ok, Im going to try that
Ok, I now understand how it is done. But this Pattern im looking for is a bit more complicated. does anyone know gow i should convert this code into without delay?
More simplified version of it...>
int led = 13;
int led2 = 12;
pinMode(led, OUTPUT);
pinMode(led2, OUTPUT);
digitalWrite(led2, LOW) //Strobe
digitalWrite(led, HIGH);
delay(20);
digitalWrite(led, LOW);
delay(50);
delay(20);
delay(50);
delay(20);
delay(50);
delay(250);
digitalWrite(led2, HIGH);
delay(20);
digitalWrite(led2, LOW);
delay(50);
delay(20);
delay(50);
delay(20);
delay(50);
delay(250);
You can use the code in Mini Stage Show x 20 - #8 by Chagrin - LEDs and Multiplexing - Arduino Forum
See my explanation of setting up the blink pattern in reply #5.
Yes, I read that Reply post, I now understand alot better how this works, im confused on the code part...
Can you possibly give me an example of a code that would flash two leds, say like 3 times each?
Or, how does the code work...
Anotherwords, What is a code I can Write that will make this work.....
led1 will Flash;
HIGH 20ms
LOW 50ms
HIGH 20ms
LOW 50ms
HIGH 20ms
LOW 50ms
HIGH 250ms
LOW 20ms
then led2 will do the same
and repeats
??? really confused, I tried many types of code and nothing works for me
I'm at work so cannot test this code but would this do? Strobe pattern only changes at the end of the pattern NOT when the button is pressed.
const int led = 13;
const int led2 = 12;
const int button1 = 5; // Button pin
const int maxStrobeMode = 3; // Max strobe number
int strobeMode = 0; // Current strobe number
pinMode(button1,INPUT_PULLUP);
switch (strobeMode) {
case 0:
digitalWrite(led2, LOW); //Strobe
myDelay(20);
myDelay(50);
myDelay(20);
myDelay(50);
myDelay(20);
myDelay(50);
myDelay(250);
myDelay(20);
myDelay(50);
myDelay(20);
myDelay(50);
myDelay(20);
myDelay(50);
myDelay(250);
break;
case 1:
myDelay(20);
myDelay(50);
myDelay(20);
myDelay(50);
myDelay(20);
myDelay(50);
myDelay(250);
myDelay(20);
myDelay(50);
myDelay(20);
myDelay(50);
myDelay(20);
myDelay(50);
myDelay(250);
break;
case 2:
myDelay(20);
myDelay(50);
myDelay(20);
myDelay(50);
myDelay(20);
myDelay(50);
myDelay(250);
myDelay(20);
myDelay(50);
myDelay(20);
myDelay(50);
myDelay(20);
myDelay(50);
myDelay(250);
break;
case 3:
myDelay(20);
myDelay(50);
myDelay(20);
myDelay(50);
myDelay(20);
myDelay(50);
myDelay(250);
myDelay(20);
myDelay(50);
myDelay(20);
myDelay(50);
myDelay(20);
myDelay(50);
myDelay(250);
break;
void myDelay(int delayTime){
if (digitalRead(button1) == LOW){
strobeMode++; // Increment strobe mode
if (strobeMode > maxStrobeMode){
strobeMode = 0; // Reset if beyond maximum strobe mode
delay(delayTime); // Do the delay
I'm new to Arduino UNO but if I were thinking of doing something like this, I would use a loop approach with a table set up to sort out the pattern required etc. A simple state-machine would be nice and easy with no resulting problems with delay() holding everything else up. I've used this approach to drive a Servo and an LCD display with some success.
Basically, I just want to know how to make that One whole flash pattern without delay. then i can make it so i can toggle it on and off with a switch...
I have modified my Multi_Blink example in the Playground to do the cool pattern you are looking for. Hope this helps.
Mulri_Blink2.h
// Multi_Blink2.h
// Blink lots of LEDs at diffreent frequencies simultaneously
// Header file is required to be able to define the structured types
#include <Arduino.h>
#ifndef MULTIBLINKH
#define MULTIBLINKH
// State values for FSM
#define MB_NULL 0
#define MB_LOW 1
#define MB_HIGH 2
#define MB_LOOP 3
#define LOOP_UNDEF 255
typedef struct
uint8_t activeVal; // state value for this state to be active (MB_* defines)
uint16_t activeTime; // time to stay active in this state stay in milliseconds or loop counter
uint8_t nextState; // If MB_LOOP this is the state to loop back/forward to
} stateDef;
typedef struct
uint8_t ledPin; // Arduino I/O pin number
uint8_t currentState; // current active state
uint8_t currentLoop; // current position in the cycle
stateDef state[5]; // the MB_* state definitions. Add more states if required
uint32_t nextWakeup; // the 'time' for the next wakeup - saves the millis() value
} ledTable;
#endif
Multi_Blink2.ino
// Multi_Blink2
// Blink lots of LEDs at different frequencies simultaneously, include delays and loops in patterns
// Marco Colli - September 2012
// Demonstrates the way to carry out multiple time based tasks without using the delay() function
// Demonstrates the use of structures (and structures within structures)
// Demonstrates a data driven approach to programming to create compact, reusable code
#include "Multi_Blink2.h" // type definitions
// Blink Table T - Modify this table to suit whatever the output requirements are
// Add or delete lines as required to achieve the desired effects.
