// Conway's Game Of Life 128x64
// PaulRB
// Jun 2013
// Sept 2013 updated to use digitalWriteFast
#include <digitalWriteFast.h>
//Pins controlling KS0108 Graphic LCD
const byte GLCD_RS = 12; // H = data, L = instruction
const byte GLCD_E = 8;
const byte GLCD_DATA0 = 7;
const byte GLCD_DATA1 = 6;
const byte GLCD_DATA2 = 5;
const byte GLCD_DATA3 = 9;
const byte GLCD_DATA4 = 10;
const byte GLCD_DATA5 = 11;
const byte GLCD_DATA6 = 13;
const byte GLCD_DATA7 = 4;
const byte GLCD_CS1 = 3; // left half of screen
const byte GLCD_CS2 = 2; // right half of screen
const byte GLCDDelay = 3; // Enable GLCD to keep up with Arduino
const int redrawMethodBoundary = 320;
const byte SpeedPot = A6;
unsigned long Matrix[129][2]; // Cell data in ram
pinModeFast(GLCD_CS1, OUTPUT);
pinModeFast(GLCD_CS2, OUTPUT);
pinModeFast(GLCD_RS, OUTPUT);
pinModeFast(GLCD_E, OUTPUT);
pinModeFast(GLCD_DATA0, OUTPUT);
pinModeFast(GLCD_DATA1, OUTPUT);
pinModeFast(GLCD_DATA2, OUTPUT);
pinModeFast(GLCD_DATA3, OUTPUT);
pinModeFast(GLCD_DATA4, OUTPUT);
pinModeFast(GLCD_DATA5, OUTPUT);
pinModeFast(GLCD_DATA6, OUTPUT);
pinModeFast(GLCD_DATA7, OUTPUT);
digitalWriteFast(GLCD_CS1, HIGH);
digitalWriteFast(GLCD_CS2, HIGH);
digitalWriteFast(GLCD_RS, LOW);
digitalWriteFast(GLCD_E, LOW);
sendGLCD(B00111111); // Enable display
sendGLCD(B11000000); // Set Scroll Position = 0
randomiseMatrix();
outputMatrix();
//Serial.begin(38400);
generateMatrix();
//delay(analogRead(SpeedPot));
void sendGLCD(byte b) { //Send a byte to the GLCD
static byte oldb; // static variables keep their value between calls
digitalWriteFast(GLCD_E, HIGH);
delayMicroseconds(GLCDDelay);
if (b != oldb) { // do we need to change the pins?
if (b & B00000001) digitalWriteFast(GLCD_DATA0, HIGH); else digitalWriteFast(GLCD_DATA0, LOW);
if (b & B00000010) digitalWriteFast(GLCD_DATA1, HIGH); else digitalWriteFast(GLCD_DATA1, LOW);
if (b & B00000100) digitalWriteFast(GLCD_DATA2, HIGH); else digitalWriteFast(GLCD_DATA2, LOW);
if (b & B00001000) digitalWriteFast(GLCD_DATA3, HIGH); else digitalWriteFast(GLCD_DATA3, LOW);
if (b & B00010000) digitalWriteFast(GLCD_DATA4, HIGH); else digitalWriteFast(GLCD_DATA4, LOW);
if (b & B00100000) digitalWriteFast(GLCD_DATA5, HIGH); else digitalWriteFast(GLCD_DATA5, LOW);
if (b & B01000000) digitalWriteFast(GLCD_DATA6, HIGH); else digitalWriteFast(GLCD_DATA6, LOW);
if (b & B10000000) digitalWriteFast(GLCD_DATA7, HIGH); else digitalWriteFast(GLCD_DATA7, LOW);
oldb = b;
digitalWriteFast(GLCD_E, LOW); // data is read by glcd on falling edge
void outputMatrix() {
//Send matrix data for display on GLCD
for (byte x = 0; x <= 7; x++) {
byte col = x >> 2;
byte b = (x & 3) << 3;
sendGLCD(B01000000); // Set Y = 0
sendGLCD(B10111000 | x); // set X
digitalWriteFast(GLCD_RS, HIGH);
digitalWriteFast(GLCD_CS2, LOW);
for (byte row = 0; row <= 127; row++) {
sendGLCD(Matrix[row][col] >> b);
if (row == 63) {
digitalWriteFast(GLCD_CS1, LOW);
void randomiseMatrix() {
//Set up initial cells in matrix
randomSeed(analogRead(0));
for (byte col = 0; col <= 1; col++) {
Matrix[row][col] = random(0xffff) << 16 | random(0xffff);
void injectGlider() {
byte col = random(127);
byte row = random(1);
Matrix[col++][row] |= B0000111;
Matrix[col++][row] |= B0000001;
Matrix[col++][row] |= B0000010;
int generateMatrix() {
//Variables holding data on neighbouring cells
unsigned long NeighbourN[2], NeighbourNW[2], NeighbourNE[2], CurrCells[2], NeighbourW[2], NeighbourE[2], NeighbourS[2], NeighbourSW[2], NeighbourSE[2];
//Variables used in calculating new cells
unsigned long tot1[2], carry[2], tot2[2], tot4[2], NewCells[2];
int changes = 0; // counts the changes in the matrix
static int prevChanges = 256; // counts the changes in the matrix on prev generation
static int staleCount = 0; // counts the consecutive occurrances of the same number of changes in the matrix
//set up N, NW, NE, W & E neighbour data
for (byte b = 0; b <= 1; b++) {
NeighbourN[b] = Matrix[127][b];
CurrCells[b] = Matrix[0][b];
Matrix[128][b] = CurrCells[b]; // copy row 0 to location after last row to remove need for wrap-around code in the loop
NeighbourNW[b] = NeighbourN[b] >> 1;
bitWrite(NeighbourNW[b], 31, bitRead(NeighbourN[1-b], 0));
NeighbourNE[b] = NeighbourN[b] << 1;
bitWrite(NeighbourNE[b], 0, bitRead(NeighbourN[1-b], 31));
NeighbourW[b] = CurrCells[b] >> 1;
bitWrite(NeighbourW[b], 31, bitRead(CurrCells[1-b], 0));
NeighbourE[b] = CurrCells[b] << 1;
bitWrite(NeighbourE[b], 0, bitRead(CurrCells[1-b], 31));
//Process each row of the matrix
//Pick up new S, SW & SE neighbours
NeighbourS[b] = Matrix[row + 1][b];
NeighbourSW[b] = NeighbourS[b] >> 1;
bitWrite(NeighbourSW[b], 31, bitRead(NeighbourS[1-b], 0));
NeighbourSE[b] = NeighbourS[b] << 1;
bitWrite(NeighbourSE[b], 0, bitRead(NeighbourS[1-b], 31));
//Any live cells at all in this region?
