I am an experienced arduino user but have absolutely no experience (or knowledge of) Processing.
I just downloaded the windows version here.
and tried to follow these instructions:
Unzip the library and copy the "arduino" folder into the "libraries" sub-folder of your Processing Sketchbook. (You can find the location of your Sketchbook by opening the Processing Preferences. If you haven't made a "libraries" sub-folder, create one.)
Run Arduino, open the Examples > Firmata > StandardFirmata sketch, and upload it to the Arduino board.
because there is no "Firmata" in any Examples menu that I can find.
In fact, I can't find "Firmata " anywhere.
I found this page but can't find
I googled it and found this: http://firmata.org/wiki/Main_Page
but can't find any instructions on how to use it.
At this point I don't know if I need something else.
I unzipped the Firmata archive and copied the "arduino " folder into my C:\My Documents\Arduino\Libraries" folder and it created
a bunch of folders there but there was nothing like a Readme file so I have no idea how to get it working.
I would appreciate some help figuring out how to use Processing.
I found out why I couldn't find "Firmata " in the menu. The arduino IDE displays the user installed libraries on the drop down menu before the IDE Examples so because I had so many folders the menu was too long to fit on the screen. I moved all MY libraries to a different HD.,
closed the IDE and reopened it and "Firmata" appears on the menu exactly where it was in your screenshot.
This is as far as I got. I was able to download and install Processing and open the app but have not been able to get it to work yet.
I think the problem has something to do with these lines:
String portName = Serial.list()[0];
myPort = new Serial(this, portName, 9600);
I know the arduino is on COM3 but I don't know how to tell Processing that.
Basically, I can open the Processing Application but that's about it. I can't figure out how to use it.
Also, I can load the StandardFirmata arduino sketch.
Also I seem to be having conflicts between the Processing and IDE with the COM port. (If one is running , I can't run the other).
Below is an except from one of my processing sketches that shows how I open the serial port to the arduino.
println(Serial.list()); lists the available comm ports and I see from viewing that list the first entry in the list was my arduino comm port so to open that port I used arduinoSerial = new Serial(this, Serial.list()[0], 115200);.
I'm not sure if I could use the port name like this arduinoSerial = new Serial(this, "com3", 115200);.
import processing.serial.*;
Serial arduinoSerial; // The serial port
boolean haveScanner = false; // Assume no Scanner attached
println(Serial.list()); // List all the available serial ports
arduinoSerial = new Serial(this, Serial.list()[0], 115200);// Open the port you are using at the rate you want:
arduinoSerial.clear(); // Flush serial buffers