// To add additional states the structure in the header file needs to be modified
ledTable T[] =
//Pin St Lopp State 0 State 1 State 2 State 3 State 4 Wkup
{ 13, 0, 0, {{MB_HIGH, 20, 0}, {MB_LOW, 50, 0}, {MB_LOOP, 3, 0}, {MB_HIGH, 250, 0}, {MB_LOW, 450, 0}}, 0 },
{ 12, 0, 0, {{MB_LOW, 450, 0}, {MB_HIGH, 20, 0}, {MB_LOW, 50, 0}, {MB_LOOP, 3, 1}, {MB_HIGH, 250, 0}}, 0 },
// Self adjusting constants for loop indexes
#define MAX_STATE (sizeof(T[0].state)/sizeof(stateDef))
#define MAX_LED (sizeof(T)/sizeof(ledTable))
for (int i=0; i < MAX_LED; i++)
pinMode(T[i].ledPin, OUTPUT);
T[i].nextWakeup = 0;
digitalWrite(T[i].ledPin, LOW);
T[i].currentLoop = LOOP_UNDEF;
// check if the state active time has expired (ie, it is less than current time)
if (millis() >= T[i].nextWakeup)
T[i].nextWakeup = millis() + T[i].state[T[i].currentState].activeTime;
switch (T[i].state[T[i].currentState].activeVal)
case MB_LOW:
case MB_HIGH: // Write digital value
digitalWrite(T[i].ledPin, T[i].state[T[i].currentState].activeVal == MB_HIGH ? HIGH : LOW);
T[i].currentState = (++T[i].currentState) % MAX_STATE;
break;
case MB_LOOP: // loop back to specified state if there is still count left
// first time in this state set the loop counter
if (T[i].currentLoop == LOOP_UNDEF)
T[i].currentLoop = T[i].state[T[i].currentState].activeTime;
// loop around or keep going?
if (T[i].currentLoop-- > 0)
T[i].currentState = T[i].state[T[i].currentState].nextState;
T[i].nextWakeup = 0; // do it immediately
T[i].currentLoop = LOOP_UNDEF; // set up loop counter
break;
default: // just move on - handles NULL and any stupid states we may get into
break;
I was searching this forum for multiplexing LEDs and like this pattern a lot
I'm installing navigation lights on a model aircraft.
Along with this flash pattern, I would also like to include an LED that gives the impression of a rotating beacon.
I have come up with the pattern as below based on PWM, but how would this be included that whilst the LEDs from the above pattern are doing there thing, the beacon is also running.
Thank you for any suggestions / help.
void Beacon()
for(value = 1 ; value <= 30; value+=1) // fade in (from min to max)
analogWrite(5, value); // sets the value (range from 0 to 255)
delay(45); // waits for 30 milli seconds to see the dimming effect
digitalWrite (5, HIGH);
delay (70);
for(value = 30; value >=1; value-=1) // fade out (from max to min)
delay(45);
This should do the same thing without blocking. I have not compiled or tested this code, so there could be some errors.
This function could be added anywhere to give the fading as it is self contained.
#define FADE_IN 0
#define FULL_BRIGHT 1
#define FADE_OUT 2
#define FADE_DELAY 45 //ms
#define FULL_DELAY 70 //ms
#define LED_PIN 5
#define FADE_MAX 30 // max PWM value
#define FADE_MIN 1
void Beacon()
static uint32_t nextWakeup = 0;
static uint8_t currentState = FADE_IN;
static uint8_t fadeValue = FADE_MIN;
if (millis() <= nextWakeup)
return; // do nothing as time has not expired
switch (currentState)
case FADE_IN:
analogWrite(LED_PIN, fadeValue++);
if (fadeValue >= FADE_MAX)
currentState = FULL_BRIGHT;
fadeValue = FADE_MAX;
nextWakeup = millis() + FADE_DELAY;
break;
case FULL_BRIGHT:
digitalWrite(LED_PIN, HIGH);
currentState = FADE_OUT;
nextWakeup = millis() + FULL_DELAY;
break;
case FADE_OUT:
analogWrite(LED_PIN, fadeValue--);
if (fadeValue <= FADE_MIN)
break;
default: // error catch all - restart the sequence
break;
return;
Many thanks, where would the Beacon() function be called from within the main original group.
Essentially, I want the LEDs to be flashing as per the original example, along with the other LED running the Beacon routine.
Thanks for your help
Put it either at the start of loop or at the end of loop.
I thought that would be the case but wanted to check as the beacon LED just illuminates and stays on without any dimming.