if (CurrCells[b] | NeighbourN[b] | NeighbourS[b] | NeighbourE[b] | NeighbourW[b] | NeighbourNE[b] | NeighbourNW[b] | NeighbourSE[b] | NeighbourSW[b] > 0) {
//Count the live neighbours (in parallel) for the current row of cells
//However, if total goes over 3, we don't care (see below), so counting stops at 4
tot1[b] = NeighbourN[b];
tot2[b] = tot1[b] & NeighbourNW[b]; tot1[b] = tot1[b] ^ NeighbourNW[b];
carry[b] = tot1[b] & NeighbourNE[b]; tot1[b] = tot1[b] ^ NeighbourNE[b]; tot4[b] = tot2[b] & carry[b]; tot2[b] = tot2[b] ^ carry[b];
carry[b] = tot1[b] & NeighbourW[b]; tot1[b] = tot1[b] ^ NeighbourW[b]; tot4[b] = tot2[b] & carry[b] | tot4[b]; tot2[b] = tot2[b] ^ carry[b];
carry[b] = tot1[b] & NeighbourE[b]; tot1[b] = tot1[b] ^ NeighbourE[b]; tot4[b] = tot2[b] & carry[b] | tot4[b]; tot2[b] = tot2[b] ^ carry[b];
carry[b] = tot1[b] & NeighbourS[b]; tot1[b] = tot1[b] ^ NeighbourS[b]; tot4[b] = tot2[b] & carry[b] | tot4[b]; tot2[b] = tot2[b] ^ carry[b];
carry[b] = tot1[b] & NeighbourSW[b]; tot1[b] = tot1[b] ^ NeighbourSW[b]; tot4[b] = tot2[b] & carry[b] | tot4[b]; tot2[b] = tot2[b] ^ carry[b];
carry[b] = tot1[b] & NeighbourSE[b]; tot1[b] = tot1[b] ^ NeighbourSE[b]; tot4[b] = tot2[b] & carry[b] | tot4[b]; tot2[b] = tot2[b] ^ carry[b];
//Calculate the updated cells:
// <2 or >3 neighbours, cell dies
// =2 neighbours, cell continues to live
// =3 neighbours, new cell born
NewCells[b] = (CurrCells[b] | tot1[b]) & tot2[b] & ~ tot4[b];
//Have any cells changed?
if (NewCells[b] != CurrCells[b]) {
//Count the change for "stale" test
changes++;
if (prevChanges <= redrawMethodBoundary) {
//Faster to redraw just changed parts of screen at this low level of changes
unsigned long before = CurrCells[b];
unsigned long after = NewCells[b];
byte col = b << 2;
for (byte x = 0; x <= 3; x++) {
if ((before & 0xFF) != (after & 0xFF)) {
sendGLCD(B01000000 | row); // Set y
sendGLCD(B10111000 | col); // set X
sendGLCD(after & 0xFF);
before = before >> 8;
after = after >> 8;
col++;
Matrix[row][b] = NewCells[b];
//Current cells (before update), E , W, SE, SW and S neighbours become
//new N, NW, NE, E, W neighbours and current cells for next loop
NeighbourN[b] = CurrCells[b];
NeighbourNW[b] = NeighbourW[b];
NeighbourNE[b] = NeighbourE[b];
NeighbourE[b] = NeighbourSE[b];
NeighbourW[b] = NeighbourSW[b];
CurrCells[b] = NeighbourS[b];
if (row == 63) {
} //next row
if (changes != prevChanges) staleCount = 0; else staleCount++; //Detect "stale" matrix
if (staleCount > 32) injectGlider(); //Inject a glider
if (prevChanges > redrawMethodBoundary) outputMatrix(); //Faster to redraw entire screen at this high level of changes
prevChanges = changes;
