button plus switch/case scenerio
So, I am still learning. Any thoughts on how to combine this
const int LED = 13; //pin for LED
const int BUTTON = 7; //push button pin
int val = 0; //val used to store state of pin
int old_val = 0; //stores previous state of val
int state = 0; //0 = LED off and 1 = LED on
void setup () {
  pinMode(LED,OUTPUT); //LED is output
  pinMode(BUTTON, INPUT); //BUTTON is input
void loop (){
  val = digitalRead(BUTTON); //read input and store it
  //check transition
  if((val == HIGH) && (old_val == LOW)){
    state = 1 - state;
    delay(10);
    old_val== val; //val is now old..store it
    if (state == 1){
      digitalWrite(LED,HIGH); //turn LED on
    }else{
      digitalWrite(LED,LOW);
momentary button with a Switch/ Case function? The end result I'd like would be push button= LED goes on..Push button= LED blinks..Push button=throb....push button= off..
Any guidance from the community would be great
This may be a start, I haven't tested it but you can give it a try and see.
void setup () {
    static byte b_State = 0;
    static bool b_OnLastLoop = false;
    static unsigned long  u_LastTime = 0;
    static bool  b_Flag = false;
    //If pressed increment state.
    if( ( digitalRead( BUTTON ) == HIGH ) && !b_OnLastLoop  ){
      b_OnLastLoop = true;
      switch( ++b_State ){
        case 1:
          digitalWrite( LED, HIGH );
          break;
        case 2:
          b_Flag = true;
          u_LastTime = millis();
          break;
        case 3:
          b_State = 0;
          digitalWrite( LED, LOW );
          break;
    }else{
      if( digitalRead( BUTTON ) == LOW ) b_OnLastLoop = false;
      if( b_State == 2 ){
        unsigned long u_NewTime = millis();
        if( ( u_NewTime - u_LastTime )  >= 1000 ) {
          digitalWrite( LED, b_Flag ? LOW : HIGH );
          b_Flag = !b_Flag;
          u_LastTime = u_NewTime;
    return;
Wow, Thanks pYro_65..
That is way more complex than I thought it would be and introduces more for me to digest.. I'll have to spend some time on that one.
Did you write that on the fly?
