Topic: Problem using SPIFFS on ESP-01 (Read 898 times) previous topic - next topic
funtastic
SPIFFS worked for a long time but all of a sudden it stops working. Whenever i write a file its empty after next boot.
Using the same sketch on an Wemos D1 mini its works without problems. Actually im only facing this problem on a ESP-01.
I use arduino IDE with this settings: Board: "Generic ESP8266 Module", Flash Mode DIO, Flash Frequency: 40MHZ, CPU Frequency: 80 MHZ, Flash Size: 1M (64K SPIFFS)
This example sketch show the problem:
#include <FS.h>
   if (!SPIFFS.begin()) Serial.println("error while mounting filesystem!");
   readFile();
   writeFile();
   Serial.println("done");
void readFile()
  Serial.println("reading");
  File f = SPIFFS.open("/myFile.txt", "r");
  if (!f) Serial.println("file not available");
  else if (f.available()<=0) Serial.println("file exists but available <0");
    String ssidString = f.readStringUntil('#');
    Serial.print("read from file: ");
    Serial.println(ssidString);
  f.close();
void writeFile()
  Serial.println("writing");
  File f = SPIFFS.open("/myFile.txt", "w");
  if (!f) Serial.println("File creation failed");
    f.print("networkConfig");
    f.print("#");
    f.flush();
    f.close();
Output of some startups:
- First start
  reading
  file not available
  writing
  done
- Second start
  reading
  read from file:
  writing
  done
- Third start
  reading
  file not available
  writing
  done
- Fourth start
  reading
  writing
  done
Any ideas? Thank you
funtastic
I found out some additional information that might be helpful.
The working ESP-01 report as flash_id:
Manufacturer: e0
Device: 4014
and the new ones that are not working:
Manufacturer: 85
Device: 6014
May the new flash chip is not supported by the arduino esp plugin yet ?
chucktodd
Manufacturer: e0
Device: 4014
Manufacturer: 85
Device: 6014
You might have to pop the top and ID the flash Chip.
Chuck.
Currently built mega http server, Now converting it to ESP32.
funtastic
Sorry,
can you explain in other words maybe? I  dont understand "You might have to pop the top and ID the flash Chip."
gdsports
SPIFFS may be corrupted and needs a reformat. SPIFFS functions are documented here.
Juraj
SPIFFS is on the same flash as everything else. it can't be "not supported by the plugin", because the plugin use esptool the same way the sketch is written to flash.
read the docs
funtastic
@Juraj
I understand your point but there seems to be a special strange behavior within SPIFFS that causes flash chip dependent problems. By the way.. Reading is working because i was able to read data from spiffs after uploading a flash image of a functional device.
Also updating the firmware with OTA works althought there the flash also has to be written.
@gdsports
Its not that easy. Of course i already tried to format and many other things. And as stated before a functionals spiffs dumped from a functional device can also not be written on a ESP-01 with the new flash chip
chucktodd
Sorry,
unsolder the RF shield covering the ESP01 SPIFlash IC, Identify the manufacture/partnumber of the FlashIC. Use the FlashIc's datasheet to debug why SPIFFS is not correctly controlling that IC.
Chuck.
