I use Linux and have loaded the compiler (UNO) and it works.
I find the on-board 8 bit ADC is too small for my LCD output. (Input is 0...+4V, LCD "0....20.00". The 2 least significant digits jump around too much!
Now I want to use Adafruit ADS1015 - a 12 bit ADC (to be able to 'discard' the last digit) for a more steady display.
I loaded the sketch and when I press "verify" I get the Error compiling :
fatal error: Adafruit_ADS1015.h.
No such file or directory.
Where can I find the right file and how do I load it?
I managed to load the ADC = ADS1015.
It seems that the ADC is reading the analog signals but I cannot output the two ADC ("single ended") values into the UNO, instead of the A0 & A2 UNO inputs.
What am I doing wrong?
Thanks.
#if ARDUINO >= 100
#include "Arduino.h"
#else
#include "WProgram.h"
#endif
#include <Wire.h>
I2C ADDRESS/BITS
#define ADS1015_ADDRESS (0x48) // 1001 000 (ADDR = GND)
CONVERSION DELAY (in mS)
#define ADS1015_CONVERSIONDELAY (1)
#define ADS1115_CONVERSIONDELAY (8)
POINTER REGISTER
#define ADS1015_REG_POINTER_MASK (0x03)
#define ADS1015_REG_POINTER_CONVERT (0x00)
#define ADS1015_REG_POINTER_CONFIG (0x01)
#define ADS1015_REG_POINTER_LOWTHRESH (0x02)
#define ADS1015_REG_POINTER_HITHRESH (0x03)
CONFIG REGISTER
#define ADS1015_REG_CONFIG_OS_MASK (0x8000)
#define ADS1015_REG_CONFIG_OS_SINGLE (0x8000) // Write: Set to start a single-conversion
#define ADS1015_REG_CONFIG_OS_BUSY (0x0000) // Read: Bit = 0 when conversion is in progress
#define ADS1015_REG_CONFIG_OS_NOTBUSY (0x8000) // Read: Bit = 1 when device is not performing a conversion
#define ADS1015_REG_CONFIG_MUX_MASK (0x7000)
#define ADS1015_REG_CONFIG_MUX_DIFF_0_1 (0x0000) // Differential P = AIN0, N = AIN1 (default)
#define ADS1015_REG_CONFIG_MUX_DIFF_0_3 (0x1000) // Differential P = AIN0, N = AIN3
#define ADS1015_REG_CONFIG_MUX_DIFF_1_3 (0x2000) // Differential P = AIN1, N = AIN3
#define ADS1015_REG_CONFIG_MUX_DIFF_2_3 (0x3000) // Differential P = AIN2, N = AIN3
#define ADS1015_REG_CONFIG_MUX_SINGLE_0 (0x4000) // Single-ended AIN0
#define ADS1015_REG_CONFIG_MUX_SINGLE_1 (0x5000) // Single-ended AIN1
#define ADS1015_REG_CONFIG_MUX_SINGLE_2 (0x6000) // Single-ended AIN2
#define ADS1015_REG_CONFIG_MUX_SINGLE_3 (0x7000) // Single-ended AIN3
#define ADS1015_REG_CONFIG_PGA_MASK (0x0E00)
#define ADS1015_REG_CONFIG_PGA_6_144V (0x0000) // +/-6.144V range = Gain 2/3
#define ADS1015_REG_CONFIG_PGA_4_096V (0x0200) // +/-4.096V range = Gain 1
#define ADS1015_REG_CONFIG_PGA_2_048V (0x0400) // +/-2.048V range = Gain 2 (default)
#define ADS1015_REG_CONFIG_PGA_1_024V (0x0600) // +/-1.024V range = Gain 4
#define ADS1015_REG_CONFIG_PGA_0_512V (0x0800) // +/-0.512V range = Gain 8
#define ADS1015_REG_CONFIG_PGA_0_256V (0x0A00) // +/-0.256V range = Gain 16
#define ADS1015_REG_CONFIG_MODE_MASK (0x0100)
#define ADS1015_REG_CONFIG_MODE_CONTIN (0x0000) // Continuous conversion mode
#define ADS1015_REG_CONFIG_MODE_SINGLE (0x0100) // Power-down single-shot mode (default)
