Well it's saying the .avrduderc file is missing. I can create that file, but unless it's a blank file, it complains about formatting. There doesn't seem to be very much documentation about what the contents of that file should be.
Oh, I just re-read your entire output. That message has nothing to do with your problem. avrdude doesn't use it.
You are getting the common "out of sync" error.
What kind of Arduino do you have and where did you buy it?
Well I have two arduinos. THey're both unos. I forget where I bought the first one as it was almost a year ago. But that's the standard issue one.
The second Arduino is the R3 model and I bought that at radioshack. They're both giving me the same problem.
Don't mess with the FTDI drivers anymore. They don't hurt or help the Uno. (It doesn't have a FTDI chip.)
Don't connect through a hub.
Quit the IDE, disconnect the Arduino, restart the IDE. Does the same serial port still show up in the serial port list (it shouldn't).
Well it's interesting. The standard issue uno shows up as dev/tty.usbmodem431 every time
and the uno r3 just doesn't show up at all in the serial list.
So the original uno will show up as usbmodem641 if I plug it into a different physical port.
Plug in the R3.
Run "System Information" found inside of Applications -> Utilities
Click on USB. See if anything there is listed as Arduino or ATmega16u2. If you're comfortable, maybe screenshot it (CMD-SHIFT-4 then SPACE then click on the window, saved to desktop) to show what shows up.
Looks like the ATmega8u2 (or 16u2) on the other Uno stopped enumerating.
So what does that mean I should do?
You can refresh the firmware on the 8u2. Google for "Arduino DFU". DFU stands for Direct Firmware Update or something like that. That's how you write to the 8u2 flash memory via USB.
When I try to reset the 16u2 on the arduino R3 it sends a messages from the dfu-programmer that says device not present.
I even tried reinstalling the dfu-programmer with some patch to help it recognize the uno r3. As described on this post.
But nothing seems to work.
Seems like the Arduino uno is cursed issues. Is there different model I should look into buying or maybe move to a different micro controller?
boomrollkick:
I have like ten arduinos working since 2-3 year ago, none shown any problem ever (besides a duemillanove I burned with too much voltage, but then fixed replacing the ftdi), my previous experience was only with PIC, and that one was a bad experience (haha so I will never trust microchip again, even when they sell that chipkit something compatible with arduino).
You say "dfu-programmer that says device not present.", so (I don't know how devices show up on mac) your arduino is not in dfu mode yet.
I've been trying to figure out DFU mode on the arduino. Neither of the articles I found on it really seem to be up to date with the r3. because neither of these boards resemble the uno r3
http://ossnotebook.blogspot.com/2011/06/dfu-mode-arduino-uno-without-soldering.html
I appreciate everyone's help here. Thank you all so much. I'm really excited about getting my project off the ground. I've gone ahead and exchanged my arduino R3 for a new one.
I'm a bit nervous though about compiling and uploading from the mac with Mountain Lion. It's bricked one board that was working fine before and a second board that I picked up at the store afterwards.
Does anyone have any experience with successfully deploying from Arduino 1.0.1 on Macintosh Mountain Lion? I would love to hear about it.
I'm considering getting an ethernet shield to deploy with since I seem to be having difficulty with the USB method.
I'm also planning to take this class to see if the teacher can give me some guidance.
http://www.3rdward.com/3rdwardclasses/physical-computing-with-arduino.html
If anyone can point me in a direction that might help me move further along with this I would greatly appreciate it.
boomrollkick:
I've had no problems.
boomrollkick:
You can't program the board over Ethernet.
Ok my arduino uno r3 board is working. Thanks all for your help.
