Is there a way I can (at runtime) turn the clock of the Arduino down to 8Mhz so I can experiment with running programs at low or high speeds? I do some projects with a microcontroller connected without a crystal, and I'd like to know if it has enough power to run something that I program on the Arduino.
I'd have to be able to slow the clock down and change the variables that affect the timing and delay functions. I want to develop on an Arduino because it's easier to wire things up and I don't have to mess with a programmer until I'm done with the project.
For example:
Create and debug a musical greeting card with flashing RGB light, 2 pins to a speaker (for 2-voice sound), and a button. 6 I/O pins. I'd develop it on my arduino.
Once it works, do a magic toggle and run it correctly at 8Mhz so I don't have to rewire my project onto another chip. Only when I'm satisfied would I burn it onto something like the AtTiny85 and disable the crystal and reset pins so I'd have 6 I/O pins.
Otherwise, I have to keep high-voltage programming the AtTiny to enable to reset pin so I can load a new program onto it. I'd rather keep the hardware-specific debugging to a minimum.
Thanks for any advice.