#define ADS1015_REG_CONFIG_DR_MASK (0x00E0)
#define ADS1015_REG_CONFIG_DR_128SPS (0x0000) // 128 samples per second
#define ADS1015_REG_CONFIG_DR_250SPS (0x0020) // 250 samples per second
#define ADS1015_REG_CONFIG_DR_490SPS (0x0040) // 490 samples per second
#define ADS1015_REG_CONFIG_DR_920SPS (0x0060) // 920 samples per second
#define ADS1015_REG_CONFIG_DR_1600SPS (0x0080) // 1600 samples per second (default)
#define ADS1015_REG_CONFIG_DR_2400SPS (0x00A0) // 2400 samples per second
#define ADS1015_REG_CONFIG_DR_3300SPS (0x00C0) // 3300 samples per second
#define ADS1015_REG_CONFIG_CMODE_MASK (0x0010)
#define ADS1015_REG_CONFIG_CMODE_TRAD (0x0000) // Traditional comparator with hysteresis (default)
#define ADS1015_REG_CONFIG_CMODE_WINDOW (0x0010) // Window comparator
#define ADS1015_REG_CONFIG_CPOL_MASK (0x0008)
#define ADS1015_REG_CONFIG_CPOL_ACTVLOW (0x0000) // ALERT/RDY pin is low when active (default)
#define ADS1015_REG_CONFIG_CPOL_ACTVHI (0x0008) // ALERT/RDY pin is high when active
#define ADS1015_REG_CONFIG_CLAT_MASK (0x0004) // Determines if ALERT/RDY pin latches once asserted
#define ADS1015_REG_CONFIG_CLAT_NONLAT (0x0000) // Non-latching comparator (default)
#define ADS1015_REG_CONFIG_CLAT_LATCH (0x0004) // Latching comparator
#define ADS1015_REG_CONFIG_CQUE_MASK (0x0003)
#define ADS1015_REG_CONFIG_CQUE_1CONV (0x0000) // Assert ALERT/RDY after one conversions
#define ADS1015_REG_CONFIG_CQUE_2CONV (0x0001) // Assert ALERT/RDY after two conversions
#define ADS1015_REG_CONFIG_CQUE_4CONV (0x0002) // Assert ALERT/RDY after four conversions
#define ADS1015_REG_CONFIG_CQUE_NONE (0x0003) // Disable the comparator and put ALERT/RDY in high state (default)
typedef enum
GAIN_TWOTHIRDS = ADS1015_REG_CONFIG_PGA_6_144V,
GAIN_ONE = ADS1015_REG_CONFIG_PGA_4_096V,
GAIN_TWO = ADS1015_REG_CONFIG_PGA_2_048V,
GAIN_FOUR = ADS1015_REG_CONFIG_PGA_1_024V,
GAIN_EIGHT = ADS1015_REG_CONFIG_PGA_0_512V,
GAIN_SIXTEEN = ADS1015_REG_CONFIG_PGA_0_256V
} adsGain_t;
class Adafruit_ADS1015
protected:
// Instance-specific properties
uint8_t m_i2cAddress;
uint8_t m_conversionDelay;
uint8_t m_bitShift;
adsGain_t m_gain;
public:
Adafruit_ADS1015(uint8_t i2cAddress = ADS1015_ADDRESS);
void begin(void);
uint16_t readADC_SingleEnded(uint8_t channel);
int16_t readADC_Differential_0_1(void);
int16_t readADC_Differential_2_3(void);
void startComparator_SingleEnded(uint8_t channel, int16_t threshold);
int16_t getLastConversionResults();
void setGain(adsGain_t gain);
adsGain_t getGain(void);
private:
// Derive from ADS1105 & override construction to set properties
class Adafruit_ADS1115 : public Adafruit_ADS1015
public:
Adafruit_ADS1115(uint8_t i2cAddress = ADS1015_ADDRESS);
private:
// from Adafruit-4-channel-adc-breakouts/programming
Adafruit_ADS1015 ads1015;
void setup(void)
Serial.println("Hello!");
Serial.println("Getting single-ended readings from AIN0..3");
