Private Sub Form_Load()
Dim mystr As String
Dim FoundIt As Integer
Dim ComFail As Integer
Dim FailErr As Integer
Dim n As Integer
MSComm1.Settings = "9600,N,8,1"
FoundIt = False
' find USB port
ComFail = False
FailErr = False
For n = 1 To 1
If MSComm1.PortOpen Then MSComm1.PortOpen = False
On Error Resume Next
MSComm1.CommPort = 1
MSComm1.DTREnable = True
MSComm1.RThreshold = 4
MSComm1.SThreshold = 3
MSComm1.InputLen = 0
MSComm1.PortOpen = True
Next
End Sub
the above code is what i edit using your code to find the comport...
- another thing is that, when i run the vb application and then hit the button it prompts an error in which i enclose in quote...then it points on the code above where i put a comment
Run-time error reading '8020':
Error reading comm device
Private Sub MSComm1_OnComm()
Dim strData As String
Static strBuffer As String
Dim strWords() As String
Dim intPos As Integer
Dim boComplete As Boolean
Dim mystr As String
Sleep 1000 ' this waits one second between readings from the Arduino
mystr = "" ' set the string to nothing
mystr = MSComm1.Input ////in this area the error points out
intPos = InStr(mystr, "<")
If intPos > 0 Then
Select Case Mid(mystr, 1, 3) ' strip off the CR/LF
Case "<Y>"
Text1.Text = ("The pressures value is 80 psi")
Call LEDOn(&HFFFF&) ' this is in hex
i need some help on how to fix this..
thanks!
