Help with millis!!!!
Hi, everybody. Millis is driving me crazier ( or maybe those curly braces? )
What I´m trying to do is start a timer when a swith comes in, wait a certain time and then " do that ".I googled millis,found tronicstuff, John Boxall and quite a few threads on the forum; can´t understand.
If I change a few things it LED" won´t go ON, or won´t go OFF or go ON immediately.
Just need explanation,not solution; Thanks.
Here´s my code:
int startPin = 2;
int LED1Pin = 3;
int openedPin = 4;
int LED2Pin = 5;
int closedPin = 6;
unsigned long openedtime; // when did switch go HIGH?
unsigned long opentime; // time delay
unsigned long currenttime;
void setup( )
pinMode ( startPin, INPUT );
pinMode ( LED1Pin, OUTPUT );
pinMode ( openedPin, INPUT );
pinMode ( LED2Pin, OUTPUT );
pinMode ( closedPin, INPUT );
void loop ( )
currenttime = millis ( );
if ( digitalRead ( startPin ) == HIGH )
digitalWrite ( LED1Pin, HIGH );
if ( digitalRead ( openedPin ) == HIGH )
digitalWrite ( LED1Pin, LOW );
openedtime = millis(); // when did it open
opentime = currenttime - openedtime;
if ( (opentime) >= 5000 )
digitalWrite ( LED2Pin, HIGH ); // turn LED2 ON
if ( digitalRead ( closedPin ) == HIGH )
digitalWrite ( LED2Pin, LOW );
Properly posted code is easier to read.
Code that has had Tools + Auto Format run on it is easier to read.
Code that consistently uses { and } after an if statement is easier to understand.
None of your INPUT pins have the internal pullup resistors enabled. Therefore, the switches MUST have external pullup or pulldown resistors. How ARE the switches wired?
Take a look at your loop(). From the time currenttime is set to millis() to the time openedtime is set to the value of millis() there are a few microseconds at most (there are just a few ifs, digitalRead()s and digitalWrite()s in between). So opentime is always 0 or maybe seldom 1 but never 5000.
Take a look a FSM's in the playground.
Mark
Pylon pointed out something, that makes me think the code might actually work like that if you moved the
"openedtime = millis(); // when did it open"
outside of the if and into the else branch.
However, it may be a little too late in the evening for me to think clearly.. Hmm, it's also a little scary that you don't initialize the unsigned long variables. So, it might be that you actually get LED2 to light up in some random cases when the program has just started. And the LED2 might be dimly lit in some case.
The variables are initialized:
All will be 0 to start.
This line:
currenttime will always be just less than openedtime because you are always resetting openedTime.
What you need is a flag to indicate that openedtime has been captured and you are waiting for time to pass; do not capture openedTime again until the flag has been cleared.
Almost sure I did that.
Does this mean that I should ALWAYS use curly braces with IF statements?
I´ve noticed that the code changes if I include or delete them.
I´m more comfortable with positive digital electronics; pullup resistors,no problem.
Hope I find it; don´t know what that means.
the code might actually work like that if you moved the "openedtime = millis(); // when did it open"outside of the if and into the else branch.
Tried that a thousand times.
Is it an error to assign both currenttime and openedtime = millis?
Should I take openedtime outof the main loop? Maybe call a function?
Is setting a flag the only way to solve this?
FSM Finite State Machine.
Also take a look a the blink without delay example which shows you the correct use of mills and is its self a small FSM.
Mark
Using a flag is one of the easiest ways.
One flag ok
two flags ok Mmm well
three flags Mmmm
four flags - redesign it
Mark
Don´t know if I´m going in the right direction but I´m into interrupts; if there´s something easier I´d appreciate you let me know. I only need one flag; when that switch actuates, count 5s.
then " do that ".I´m working on it, just need directives, thanks.
unsigned long getDeltaT(unsigned long st){
  unsigned long deltaT=0;
  unsigned long currTime=millis();
       // Serial.println("inside utils");
  if(currTime < st)
    deltaT = (2^32-1) - st + currTime;
    deltaT = currTime - st;
  return deltaT;
use above function it might solve your issue
Moderator edit:
</mark> <mark>[code]</mark> <mark>
</mark> <mark>[/code]</mark> <mark>
tags added.
Moderator edit: excessive over-quote removed.
void loop(){
currentTime = millis();
if ( (digitalRead(startPin) == 0) && (timeRunning == 0) ) { // time not running, and startPin button is pressed to Gnd
startTime = currentTime;
timeRunning = 1;
digitalWrite (LED1, HIGH);
elapsedTime = currentTime - startTime;
if ( (timeRunning == 1) && elapsedTime >= 5000){
timeRunning = 0;
digitalWrite(LED1, LOW);
and add what ever you're doing with LED2
Yes, even if it's just one line of code. Adding an extra statement to the if block is easier if the block is already there.
Plus, it makes it very clear that you KNOW the amount of code that will be executed if a statement is true.
Without them, I know, and the compiler knows, but it isn't clear that you know how much code will be executed.
This makes it seem like you really don't know the effect of the curly braces, or the amount of code that will be executed as a result of the evaluation of the if statement (or while statement or for loop, etc.).