Serial.println("ADC Range: +/- 6.144V (1 bit = 3mV)");
ads1015.begin();
void loop(void)
int16_t adc0, adc1, adc2, adc3;
adc0 = ads1015.readADC_SingleEnded(0);
adc1 = ads1015.readADC_SingleEnded(1);
adc2 = ads1015.readADC_SingleEnded(2);
adc3 = ads1015.readADC_SingleEnded(3);
Serial.print("AIN0: "); Serial.println(adc0);
Serial.print("AIN1: "); Serial.println(adc1);
Serial.print("AIN2: "); Serial.println(adc2);
Serial.print("AIN3: "); Serial.println(adc3);
Serial.println(" ");
//end of ADS1015 programme===============================================
#include <LiquidCrystal.h>
int chgaPin = 0;
int bavoltPin = 2;
int led = 13;
LiquidCrystal lcd (12, 11, 5, 4, 3, 2);
const int numReadings = 100;
int readings[numReadings];
int index = 0;
int total = 0;
int average = 0;
int inputPin = 0;
lcd.begin(16, 2);
for (int thisReading = 0; thisReading < numReadings; thisReading ++)
readings[thisReading] = 0;
total = total - readings [index];
readings [index] = analogRead (chgaPin);
total = total + readings[index];
index = index + 1;if (index >= numReadings) index = 0;
average = total / numReadings ;
Serial.println (average);
delay(1);
int chgaReading = analogRead(chgaPin);
float chgaVolts = chgaReading * 1.0 / 27.0 ;
lcd.setCursor(0, 0);
lcd.print ("+ A");
lcd.setCursor (1, 0);
lcd.print(chgaVolts);
int bavoltReading = analogRead(bavoltPin);
float bavoltVolts = bavoltReading * 1.0 / 56.0 ;
lcd.setCursor (9, 0);
lcd.print (" V");
lcd.setCursor (10, 0);
lcd.print (bavoltVolts);
lcd.setCursor (10, 1);
Error shows
bm01.ino: In function ‘void loop()’:
bm01:219: error: expected `}' at end of input
You must have all the # statements at the very start of the code. The error message says you are missing a matching brace that is all.
That is very odd looking code, must be your Linux background.
Okay, I may have solved the ADS1015 output to the UNO input but am not sure.
Still get "expected unqualified-id before '{' token" error
[at line 167, i.e. before the "lcd.begin(16, 2)"].
The way I see it I can account for all curly braces. Or ....???
#if ARDUINO >= 100
#else
#endif
#include <Wire.h>
I2C ADDRESS/BITS
POINTER REGISTER
CONFIG REGISTER
typedef enum
adsGain_t;
protected:
uint8_t m_bitShift;
adsGain_t m_gain;
public:
void begin(void);
private:
public:
private:
void setup(void)
ads1015.begin();
void loop(void)
//end of ADS1015
int index = 0;
int total = 0;
int average = 0;
int inputPin = 0;
lcd.begin(16, 2);
delay(1);
int chgaReading = analogRead(adc0);
lcd.print ("+ A");
int bavoltReading = analogRead(adc2);
lcd.print (" V");
You have an opening brace in your code at line 167 for no reason at all. I suspect this should be the start of a function definition but you have no function you are defining.
Also all # defines and includes should be at the start of your code.
I suspect that this is not your code and you are trying to merge two codes together. Withholding information is only going to make the process of fault finding very tiresome.
