin,LOW);
delay(18);
delayMicroseconds(600);
delayMicroseconds(40);
pinMode(dht_dpin,INPUT);
dht_in=digitalRead(dht_dpin);
if(dht_in) {
bGlobalErr=1;
return;
delayMicroseconds(80);
if(!dht_in) {
bGlobalErr=2;
return;
delayMicroseconds(70);
for (i=0; i<5; i++)
dht_dat = read_dht_dat();
  • pinMode(dht_dpin,OUTPUT);*
  • digitalWrite(dht_dpin,HIGH);*
  • byte dht_check_sum =*
  • dht_dat[0]+dht_dat[1]+dht_dat[2]+dht_dat[3];*
  • if(dht_dat[4]!= dht_check_sum)*
  • {bGlobalErr=3; }*
    byte read_dht_dat(){
  • byte i = 0;*
  • byte result=0;*
  • for(i=0; i< 8; i++) {*
  • while(digitalRead(dht_dpin)==LOW) ; *
  • delayMicroseconds(30);*
  • if (digitalRead(dht_dpin)==HIGH)*
  • result |=(1<<(7-i)); *
  • while (digitalRead(dht_dpin)==HIGH) ;*
  • return result;*
That's easy:
  read_dht11();
  if dht11.humidity < 40% turn on a led;
  else turn off the led;
  if hdt11.temperature > 23 turn on another led;
        for (i=0; i<5; i++)
Nicely done.
thank you dhenry for your reply, in fact i did that but im not sure where should i put that sentence on the code and i have doubts if its gonna be simple as that
i added a servo but with no control of comparators.. i have problem with that part :sweat_smile: .I wanna turn the servo on for 20 secs when humidity is lower than 40%. Anyone?
#define dht_dpin 14
#include <Servo.h>
Servo myservo;
byte bGlobalErr;
byte dht_dat[4];
int pos = 0;
void setup(){
myservo.attach(9);
lcd.begin(16, 2);
InitDHT();
delay(300);
delay(700);
void loop(){
if ( flip & 1 )
flip++;
ReadDHT();
case 0:
break;
case 1:
break;
case 2:
break;
case 3:
break;
default:
break;
delay(800);
for(pos = 0; pos < 180; pos += 1) // goes from 0 degrees to 180 degrees
{ // in steps of 1 degree
myservo.write(pos); // tell servo to go to position in variable 'pos'
delay(15); // waits 15ms for the servo to reach the position
for(pos = 180; pos>=1; pos-=1) // goes from 180 degrees to 0 degrees
void InitDHT(){
void ReadDHT(){
bGlobalErr=0;
byte dht_in;
byte i;
delay(18);
if(dht_in) {
bGlobalErr=1;
return;
if(!dht_in) {
bGlobalErr=2;
return;
for (i=0; i<5; i++)
  • {bGlobalErr=3; }*
  • byte i = 0;*
  • byte result=0;*
  • return result;*
You don't "turn on a servo". Please describe exactly what you mean by that. While you are thinking about it, look at the blink without delay example.
yeah sorry for the misleading words, i have the sweep servo code but i still need the comparations when temperature is higher than 25 C and the when humidity is lower than 40% turn on a led
this code have the servo sweep, the dht11 + lcd but no parameters for comparation
#define dht_dpin 14
#include <Servo.h>
Servo myservo;
byte bGlobalErr;
byte dht_dat[4];
int pos = 0;
void setup(){
myservo.attach(9);
lcd.begin(16, 2);
InitDHT();
delay(300);
delay(700);
void loop(){
if ( flip & 1 )
flip++;
ReadDHT();
case 0:
break;
case 1:
break;
case 2:
break;
case 3:
break;
default:
break;
delay(800);
void InitDHT(){
void ReadDHT(){
bGlobalErr=0;
byte dht_in;
byte i;
delay(18);
if(dht_in) {
bGlobalErr=1;
return;
if(!dht_in) {
bGlobalErr=2;
return;
for (i=0; i<5; i++)
{bGlobalErr=3; }
byte i = 0;
byte result=0;
return result;
