i try to make led high when enter 'on' in serial monitor and low when write 'off' i need to know why this code not operate
int ledPin=13;
char a[2] = {'o', 'n'};
char b[3] = {'o', 'f', 'f'};
char c[3] ;
void setup ()
pinMode(ledPin,OUTPUT);
void loop ()
c[3] = Serial.read();
if ((a[0]==c[0])&&(a[1]==c[1]))
{digitalWrite(ledPin,HIGH);
if (b[0] == c[0]&&b[1] == c[1]&&b[2] == c[2])
{digitalWrite(ledPin,LOW);
Don't write to the fourth element of a three element array
AWOL:
sorry i can't understand you :~
You've declared a three element array.
You're writing to the fourth element.
Don't do it.
C array indexes start at zero. Your c[3] array has three elements numbered [0], [1], and [2].
-br
Moderator edit:Smileys disabled
i don't know how i take value from serial and put it in array can you adjustment my code and post it thanks
Read it one character at a time, or check readBytes in the Serial reference.
AWOL:
please can you post any code to help me because i try to understand readbytes but i can't
thanks alot
Sorry, try the Arduino homework helpline.
MostafaHamdy:
I suggest you buffer the incoming message in a null-terminated c-string, and use the standard string functions to manipulate it.
// incomplete, untested
void handleSerial()
const int BUFF_SIZE = 32; // make it big enough to hold your longest command
static char buffer[BUFF_SIZE+1]; // +1 allows space for the null terminator
static int length = 0; // number of characters currently in the buffer
if(Serial.available())
char c = Serial.read();
if((c == '\r') || (c == '\n'))
// end-of-line received
if(length > 0)
handleReceivedMessage(buffer);
length = 0;
if(length < BUFF_SIZE)
buffer[length++] = c; // append the received character to the array
buffer[length] = 0; // append the null terminator
// buffer full - discard the received character
void handleReceivedMessage(char *msg)
if(strcmp(msg, "on") == 0)
// handle the command "on"
// etc
