DEAR ARDUINO EXPERTS..
I'm having problem with LED dot matrix as i can only put strings in the characters, but not numbers for example dates, values...
can somebody help?. Here is the code.. I already comment where the problem is
// based on an orginal sketch by Arduino forum member "danigom"
// http://forum.arduino.cc/index.php?action=profile;u=188950
#include <avr/pgmspace.h>
#include <LedControl.h>
#include <stdio.h>
#include <string.h>
#include <DS1302.h> Â //http://www.henningkarlsen.com/electronics/download.php?f=DS1302.rar
const int numDevices = 1; Â Â Â // number of MAX7219s used
const long scrollDelay = 100; Â // adjust scrolling speed
uint8_t CE_PIN Â = 5;
uint8_t IO_PIN Â = 6;
uint8_t SCLK_PIN = 7;
const int PINMOTION=9;
char buf[50];
char day[10];
DS1302 rtc(CE_PIN, IO_PIN, SCLK_PIN);
unsigned long bufferLong [14] = {0};
int da
LedControl lc=LedControl(12,11,10,numDevices);
// pin 12 is connected to the MAX7219 pin 1
// pin 11 is connected to the CLK pin 13
// pin 10 is connected to LOAD pin 12
// 1 as we are only using 1 MAX7219
void printyear(){
Time t = rtc.time();
snprintf(buf, sizeof(buf), "%04d",t.yr);
Serial.println(buf);
void printmonth(){
snprintf(buf, sizeof(buf), "%02d",t.mon);
Serial.print(buf);
void printdate(){
snprintf(buf, sizeof(buf), "%02d",t.date);
Serial.print(buf);
prog_uchar scrollText1[] PROGMEM ={snprintf(buf, sizeof(buf), "%02d",date) Â };
// Â !!!!----HEREIS THE PROB
void setup(){
 pinMode(PINMOTION,INPUT);
  for (int x=0; x<numDevices; x++){
    lc.shutdown(x,false);    //The MAX72XX is in power-saving mode on startup
    lc.setIntensity(x,8);    // Set the brightness to default value
    lc.clearDisplay(x);     // and clear the display
void loop(){
 if(digitalRead(PINMOTION)==HIGH){
 Â
  //scrollFont();
