Error in camera C328R library file
Hello all,
I am interfacing camera and arduino.
I am using serial TTL camera and using C328R library file bt got error in it as "Byte in not known type"
Please help me.Thanks in advance.
Probably means the library hasn't been updated for IDE 1.0+. As you haven't posted a link to where you got it from, it's just a guess though.
hey i am attaching library file..
It gives error wherever byte is used..
Camera RSV5-C328R.zip (6.53 KB)
As I thought. Not IDE 1.0+ compatible.
You need to either:
. Use a pre-1.0 version of the IDE.
. Find a newer version of the library, or contact the author and get them to update it.
. Update it yourself.
If you want to update it yourself, there are a number of things you need to do.
. See point 2 at http://arduino.cc/forum/index.php/topic,97455.0.html.
. The library makes use of NewSoftSerial. You will need to replace all occurrences of NewSoftSerial with SoftwareSerial.
. Replace all:
		Serial.print(data,BYTE);
with
		Serial.write(data);
. There may be other things too.
I am getting so confused with updated and old libraries.
If any one having recent working stuff regarding C328 camera with arduino,please e-mail me on "rbangar30@gmail.com".