Any ideas please.
Kind regards,
Steve
Check if your code is the same as posted as I corrected an error in the FULL_BRIGHT section soon after I posted it.
Spot on, I obvioulsy included your code as soon as you posted it and didn't realise it had been changed.
Thanks very much, does exactly what i want and looks very cool
Sorry to be pop up again, I wanted to add another LED onto another PMW pin, such as IO3.
The below code works, but is this method the most efficient to achieve the same PWM pattern on 2 IO pins ?
Many thanks for your help,
#define FADE_IN 0
#define FADE_OUT 2
#define LED_PIN1 5
#define LED_PIN2 3
#define FADE_MIN 1
Void Beacon()
static uint8_t fadeValue1 = FADE_MIN;
static uint8_t fadeValue2 = FADE_MIN;
case FADE_IN:
analogWrite(LED_PIN1, fadeValue1++);
analogWrite(LED_PIN2, fadeValue2++);
if (fadeValue1 >= FADE_MAX)
fadeValue1 = FADE_MAX;
if (fadeValue2 >= FADE_MAX)
fadeValue2 = FADE_MAX;
break;
case FULL_BRIGHT:
digitalWrite(LED_PIN1, HIGH);
digitalWrite(LED_PIN2, HIGH);
break;
case FADE_OUT:
analogWrite(LED_PIN1, fadeValue1--);
analogWrite(LED_PIN2, fadeValue2--);
if (fadeValue1 <= FADE_MIN)
if (fadeValue2 <= FADE_MIN)
break;
break;
return;
In the case of 2 LEDs it is probably ok. You could consider just electrically joining them if they are supposed to be identical, but software is probably easier.
In the more general case where you may want to do lots of LEDs and these could be at different times and out of phase, then you need to keep the data and the code separated so that each LED has its own context (eg, pin, timer, status, etc). The data is then passed to the code (in this case as a parameter to the function, maybe) implementing the Finite State Machine (FSM) to run the FSM on the data supplied. This is the essence of what MultiBlink2 does and Beacon is very similar.
If you are new to programming it is worth studying these pieces of code as they are the key to how you do things on the Arduino (or any single tasking computer) without holding anything else up. Maybe start by reading about FSM and then look at how they are implemented in this code - Beacon is a lot simpler than MultiBlink.
Having got the LED pattern working (and huge thanks to Marco), I wanted to add a little more hardware to the Arduino.
I wanted to add a little more code that listens to one of the pins for various PWM signals and if they are within a certain range, action by calling a subroutine.
However it seems to lock out some of the LED patterns. I essentially want to the LED pattern to continue if that is possible ?
Can anyone suggest where I have gone wrong please ?
#include <multiCameraIrControl.h>
Sony Nex5(9);
int z=100;
ledTable T[] =
{ 11, 0, 0, {{MB_LOW, 1500, 0}, {MB_HIGH, 35, 0}}, 0 }, //
{ 0, 0, 0, {{MB_HIGH, 20, 0}, {MB_LOW, 50, 0}, {MB_LOOP, 3, 0}, {MB_HIGH, 250, 0}, {MB_LOW, 450, 0}}, 0 }, //
{ 1, 0, 0, {{MB_HIGH, 20, 0}, {MB_LOW, 50, 0}, {MB_LOOP, 3, 0}, {MB_HIGH, 250, 0}, {MB_LOW, 450, 0}}, 0 }, //
{ 5, 0, 0, {{MB_LOW, 450, 0}, {MB_HIGH, 20, 0}, {MB_LOW, 50, 0}, {MB_LOOP, 3, 1}, {MB_HIGH, 250, 0}}, 0 }, //
{ 7, 0, 0, {{MB_LOW, 450, 0}, {MB_HIGH, 20, 0}, {MB_LOW, 50, 0}, {MB_LOOP, 3, 1}, {MB_HIGH, 250, 0}}, 0 }, //
{ 2, 0, 0, {{MB_HIGH, 35, 0}, {MB_LOW, 1500, 0}}, 0 },
#define FADE_IN 0
#define FADE_OUT 2
#define FRONT_LED 11
#define FADE_MIN 1
Serial.begin(9600); // Debug via serial window
delay (2500);
pinMode(FRONT_LED, OUTPUT);
pinMode (11, OUTPUT); // On board status LED
pinMode(A0, INPUT); // RC PMM Signal input
// pinMode(LED_PIN2, OUTPUT);
z = pulseIn(A0, HIGH, 20000);
if (z>1155 && z<1170) {
Nex5.shutterNow();
if (z>1780 && z<1820) {
Nex5.shutterNow();
delay(1500);
if (z>1430 && z<1500) {
Nex5.videoToggle();
case MB_LOW:
break;
break;
break;
Anyone able to assist in the above please.
I'm trying to maintain the blinking LEDs, but also respond to a PWM input by activating an infrared LED for an IR remote.
I think i'm getting the "multitasking" bit round my neck!
